Zeitgeist 13 Samba Member
Posted: Tue Oct 08, 2019 1:37 pm Post subject: Re: Catalytic silencer for diesel heaters |
If it's going to work, it probably needs to be mounted right to the burner exit. I've long suspected that the cat on my tdi van isn't as effective because it's too far downstream to capture the required heat needed to function properly. _________________ Casey--
'01 Weekender --> full camper
y u rune klassik? |
big swifty Samba Member
Joined: August 21, 2007 Posts: 246 Location: Formally in Republic of VT; now in Hollywood, FL
Posted: Tue Oct 08, 2019 3:37 pm Post subject: Re: Catalytic silencer for diesel heaters |
I have the D2. Never been bothered by diesel odor on startup or while continuously running. _________________ Evan
1987 Vanagon Syncro // Westfalia pop-top graft // Factory new ALH. 11mm IP. AFN 110 RC 2,3,4 // S7 turbo// Titan P502's
2013 Golf 4d TDI. No mods. Yet.
[1991 Jetta coupe TD. Giles Superpump. Custom tall 5 speed. SOLD |
SyncroButter Samba Member
Joined: February 02, 2016 Posts: 383 Location: Seattle
Posted: Tue Oct 08, 2019 3:47 pm Post subject: Re: Catalytic silencer for diesel heaters |
vwwestyman wrote: |
SyncroButter wrote: |
vwwestyman wrote: |
Those are significantly larger that what would be required/used on one of the little heaters. |
Oh, absolutely.... WAAAAAAY overkill. But also not $330. |
I'm thinking that if one really wanted a catalytic converter, that giant thing (as compared to the small one made for the heater) would probably never get hot enough to work properly. |
Interesting, I never realized that the cat has to get hot in order to function, but that does make sense... I learned something new today! _________________ Grant
In the stable: 1986 Syncro Westfalia/Bostig, 1989 Doka Tristar, 1974 Vespa Rally 200, 1973 Vespa Primavera 125, 1963 Solex 2200, 1938 Buick Special
Gone but not forgotten: 1989 Porsche 944, 1973 Standard Beetle |
fxr Samba Member
Joined: December 07, 2014 Posts: 2325 Location: Bay area CA
Posted: Wed Oct 09, 2019 7:03 pm Post subject: Re: Catalytic silencer for diesel heaters |
Apparently the diesel heaters should have a maximum combustion chamber temperature of 180°C, ~350°F - not nearly hot enough to 'light up' a cat. _________________ Jim Crowther
Vespa GTS 300 |
DanHoug Samba Member
Joined: December 05, 2016 Posts: 4790 Location: Bemidji, MN
Posted: Thu Oct 10, 2019 5:31 am Post subject: Re: Catalytic silencer for diesel heaters |
fxr wrote: |
Apparently the diesel heaters should have a maximum combustion chamber temperature of 180°C, ~350°F - not nearly hot enough to 'light up' a cat. |
seems so, but there IS a cat made for these heater's exhaust! it probably isn't a super high tech media that operates at lower than normal temp, as it would sky rocket the price beyond the advertised 300Euro.
i don't even have one of these heaters but i'd love to bench test one with some different cats i have around. very easy to see if they are working with an IR camera. something for the long garage project list, eh? _________________ -dan
www.thefixitworkshop.com |
