Lowering a swb and value
PDX db
PDX db is offline
PostPosted: Sun Oct 06, 2019 3:15 pm    Post subject: Lowering a swb and value Reply with quote
I'm more familiar with VW values where lowered cars often sell for less than stock height. Is this also the case with swb Porsche's?
HarryFD
HarryFD is offline
PostPosted: Sun Oct 06, 2019 10:52 pm    Post subject: Re: Lowering a swb and value Reply with quote
Lowering a 912/911 is done by re-indexing the front and rear torsion bars. It is easily reversible unless the ride height lower extremely lowered requiring additional modification to the steering and suspension.
How low are you concerned about?
1970 Deluxe Sunroof Bay Brilliant Blue/Cloud White
1971 Jaguar XKE 2+2 V12 Coupe
1973.5 911 Targa
2009 MB C300
[email protected]
dr914@autoatlanta.com is offline
PostPosted: Mon Oct 07, 2019 9:29 am    Post subject: Re: Lowering a swb and value Reply with quote
I would actually not lower the car, put a level in the door sill with the tire inflation correct and make sure that the car is even
Lowering or raising the front is very easy, the rear is not as taking apart the radius arms and getting the proper degree is very tedious work, especially if one torsion bar is weaker than the other one. Also parts may be rusted
PDX db
PDX db is offline
PostPosted: Mon Oct 07, 2019 3:01 pm    Post subject: Re: Lowering a swb and value Reply with quote
I purchased some away away adjustable springplates for my 912. I'm in the process of trying to sell the car....not sure if the effort is a positive or negative on selling. I think it would certainly look better lowered, just not sure if the market agrees.
HarryFD
HarryFD is offline
PostPosted: Mon Oct 07, 2019 3:41 pm    Post subject: Re: Lowering a swb and value Reply with quote
If the car drives ok now (no weird handling issues) save your money and leave it alone. If you lower the car you will need to get us aligned and corner balanced. Depending on how low you go, you will also need to address bump steer issues.
1973.5 911 Targa
2009 MB C300
jt912
jt912 is offline
PostPosted: Tue Oct 08, 2019 12:48 pm    Post subject: Re: Lowering a swb and value Reply with quote
For a car you are flipping, I would spend the least amount of time and money on it. Make sure it is presentable, clean, and well sorted. That will give you a way bigger bang-for-your-buck than lowering it. If the Fuchs are not aftermarket, they will also be a good selling point.
[email protected]
PostPosted: Wed Oct 09, 2019 7:44 am    Post subject: Re: Lowering a swb and value Reply with quote
keep it at stock height by all means
