Frodge Samba Member
Posted: Thu Oct 10, 2019 12:59 pm Post subject: 1972 bug stalling. |
Not mine. It’s my neighbors. Runs solex 30 pict 2 with a Pertronix module. Car runs fine. Hard to start sometimes unless he pours gas down the carb throat. Runs great once it’s going. When it warms up and you come to a stop, it will stall out. |
jeffrey8164 Samba Member
Joined: January 06, 2018 Posts: 3819 Location: Georgia
Posted: Thu Oct 10, 2019 3:52 pm Post subject: Re: 1972 bug stalling. |
Rebuild the carb.
Look for intake leaks when hot.
While you’re at it, do a compression and leak down test, check torque on the heads and adjust the valves. _________________ Volkswagen!
(Compression 8.7:1) |
Paul Windisch Samba Member
Joined: September 02, 2009 Posts: 2546 Location: Clinton Township, Michigan
Posted: Thu Oct 10, 2019 4:57 pm Post subject: Re: 1972 bug stalling. |
Frodge wrote: |
For the starting issue, check the operation of the accelerator pump output, and check to make sure the choke is working properly.
For the stalling when coming to a stop, as suggested, check for vacuum leaks. _________________ *ASE Recertified Master Automotive Tech*
1984 Mexican Beetle
-1914cc
-L3 Heads 35x32 valves 52cc chambers
-0.040" deck for about 9.1:1 Compression
-Engle W110 cam
-CB Super Stock 1.1:1 Rockers
-Stock Heat Exchangers w/ Tri-Mil Muffler
-Dual Weber IDF 40s w/ 26mm venturis
-034 SVDA Distributor
2013 Chevrolet Volt DD
2005 Pontiac Montana SV6
MAHLE Service Solutions
Applications Engineer |
Frodge Samba Member
Posted: Thu Oct 10, 2019 5:16 pm Post subject: Re: 1972 bug stalling. |
The engine only has 2000 miles on it. Valves are adjusted. Where would you check for vacuum leaks on the car? I’m going to see him tomorrow. |
Posted: Thu Oct 10, 2019 5:34 pm Post subject: Re: 1972 bug stalling. |
Check the entire intake tract for leaks; manifolds to heads, manifolds to intake pipe, intake to carburetor base, throttle shaft bushings, and any vacuum lines that are fed by the intake BELOW the throttle blade. _________________ *ASE Recertified Master Automotive Tech*
1984 Mexican Beetle
-1914cc
-Engle W110 cam
Teeroy Samba Member
Joined: April 20, 2003 Posts: 3685 Location: Eastern WA
Posted: Thu Oct 10, 2019 6:09 pm Post subject: Re: 1972 bug stalling. |
Stalling is probably improper intake heat, Starting issue improper choke setting. Could be alot of other things, but these are common issues _________________ Pres. Rivercity VW Club www.rcvwclub.org
Founder Derr Wheat Panzers (DWP)
ARR #3
www.autosportsnorthwest.org |
