Frodge Samba Member
Posted: Thu Oct 10, 2019 5:54 pm Post subject: 205T tune up part #s |
Where can I find a cross reference of the parts I would need for this distributor? Cap, rotor, points, condenser plugs etc. |
Glenn Mr. 010
Joined: December 25, 2001 Posts: 76760 Location: Sneaking up behind you
Posted: Thu Oct 10, 2019 6:05 pm Post subject: Re: 205T tune up part #s |
Condensor: 02 007
Rotor: 04 033
Cap: 03 010
Plugs are NGK B5HS if you have the original heads. _________________ Glenn
Member #1009
#BlueSquare |
Frodge Samba Member
Posted: Thu Oct 10, 2019 6:15 pm Post subject: Re: 205T tune up part #s |
Thanks. |
Frodge Samba Member
Posted: Thu Oct 10, 2019 6:20 pm Post subject: Re: 205T tune up part #s |
What condenser is 02069? |
Glenn Mr. 010
Posted: Thu Oct 10, 2019 6:22 pm Post subject: Re: 205T tune up part #s |
Frodge wrote: |
If you have AC, I assume it hit the bracket or compressor.
Looks like the lead wire is different so you can mount the condenser on the other side of the vacuum canister.
02 007
02 069
Member #1009
#BlueSquare |
Frodge Samba Member
Posted: Thu Oct 10, 2019 6:27 pm Post subject: Re: 205T tune up part #s |
So the wire is just longer. I guess I can still use that. I have one of those. Thanks. |
Joined: April 27, 2002 Posts: 6371 Location: Pentwater, Michigan
Posted: Thu Oct 10, 2019 6:43 pm Post subject: Re: 205T tune up part #s |
Here's the best all around link for tune up parts identification by distributor model, IMHO:
https://www.thesamba.com/vw/archives/manuals/Bosch_Tune_Up_Parts/Bosch_Tune_Up_Parts.pdf _________________ Roads Scholar &
1961 (October)Single Cab- Road Trip Workhorse |
heimlich VWNOS.com
Joined: November 20, 2016 Posts: 6554 Location: Houston, Texas
Posted: Fri Oct 11, 2019 7:50 am Post subject: Re: 205T tune up part #s |
I have the parts for each distributor filtered. Here is yours: https://www.vwnos.com/Catalog/DistributorSearch?distributor=113+905+205+T
As for the condensers just go with 02069. 02007 is actually a specialty condenser. Instead of stocking one for AC and one without the 02069 is used universally since it has the longer wire. _________________ www.vwnos.com [email protected]
