Automatic Transmission nightmare
jkidd152
jkidd152 is offline
PostPosted: Sat Oct 12, 2019 4:04 pm    Post subject: Automatic Transmission nightmare Reply with quote
At a friends house to help him reinstall his transmission and then this happens
What do you think? Is he screwed? He might try to JB weld it
'85 Syncro Westy Wink
djkeev Premium Member
djkeev is offline
PostPosted: Sat Oct 12, 2019 4:21 pm    Post subject: Re: Automatic Transmission nightmare Reply with quote
They are heavy!
Dropping it can't be good. I was mocked for it by some, but I used my engine hoist to separate and mate these two parts.
What are his options outside of sourcing a used unit? You can try magic bonding agents but............
Dave
Ghia
Vanagon
Beetle
jkidd152
jkidd152 is offline
PostPosted: Sat Oct 12, 2019 5:08 pm    Post subject: Re: Automatic Transmission nightmare Reply with quote
Repair in progress
VWagabond
VWagabond is offline
PostPosted: Sat Oct 12, 2019 7:35 pm    Post subject: Re: Automatic Transmission nightmare Reply with quote
Hope it works....Hey? what-a you got to lose? It's dead already. Good luck, love to hear the results down the road.
The Road Goes Ever On & OnÖÖ...
VWagabond
87 Camper GL
87 Syncro GL
Butcher
Butcher is offline
PostPosted: Sat Oct 12, 2019 7:57 pm    Post subject: Re: Automatic Transmission nightmare Reply with quote
That's no repair. That is butchery and I know a bit about that.
[email protected]
Samba Peckerhead
PostPosted: Sat Oct 12, 2019 9:04 pm    Post subject: Re: Automatic Transmission nightmare Reply with quote
X2. that's used car dealer "run it thru the auction" bullshit right there. it may hold for a minute or 2 but I wouldn't go out of walking distance with a 'repair' like that
gprudenciop wrote:
[email protected] wrote:
Jake Raby wrote:
Brian wrote:
jimf909 Premium Member
jimf909 is offline
PostPosted: Sat Oct 12, 2019 10:07 pm    Post subject: Re: Automatic Transmission nightmare Reply with quote
Iíve seen JB weld hold parts together for 30 years and counting. In some cases (no pun intended) thereís no chance it will work, in others, itís an entirely reasonable option. This appears that it may be the latter.
If youíre a pro and banking your reputation on the result using JBweld would be dumb. If youíre fixing your own van and understand the consequences it may be a risk worth taking.
Looking forward to hearing the outcome.
Abscate wrote:
Current: 1990 Westy Camper - Bostig RG4, 2wd, manual trans w/Peloquin, NAHT high-top, Flash Silver, seam rust, bondo, etc., etc.
Wildthings
Wildthings is offline
PostPosted: Sat Oct 12, 2019 10:55 pm    Post subject: Re: Automatic Transmission nightmare Reply with quote
I would have put a nice flat piece of metal under that board and then tightened the crap out of the C-clamp. Don't want the repair to be raise up at all compared to the rest of the surface.
ALIKA T3
ALIKA T3 is offline
PostPosted: Sat Oct 12, 2019 11:59 pm    Post subject: Re: Automatic Transmission nightmare Reply with quote
Grease the square o`ring well when assembling, as to not force on your repair and you might be fine. If thers`s room, make a reinforcement from the inside.
Or you could have it welded, ductile iron I believe it is. Not many people know how.
MarkWard
MarkWard is offline
PostPosted: Sun Oct 13, 2019 8:12 am    Post subject: Re: Automatic Transmission nightmare Reply with quote
I have a good used differential I could let go for a good price if it comes to that. Hope the repair works. Iíve seen JB weld perform small miracles.
1982 Vanagon Camper with ALH TDI.
In Car https://youtu.be/5hbfdUJR88Q
Sodo
Sodo is offline
PostPosted: Sun Oct 13, 2019 9:03 am    Post subject: Re: Automatic Transmission nightmare Reply with quote
Agreed a pro can't do that, but shadetree could be OK, as long as you're OK with taking it all apart again if it leaks.
Doing it then selling right away it is not real nice, but if it goes a few years and no leaks.....
Per AlikaT3 .... (and not seeing it in-person, I don't know the purpose of that gap...) carefully fit some steel supports across to the inside, that fill the gap completely and support the constant 0-ring pressure.
O-ring pressure is trying to break your JB-weld, it's a LOT of force across a couple inches of 0-ring.
Carefully JB-Weld the supports in-place too.
It's a risk but it could work.
'07 EJ25 with '12 longblock, (Peloquin TDB on the shelf), locker, transaxle oil cooler/filtration system. LiFePO
....KTMs, GasGas, and a Stumpjumper
Gear oil is like underwear (aesthetics, comfort, runtime, etc. 😉)
alaskadan
alaskadan is offline
PostPosted: Sun Oct 13, 2019 10:04 am    Post subject: Re: Automatic Transmission nightmare Reply with quote
Too late now, wouldn't brazing it in place have been a good choice here?
Sodo
Sodo is offline
PostPosted: Sun Oct 13, 2019 11:45 am    Post subject: Re: Automatic Transmission nightmare Reply with quote
I like brazing too.
That requires a skill, some brazing equipment, probably complete teardown.
I donít know anything about that housing or if complete teardown is a big deal.
I suppose it can be done later if the JB doesnít survive.
vwfreek61
vwfreek61 is offline
PostPosted: Sun Oct 13, 2019 12:34 pm    Post subject: Re: Automatic Transmission nightmare Reply with quote
That area isn't under any stress, it's just a sealing surface. So as long the JB weld is filed smooth, it should be fine.
Kenneth
1964 Bug with Saxomat
1976 VW/Harley Trike Autostick
1987 Vanagon Westy w/2.0 ABA
SyncroButter
SyncroButter is offline
PostPosted: Sun Oct 13, 2019 12:46 pm    Post subject: Re: Automatic Transmission nightmare Reply with quote
+1, I would worry less about whether the repair will hold (jb weld is pretty stout and the surfaces should have plenty of tooth) and more about how well the resulting seal surface is planed but seems like a decent shot at a long tern fix here. In any case, nothing to lose and assuming dropping an auto trans on a vanagon is as simple as dropping a standard trans then you're not gambling an insane amount of remove and replace time if it does fail.
Grant
In the stable: 1986 Syncro Westfalia/Bostig, 1989 Doka Tristar, 1974 Vespa Rally 200, 1973 Vespa Primavera 125, 1963 Solex 2200, 1938 Buick Special
Gone but not forgotten: 1989 Porsche 944, 1973 Standard Beetle
Wildthings
PostPosted: Sun Oct 13, 2019 3:36 pm    Post subject: Re: Automatic Transmission nightmare Reply with quote
Sodo wrote:
I like brazing too.
Soldering requires less heat and the job could probably be done with nothing more than a propane torch.
IdahoDoug
IdahoDoug is offline
PostPosted: Sun Oct 13, 2019 5:38 pm    Post subject: Re: Automatic Transmission nightmare Reply with quote
It will be fine. Thats not even mid-pack for the things this surprisingly high end epoxy can and will do. Just seal pressure here. Perfect fix though certainly not something a shop should do, as they get paid NOT to do this stuff. Carry on.
1987 2WD Wolfsburg Vanagon Weekender "Mango", two fully locked 80 Series LandCruisers. 2016 Subaru Outback boxer. 1990 Audi 90 Quattro 20V with rear locking differential. 1988 Mitsubishi Van w/ dual spinny seats, mid engine and solid axle.1990 burgundy parts Vanagon. 1984 Porsche 944, 1992 Lexus LS400, 1988 Toyota Supra 5 speed targa project in pieces, 2002 BMW 325iX
AndyBees
AndyBees is offline
PostPosted: Sun Oct 13, 2019 7:09 pm    Post subject: Re: Automatic Transmission nightmare Reply with quote
I agree......... should be fine!
'84 Vanagon Tin-top, ALH TDI. 1989 Tin-top
