Frodge Samba Member
Posted: Sat Oct 05, 2019 12:39 pm Post subject: Symptoms of loose drums |
Simple answer is check. But would a rear drum that is loosening up or wasn’t torqued correctly show any symptoms? Noise, drivability etc...... |
Cusser Samba Member
Joined: October 02, 2006 Posts: 31379 Location: Hot Arizona
Posted: Sat Oct 05, 2019 3:41 pm Post subject: Re: Symptoms of loose drums |
Frodge wrote: |
Could have noise.
Could have rear wheel wobble.
Could shear the big cotter pin.
Could shear off the splines of the drum and VW will not move when in gear.
O'Reilly has loaner torque wrenches that go to 250 ft lbs. You'll need a 36mm socket. _________________ 1970 VW (owned since 1972) and 1971 VW Convertible (owned since 1976), second owner of each. The '71 now has the 1835 engine, swapped from the '70. Second owner of each. 1988 Mazda B2200 truck, 1998 Frontier, 2014 Yukon, 2004 Frontier King Cab. All manual transmission except for the Yukon. http://www.thesamba.com/vw/forum/album_page.php?pic_id=335294 http://www.thesamba.com/vw/forum/album_page.php?pic_id=335297 |
Frodge Samba Member
Posted: Sat Oct 05, 2019 4:24 pm Post subject: Re: Symptoms of loose drums |
Also, how do you justify if a rear bearing is bad or not? Any test? |
VW_Jimbo Samba Member
Joined: May 22, 2016 Posts: 9966 Location: Huntington Beach, CA
Posted: Sat Oct 05, 2019 5:08 pm Post subject: Re: Symptoms of loose drums |
Frodge wrote: |
Jack the rear end up and set it on jack stands. Grab the tire at 12 o’clock and 6 o’clock and push and pull. Should be very slight play. Never measured it, but maybe 1/16. Keep track of it. As the bearing wears, the play will increase. When it gets really bad, it will start grumbling at you. If it starts grumbling or you have more than 3/16 of an inch play, its time to replace the bearings. _________________ Jimbo
TDCTDI wrote: |
67rustavenger wrote: |
GFY's Xevin and VW_Jimbo! |
