Hand brake ratchet pull rod
malcolm2
malcolm2 is offline
PostPosted: Wed Oct 09, 2019 9:35 am    Post subject: Hand brake ratchet pull rod Reply with quote
The pull rod has a hole in one end. The pull handle is attached via a roll pin in that hole. With the assembly at rest, driving down the road. What is the orientation of the T-Handle?
I thought it was horizontal as pictured below. That position would face the ratchet teeth upwards. You pull the rod and the teeth catch on the ratchet spring plate and the rod stays where you stop.
The result of that question will answer the MAIN problem here.
The spring.
It seems that the spring tension make it point straight down when at rest. Putting the teeth at about 10 o'clock and the T-handle pointing at 2 o'clock. IS THAT RIGHT?
in this orientation, the ratchet plate slides on top of the rod until i twist my wrist to rotate the teeth upwards. And then the spring is pretty tight and could actually rotate the rod disengaging the teeth and the park brake.
My Toys: '75 Porsche 914, '92 Ski Nautique and now a 1972 VW Transporter Deluxe (punch list fixing)
Daverham
Daverham is offline
PostPosted: Wed Oct 09, 2019 10:01 am    Post subject: Re: Hand brake ratchet pull rod Reply with quote
You are correct that the ratchet teeth face straight up at rest. And the T-handle is horizontal (with the longer part on the right).
Your problem is that the rod isn't seated all the way forward. The pin that the spring attaches too doubles as a stop which prevents the whole thing from rotating too far counter clockwise. The spring pulls it down, but it doesn't go all the way to 6 o'clock. It hits the parking brake lever and stops at about 8 o'clock, which leaves the handle horizontal. Make sense?
SGKent Premium Member
SGKent is offline
PostPosted: Wed Oct 09, 2019 10:24 am    Post subject: Re: Hand brake ratchet pull rod Reply with quote
my handle is horizontal with the notches up. To release it you turn it clockwise.
“Most people don’t know what they’re doing, and a lot of them are really good at it.” - George Carlin
skills@eurocarsplus
Samba Peckerhead
PostPosted: Wed Oct 09, 2019 10:48 am    Post subject: Re: Hand brake ratchet pull rod Reply with quote
yes, the lollipop is adjusted too far. as mentioned, the pin contacts the lever and acts as a stop
gprudenciop wrote:
[email protected] wrote:
Jake Raby wrote:
Brian wrote:
malcolm2
malcolm2 is offline
PostPosted: Wed Oct 09, 2019 11:18 am    Post subject: Re: Hand brake ratchet pull rod Reply with quote
Yes. Perfect. I assumed the eyebolt was part of the adjustment. Threading it all the way in will be the fix.
Thanks.
