63 vwnotch Samba Member
Joined: December 31, 2002 Posts: 734 Location: Riverside,CA Econo Motors
Posted: Fri Oct 11, 2019 2:59 pm Post subject: Dont look in classifieds.... |
I've been guilty of browsing classifieds in the past and wind up with yet another project I wasnt even looking for...
I'm not grounded or anything, but I'm currently not allowed to peruse classifieds in any category other than parts😁 _________________ BUS WANTED: 13 window BUS any year considered.. |
my59 Samba Member
Joined: August 13, 2003 Posts: 3793 Location: connecting the dots
Posted: Fri Oct 11, 2019 3:22 pm Post subject: Re: Dont look in classifieds.... |
63 vwnotch wrote: |
I'm not grounded or anything, but I'm currently not allowed to peruse classifieds in any category other than parts😁 |
Well, if its missing some parts, you could call it a parts car, not a project.... _________________ my59: Well son, my grandfather died before I got to drive it, so does that answer your question?
Other:'12 Jetta, '77 Benz 300D, and a 74 MG Midget. |
ach60 Samba Member
Joined: May 14, 2001 Posts: 4139 Location: Santa Maria
Posted: Mon Oct 14, 2019 5:36 pm Post subject: Re: Dont look in classifieds.... |
It never hurts to look, or build it in your head
Example:
Off Road look Crown Victoria for $7900 up to $10,500
2011 Ford Crown Victoria Police Interceptor - $4500 (brentwood / oakley) White with Bull Bar odometer: 88000
https://sfbay.craigslist.org/eby/cto/d/discovery-bay-2011-ford-crown-victoria/6974321131.html
2008 Crown Victoria Police Interceptor - $1500 (san jose east) Silver odometer: 54500 Smog & Rust issues
https://sfbay.craigslist.org/sby/cto/d/san-jose-2008-crown-victoria-police/6971012746.html
2011 Ford Crown Victoria Police Interceptor P71 92K miles - $3600 (burlingame) Black& White odometer: 92889
https://sfbay.craigslist.org/pen/cto/d/burlingame-2011-ford-crown-victoria/6959091227.html
___________________________________________________________________________________________
5x114.3 Wheel information, 235/50ZR18 97W tire(stockish Diameter) for a 27” tire height
03-UP 16x7 5x114.3 1/2-RH 70.3 H
Mickey Thompson Street Comp SC-5, 18x10.5 Wheel with 5 on 114.3 Bolt Pattern - Flat Black (3080421) - 90000021238
Wheels Link: https://www.4wheelparts.com/p/mickey-thompson-stre...0000021238
Brand Mickey Thompson
Model Street Comp SC-5
Item Weight 24.7 pounds
Product Dimensions 20.2 x 20.2 x 12.8 inches
California residents Click here for Proposition 65 warning
Item model number 90000001865
Exterior
Machined Lip
Manufacturer Part Number 90000001865
OEM Part Number
90000001865
Construction
1 Piece, Cast
Rim Diameter
18 inches
Rim Width
10.5 inches
Bolt Pattern (Number of Holes)
5
Bolt Pattern (Pitch Circle Diameter)
127 millimeters
Offset
45 millimeters
Backspace
7.5 inches
Bore Diameter
2.78 inches
Tire
Link: https://www.4wheelparts.com/p/bf-goodrich-35x12-50r18-tire-all-terrain-t-a-ko2-13389/_/R-BDKZ-13389
BF Goodrich 35x12.50R18 Tire, All-Terrain T/A KO2 - 13389
Part Number: BFG13389
$324.99 and $2,245.92 for 4 wheels & Tires
06-11 FORD PANTHER 3″ TO 10″ CAR LIFT KIT FOR CROWN VIC, MARQUIS, TOWN CAR
Link: https://www.universalcarlifts.com/product/06-11-fo...mp;yr=2010
Lift Kit Size
10"
Bushings / Ball Joints
Installed In Kit
Panhard / Track Bars
2 Panhard Bars
$2,609.00
Information:
3″ to 10″ complete suspension kit for 2006-2011 Crown Victoria, Grand Marquis, and Town car. This kit installs under your factory coil springs to lift your Car 3 to 10 inches! Clear 22 inch up to 28 inch rims and tires with this kit (measure to be sure).
Complete kit for 06-11 Vic, Marquis and Town Car
Comes with custom strut lift spacer brackets, extended front and rear control arms, panhard bar, extended rear shocks, installation manual and full install DVD. This kit includes control arms for the front of the car to eliminate the negative camber (where the wheel tilts inwards towards the top) that is caused when lifting a car. Also included are the rear adjustable trailing arms to keep the wheel centered in the wheel well and drive shaft angle correct. The panhard bar keeps your axle centered side to side. Adjustable arms will keep your tires from wearing excessively on the inside and will keep your alignment on straight.
Demand the highest quality parts for your Vic project
UCL parts are built out of rugged over-sized steel of the highest quality and craftsmanship. Parts have a durable black powder coat finish and lifetime warranty. 8″ Kit also includes universal body lift kit. 10″ kit adds a body lift and threaded adjustable coil-over front struts, which will allow you to get a few extra inches out of the front suspension. Remember to add the bushings and ball joints! Most shops and customers agree that the installation time and stress levels are greatly reduced when you have us INSTALL the Bushings. Simply select the option that says “Installed In Kit”.
Special notes about this kit
Note: this kit comes standard with 1 panhard bar- if you have a police edition, taxi, towing package, Grand Marquis or Town Car you may need an extra bar, be sure to select the correct option below.
ABOUT OUR OPTIONS:
• “Not Included” = You will need to get your own bushings and ball joints from a part store.
• “Included In Kit” = The kit will come with the bushings and ball joints. You will need to install the bushings and ball joints with a press.
• “Installed In Kit” = The kit will come with the bushings and ball joints INSTALLED!! Customers agree this is the best option.
• “Panhard / Track Bars” = Either 1 panhard bar or 2 panhard bars, depending on how many your car has. _________________ Good Luck
Al |
Joined: August 31, 2013 Posts: 12855 Location: North Carolina
Posted: Mon Oct 14, 2019 6:58 pm Post subject: Re: Dont look in classifieds.... |
Umm... that lift kit is for “Donk” status, not for any sort of off-road abilities. _________________ Everybody born before 1975 has a story, good, bad, or indifferent, about a VW.
bluebus86 Banned
obus Samba Member
Joined: March 08, 2001 Posts: 11069 Location: just off Garden State Parkway Exit 81
