Orangitang Samba Member
Posted: Sun Oct 13, 2019 8:53 am Post subject: Emergency Flasher short with switch knob in. |
Hello everyone.
I have a 71 super beetle. My turn signals have not been working since I got the car seven weeks ago. I have A new emergency flasher and it appears to be wired correctly according to what I have researched.
With the ignition key OFF I get nothing from the emergency flashers when I pull the knoB out.
With the ignition key ON and the emergency flasher knob pulled out only I get the indicator light on the dash. But as soon as I push the knob in it shorts the fuse.
Any ideas on why that would be?
I know that it’s shorting somewhere. But I would expect it to blow the fuse when I pull out on the switch knob rather than push in on the switch knob.
Thank you for any help! |
VW_Jimbo Samba Member
Joined: May 22, 2016 Posts: 9966 Location: Huntington Beach, CA
Posted: Sun Oct 13, 2019 11:08 am Post subject: Re: Emergency Flasher short with switch knob in. |
I had the same issues with a JBugs Hazard switch. Bought a used one made by VW. All good! _________________ Jimbo
TDCTDI wrote: |
67rustavenger wrote: |
GFY's Xevin and VW_Jimbo! |
gt1953 Samba Member
Posted: Sun Oct 13, 2019 1:52 pm Post subject: Re: Emergency Flasher short with switch knob in. |
The emergency flasher knob/shaft does have different lengths. I discovered that when my signals would not work. Had to source out the correct length for my 72 type 1. Found it at a swap meet. _________________ Volkswagen: We tune what we drive.
72 type 1
72 Squareback
ashman40 Samba Member
Joined: February 16, 2007 Posts: 15985 Location: North Florida, USA
Posted: Tue Oct 15, 2019 6:24 am Post subject: Re: Emergency Flasher short with switch knob in. |
Give this thread a read. It talks about a problem with a new E-Flasher switch blowing fuses. Sounds like you have a similar problem. In the below case it was a design problem with the aftermarket switch.
https://www.thesamba.com/vw/forum/viewtopic.php?p=9080004 _________________ AshMan40
