Prowe Samba Member
Joined: September 02, 2018 Posts: 14 Location: Michigan
Posted: Sat Oct 05, 2019 5:04 pm Post subject: Need Help Identifying My MOFOCO Engine Case |
I Have a MOFOCO engine case with this stamped number B6285309. Can anyone identify this case for me, I can't find it on MOFOCO's site of any other VW site.
Thanks in advance for your assistance!!
Phil
_________________ Thank you,
Philip Rowe |
andk5591 Samba Member
Joined: August 29, 2005 Posts: 16758 Location: State College, PA
Posted: Sat Oct 05, 2019 6:27 pm Post subject: Re: Need Help Identifying My MOFOCO Engine Case |
Message Roy or call them Monday. _________________ D-Dubya Manx clone - 63 Short pan,1914.
Prowe Samba Member
Posted: Sat Oct 05, 2019 6:58 pm Post subject: Re: Need Help Identifying My MOFOCO Engine Case |
andk5591 wrote: |
Message Roy or call them Monday. |
Thanks for the reply, Can you give me Roy's user name co I can message him.
Thank you. _________________ Thank you,
Philip Rowe |
Glenn Mr. 010
Joined: December 25, 2001 Posts: 76945 Location: Sneaking up behind you
vwinnovator Samba Member
Joined: July 11, 2005 Posts: 1555 Location: Still doing it in the back of your VW
Posted: Sun Oct 06, 2019 10:32 am Post subject: Re: Need Help Identifying My MOFOCO Engine Case |
that's just a "B"block made by vw
notice how the logo surface is machined.... |
Cusser Samba Member
Joined: October 02, 2006 Posts: 31380 Location: Hot Arizona
Posted: Sun Oct 06, 2019 2:13 pm Post subject: Re: Need Help Identifying My MOFOCO Engine Case |
vwinnovator wrote: |
that's just a "B"block made by vw |
Dual relief case originally used as a 1600cc single port engine, for 1970 year. _________________ 1970 VW (owned since 1972) and 1971 VW Convertible (owned since 1976), second owner of each. The '71 now has the 1835 engine, swapped from the '70. Second owner of each. 1988 Mazda B2200 truck, 1998 Frontier, 2014 Yukon, 2004 Frontier King Cab. All manual transmission except for the Yukon. http://www.thesamba.com/vw/forum/album_page.php?pic_id=335294 http://www.thesamba.com/vw/forum/album_page.php?pic_id=335297 |
Rome Samba Member
Joined: June 02, 2004 Posts: 9654 Location: Pearl River, NY
Posted: Sun Oct 20, 2019 6:37 am Post subject: Re: Need Help Identifying My MOFOCO Engine Case |
I agree about contacting MoFoCo for the most reliable info about your case.
About 15 years ago a friend gave me a bare case with the same large MOFOCO logo on both sides of the engine sump. That engine # started with AH, making it a dual-port engine case. He bought the complete longblock from MoFoCo in the late 1990's which that company built as a 1776 cc (90.5 mm cylinders) and it was also painted the same gold as yours. That case needed a line-bore, so that he bought a new case as basis for a 2-liter engine build using nearly all-new parts. I ground off the sump logos, had the line bore done, cleaned the entire case throughly and painted the external surface semi-gloss black. I built it up as a mild 1776 with DP heads and dual carbs. Still have it.
Have you measured your cylinder spigot bores, in case the case's gold color was indicative of certain big bore sizes? Diameter would be 90 mm for a stock 1600's 85.5 cylinder, or 96 mm for the 90.5's. |
