torque wrench not enough for the job
airoldspeed
airoldspeed is offline
PostPosted: Fri Apr 10, 2020 2:02 pm    Post subject: torque wrench not enough for the job Reply with quote
I have one torque wrench, but it only marks until 200 NM. I need to change the flywheel oil seal, for what I check it is not enough.
I can't afford a torque wrench with that high of a rating and either donít have anyone that can borrow one.
It will be better to do the job right!? Or it can be torque to 200NM without any problem?
If not, there is anyway that I can use this 200NM torque wrench and be ok with that flywheel gland not?
(1300 F letter)
mukluk
mukluk is offline
PostPosted: Fri Apr 10, 2020 2:10 pm    Post subject: Re: torque wrench not enough for the job Reply with quote
You need 294 NM to torque the gland nut sufficiently, so your torque wrench only gets you there about two thirds of the way. Either borrow a torque wrench with enough capacity or use a breaker & cheater bar along with some math.
Zundfolge1432 Premium Member
Zundfolge1432 is offline
PostPosted: Fri Apr 10, 2020 2:29 pm    Post subject: Re: torque wrench not enough for the job Reply with quote
How about Chester with the big impact down at the truck stop? 😂
sjbartnik
sjbartnik is offline
PostPosted: Fri Apr 10, 2020 2:53 pm    Post subject: Re: torque wrench not enough for the job Reply with quote
Another option is the "torque meister" tool which is a 9x torque multiplier. By applying ~30 ft-lbs. of torque to the tool, the glad nut is nicely and easily torqued to spec.
1965 Volkswagen 1500 Variant S
2000 Kawasaki W650
car_cursed
car_cursed is offline
PostPosted: Fri Apr 10, 2020 3:23 pm    Post subject: Re: torque wrench not enough for the job Reply with quote
I second this, I put off buying torque meister, but very much worth the price.
But I also bought this. figured for $40 I can use it to double check.
https://www.amazon.com/gp/product/B01LX4NIFK/ref=ppx_yo_dt_b_search_asin_title?ie=UTF8&psc=1
Cusser
Cusser is offline
PostPosted: Fri Apr 10, 2020 3:30 pm    Post subject: Re: torque wrench not enough for the job Reply with quote
Free loaner torque wrench at O'Reilly goes to 250 ft lbs. I've borrowed it a few times.
1970 VW (owned since 1972) and 1971 VW Convertible (owned since 1976), second owner of each. The '71 now has the 1835 engine, swapped from the '70. Second owner of each. 1988 Mazda B2200 truck, 1998 Frontier, 2005 Yukon, 2004 Frontier King Cab. All manual transmission except for the Yukon. http://www.thesamba.com/vw/forum/album_page.php?pic_id=335294 http://www.thesamba.com/vw/forum/album_page.php?pic_id=335297
airoldspeed
PostPosted: Fri Apr 10, 2020 3:31 pm    Post subject: Re: torque wrench not enough for the job Reply with quote
I was wondering if anyone had used the "beam" type torque wrench, the one that have like a needle to point..? Can it be ok for the job?
mukluk
mukluk is offline
PostPosted: Fri Apr 10, 2020 3:36 pm    Post subject: Re: torque wrench not enough for the job Reply with quote
Yes, a beam style torque wrench is perfectly fine to use here provided it goes up to at least 294 NM / 217 ft lbs.
airoldspeed
PostPosted: Fri Apr 10, 2020 4:19 pm    Post subject: Re: torque wrench not enough for the job Reply with quote
Thank you!!
61SNRF
61SNRF is offline
PostPosted: Fri Apr 10, 2020 4:55 pm    Post subject: Re: torque wrench not enough for the job Reply with quote
For best accuracy your torque wrench should have a much higher capacity than 217. Ideally the wrench should have ~double the desired value. This is why a torque multiplier is a good value.
Whatever method you use be absolutely certain you get the nut properly tightened!
If the nut is not tight enough the flywheel can come loose causing major damage to the crankshaft and flywheel.
Replacement of these might be 10X more expensive than the correct tools will cost Wink
-Bruce
An ounce of prevention is worth a pound of cure.
modok
modok is offline
PostPosted: Sat Apr 11, 2020 2:05 pm    Post subject: Re: torque wrench not enough for the job Reply with quote
You don't need a torque wrench.
You know how much you weigh, torque is force times distance, make a cheater bar the right length.
Cusser
Cusser is offline
PostPosted: Sat Apr 11, 2020 3:11 pm    Post subject: Re: torque wrench not enough for the job Reply with quote
I'd still go with the loaner torque wrench.
ashman40
ashman40 is offline
PostPosted: Sat Apr 11, 2020 3:48 pm    Post subject: Re: torque wrench not enough for the job Reply with quote
modok is correct, you can tighten the gland nut using a cheater bar to extend/increase your leverage on the nut. Knowing how much weight you are applying at what distance to the nut you can calculate the applied torque. You also need a way to lock the flywheel in place. You don't need to apply ALL of your weight, but if you apply less than all you will need to measure how much less. Here a accurate bathroom scale will tell you how much of your weight is NOT being supported by the cheater bar.
But there are added risks when placing extensions on tools and applying a VERY large torque at a larger distance. It is easy to loose control of the situation and get hurt. Make sure the socket over the gland nut is supported so it doesn't slip off the nut while tightening.
AshMan40
Pruneman99
Pruneman99 is offline
PostPosted: Sat Apr 11, 2020 4:16 pm    Post subject: Re: torque wrench not enough for the job Reply with quote
Once you use the torque multiplier, you will never go back to long bars, slipping sockets, or tipping engines.
The first time I used mine, it freaked me out how easy and CONTROLLED getting the axle nuts and gland nut torqued to exactly what you want with a regular ol' 3/8 ratchet and two fingers.
Ever notice how every old axle nut is all damaged and rounded? That's from using a long bar and it slipping off.
Best VW tool I ever purchased.
mukluk
mukluk is offline
PostPosted: Sat Apr 11, 2020 5:34 pm    Post subject: Re: torque wrench not enough for the job Reply with quote
I very much agree that the Torquemeister or a variant thereof is the best tool for this job, but I figured since the OP stated they couldn't afford to buy the proper rated torque wrench here that it was quite unlikely they could afford to buy a torque multiplier tool either. So, suggestions as to go about things were based on what was likely they would come across versus the ideal, ie, make do with what you have. Wink
Pruneman99
PostPosted: Sat Apr 11, 2020 7:45 pm    Post subject: Re: torque wrench not enough for the job Reply with quote
Large torque wrenches can be quite expensive. The tool is less than 100 with the 12v and 6v gears. If that's still outta reach, just go back to the old long bar and some math. Just find a way to support the engine well and bolt the socket on firmly.
But if the op can swing it the multiplier was the best money I've spent. Highly recommend if you own a VW IMHO.
Glenn Premium Member
Mr. 010
Glenn is offline
PostPosted: Sat Apr 11, 2020 7:52 pm    Post subject: Re: torque wrench not enough for the job Reply with quote
VW made a tool specifically for the axle and gland nuts.
Glenn
Cast Iron and Aluminum distributors rebuilt since 2000.
Cusser
Cusser is offline
PostPosted: Sat Apr 11, 2020 8:50 pm    Post subject: Re: torque wrench not enough for the job Reply with quote
That's why I suggested the FREE LOANER tool.
mukluk
mukluk is offline
PostPosted: Sat Apr 11, 2020 8:52 pm    Post subject: Re: torque wrench not enough for the job Reply with quote
Based on the OP using metric units and their grammar being slightly odd, I'd say chances are good they don't live in the USA and likely don't have FLAPS with FREE LOANER programs. Wink
Cusser
Cusser is offline
PostPosted: Sun Apr 12, 2020 8:28 am    Post subject: Re: torque wrench not enough for the job Reply with quote
Good observation. I notice guy did not fill in his location, year of VW, engine type.
But since he's a newbie and it's Easter, I won't yell at him.
