zap26 Samba Member
Posted: Sat Oct 12, 2019 6:26 pm Post subject: 1971 Super Beetle Ignition Coil Hot |
I am putting together an old project that had some work done at a shop that wasn't the best, and is now defunct. But the wiring is a mess, I have most of the lights and accessories working but noticed my ignition coil was heating up. I havent run the car or motor yet just installed everything and seeing what works. Is the coil suppose to heat up when hooked up to a battery and I mean really hot almost too hot to touch. I only noticed it when swapping the plugs and oil that it was burning up. Also would love some advice for the best places to hook up an electronic fuel pump as I will be running that as well. Any help or insight is greatly appreciated |
VW_Jimbo Samba Member
Joined: May 22, 2016 Posts: 9967 Location: Huntington Beach, CA
Posted: Sat Oct 12, 2019 9:32 pm Post subject: Re: 1971 Super Beetle Ignition Coil Hot |
Yes, a coil will get hot and burn itself out if left energized for long, inactive durations.
If you run an electronic fuel pump, you need a safety circuit that cuts power to it, in an accident. Old rabbit relays do a good job. _________________ Jimbo
TDCTDI wrote: |
67rustavenger wrote: |
GFY's Xevin and VW_Jimbo! |
bnam Samba Member
Joined: July 02, 2006 Posts: 2936 Location: El Dorado Hills CA/ Bangalore, India
Posted: Sun Oct 13, 2019 1:04 am Post subject: Re: 1971 Super Beetle Ignition Coil Hot |
zap26 wrote: |
It will get hot if the ignition is in the ON position. If it is getting hot with the key in the OFF position, then something is wrong in your wiring. The coil should get switched power - switched by the ignition. _________________ 1971 1302LS Convertible (RHD) owned since '74
Click to view image
1952 Citroen TA 11BL |
Blue69Baja Samba Member
Joined: September 04, 2008 Posts: 1065 Location: Fair Oaks
Posted: Sun Oct 13, 2019 8:15 am Post subject: Re: 1971 Super Beetle Ignition Coil Hot |
bnam wrote: |
zap26 wrote: |
It will get hot if the ignition is in the ON position. If it is getting hot with the key in the OFF position, then something is wrong in your wiring. The coil should get switched power - switched by the ignition. |
Well the coil will only get hot when the points are closed.. Not good for the points either. Miss wire and you would not be able to turn the engine off.
Jim _________________ 69 Baja with a 1914...
72 Super 100% orig...W/ factory air... 56,000mi
Even the spare is original.. |
