Paul Windisch Samba Member
Joined: September 02, 2009 Posts: 2546 Location: Clinton Township, Michigan
Posted: Fri Oct 11, 2019 7:12 am Post subject: Re: Bearing diagnosis? |
ekacpuc wrote: |
Paul Windisch wrote: |
A W110 should idle pretty well. I have that cam in mine, and it idles smoothly at 900 rpm. You may have had other issues if the idle is rough. |
You’re not running the stock carb correct? W110 is a lot for one carb throat. |
Correct. Sorry, after re-reading the OP's post, I realized he's on a single barrel. I (incorrectly) assumed that if one took the engine apart to install a different cam, the other peripherals would have also been upgraded.
My apologies. _________________ *ASE Recertified Master Automotive Tech*
1984 Mexican Beetle
-1914cc
-L3 Heads 35x32 valves 52cc chambers
-0.040" deck for about 9.1:1 Compression
-Engle W110 cam
-CB Super Stock 1.1:1 Rockers
-Stock Heat Exchangers w/ Tri-Mil Muffler
-Dual Weber IDF 40s w/ 26mm venturis
-034 SVDA Distributor
2013 Chevrolet Volt DD
2005 Pontiac Montana SV6
MAHLE Service Solutions
Applications Engineer |
mark tucker Samba Member
Posted: Fri Oct 11, 2019 12:25 pm Post subject: Re: Bearing diagnosis? |
the pistons are spekled with debris. they are tiny but they are there, thats what causing the lines in the cylinders... look at the end of each line in the pistons and there will usualy be a spec imbeded. as well as some with no lines. they are eazy to pick out with a sharp hard tool I like dentist picks to do it. it takes a while to get them all and dont wory about hurting the piston.did a hole if you wish it wont hurt squat, just get every peice out!!! you can scratch across and feal and hear the steel/iron in the skirts with a pick.some will cum right out and some will take some work. rough honed replacement cylinders fill the skirts with iron as the rings wear out. thus the need to "knock the tooth off the hone pattern" this greatly reduces the blow by and shedding of debris in to the oil&skirts. dont forget to add a spin on oil filter. |
TomSimon Samba Member
Posted: Sat Oct 12, 2019 5:58 am Post subject: Re: Bearing diagnosis? |
It sounds like you purchased a VW from what I call a 'flipper', a guy who pieced something together, a used engine from under the work bench, slapped on some chrome tin for nice pictures, slapped it together and "send it!" About what I'd expect from a used VW where the owner 'didn't know much about the engine'. A worn out POS, but it drove, and idled, able to ship it as a running vehicle. Pretty typical, actually. Hopefully you boought it with the possibility it needed a rebuild, in mind, and budgeted $3k-$5k depending on goals.
Again, not a horrible or dishonest deal, unless it was mis-represented as 'a one-owner, numbers matching time capsule, deal of the century w/rebuilt engine'. If so, you were taken advantage of.
Moving forward, if you plan to love and keep this car, it's time for a quality rebuild. Set a realistic budget, connect with a local VW machine shop. You might find that having a reputable engine builder will save money and time in the long run, and move your purchase from 'project' to 'runner and driver' status much quicker and less painful. Budget and goals.
The bearings show trash has run through it, probably super dirty oil with carbon chunks have circulated though it. Nothing out of the ordinary for old cars. The W110 cam is puzzling, but a new cam is part of any build, they are cheap, cam, lifters, and bearings $100-$200 depending on what you want. . the 'std' marking is just 'standard' cam bearing. Those cam bearing look fine, by the way, but replace them with a rebuild. The case where the cam bearings fit almost never need attention, but the lifter bores need to be scrutinized for wear, repaired if needed, given the that trash has gone through the engine.
There are many threads on the sequence of a complete rebuild, which is what you need. Start with goals, them break it all down and have the ca application, bu these things are getting old, so the case needs to be looked at for case spreading, bad head stud threads. Typically you are looking at doing an align bore of the case, regrind the crank, and have the machine shop supply new oversize bearings to match.
I hope that helps _________________ 2-time NASA Pro Racing Champion, Bonneville 130 Club and 150 Club Memeber, BRS Pro Gas racer |
petrol punk Samba Member
Joined: August 21, 2007 Posts: 975 Location: Las Vegas, NV
Posted: Sat Oct 19, 2019 2:59 pm Post subject: Re: Bearing diagnosis? |
I am going to piggyback off this thread since your case is so similar to mine. Pulled these out after 500 miles. It was making an awful knocking sound and the oil looked like an aluminum based syrup. This was ran with the Mexican style oil pump/filter combo. I'm guessing this is oil contamination too? Unfortunately pulley side main journal has a deep gouge in it and the thrust bearing journal borderline fails the fingernail test as well.
Don't mind the white powder chalky looking stuff here. Thought I picked the brake cleaner can.
_________________ 36hp '56 European DeLuxe oval, '70 bug 1835cc dual 36DRLA, and a '98 4x4 5spd single cab Tacoma |
Who.Me? Samba Member
Joined: July 14, 2014 Posts: 2206 Location: UK (South)
Posted: Wed Oct 23, 2019 11:00 am Post subject: Re: Bearing diagnosis? |
I was chased up for some pictures of the rod bearings. Finally had a chance to split the rods this evening...
I've got the case and crank ready to go off for machining. Just need to find a decent strength box to ship them in. _________________ Andy
Looking for info on my truck's history. Are you from Campbell California or nearby. Do you recognise it? ... http://www.thesamba.com/vw/forum/viewtopic.php?t=636786 |
txoval Samba Member
Joined: January 23, 2004 Posts: 3552 Location: The Woodlands, TX
Posted: Wed Oct 23, 2019 6:03 pm Post subject: Re: Bearing diagnosis? |
Your bearings (Mains) look like too tight of clearances...
petrol punk wrote: |
I am going to piggyback off this thread since your case is so similar to mine. Pulled these out after 500 miles. It was making an awful knocking sound and the oil looked like an aluminum based syrup. This was ran with the Mexican style oil pump/filter combo. I'm guessing this is oil contamination too? Unfortunately pulley side main journal has a deep gouge in it and the thrust bearing journal borderline fails the fingernail test as well. |
modok Samba Member
Joined: October 30, 2009 Posts: 26781 Location: Colorado Springs
Posted: Thu Oct 24, 2019 4:48 pm Post subject: Re: Bearing diagnosis? |
A lot of dirt in there. The more dirt stuck in the bearing, the "tighter" they get. |
PEPPE Samba Member
Joined: August 24, 2003 Posts: 1068 Location: Roma Italy
Posted: Fri Oct 25, 2019 1:11 pm Post subject: Re: Bearing diagnosis? |
the case may be loose in the main bearing seats, if the rebuild is recent they don not linebore the case. crank looks damaged (cut) where the flywheel shims ride. |
Posted: Fri Nov 01, 2019 6:47 am Post subject: Re: Bearing diagnosis? |
Do you have an opinion on the bugpack or Scat versions? (e.g. https://www.coolairvw.co.uk/Item/Shop_by_Vehicle~B...Studs.html)
I can't find anywhere in Europe that has the CB Performance one in stock and they all order direct from CB Perf. The linked seller above seems to be the only seller in the UK who advertises the 4-bolt 'dished' cam version. They have a six week lead time and it's just under £120.00 ($155) with my discount.
I have a relative in D.C, who I could probably get to forward one direct to me more quickly and at lower cost though.
The UK seller also felt the Maxi Pump is overkill for a stock 1600 D.P engine due to the pump gearing. The CB Perf. link says the gears are 26mm which I thought was standard for a dished cam oil pump though?
Does the Maxi Pump put out excessive pressure? _________________ Andy
PEPPE Samba Member
Posted: Fri Nov 01, 2019 6:56 am Post subject: Re: Bearing diagnosis? |
yes, 26mm is standard for dished cam, so no really "HD" |
Posted: Sat Nov 02, 2019 1:36 am Post subject: Re: Bearing diagnosis? |
Thanks. CB Performance's description inclues this line that I'd overlooked before...
Quote: |
The pumps are assembled with closer tolerances than stock pumps to provide increased oil pressure during low speed operation. |
Is that significant, and is it desirable for a stock road engine or not? _________________ Andy
RWK Samba Member
Posted: Sat Nov 02, 2019 5:40 am Post subject: Re: Bearing diagnosis? |
Poorly maintained stock oil bath air cleaner causes a lot of dirt ingress also, one of the reasons VW used oil bath, helps with the lack of oil filter. _________________ 73 Type 181
63 Type 113
63 Type 261- 428 071
62 Type 241-378 025 178 530 |
Posted: Sat Nov 02, 2019 3:53 pm Post subject: Re: Bearing diagnosis? |
wow!! those main & rod bearings are full of shit!!!! was the crank oil gallys cleaned good before assy???or did the camshaft die too?? yikes! |
