plotch Samba Member
Joined: December 22, 2004 Posts: 537 Location: jeffersonville, vermont
Posted: Sun Oct 13, 2019 4:33 pm Post subject: First the good news; clutch problem. |
The good news is that after 7 years 11 months i had it running and it left the garage under its own power. The bad news: Cannot adjust the clutch cable or it has no effect. 75 standard beetle and pedal cluster, double sided transmission with the 75 lever on the trans.
It would appear that there isn't enough travel to disengage the clutch. No slack either so it slips under power. I'm trying to use the older trans with the 4.1 ring and pinion because of the larger tires. 225/75-15.
Solution? Back to the 3.88 trans? Older pedal cluster? Thanks, guys. |
Dale M. Samba Member
Joined: April 12, 2006 Posts: 20365 Location: Just a tiny bit west of Yosemite Valley
Posted: Sun Oct 13, 2019 5:04 pm Post subject: Re: First the good news; clutch problem. |
"Travel" should not be a issue, changing clutch arm should not be issued as people have mixed and matched about every combination of arms and transaxle imagenable...
Real question is do you have correct clutch disk and pressure plate for through bearing and throwout forks style...
Also clutch cable could be wrong length, clutch tube could be loose in tunnel or problem with the hook at pedal assembly (worn)....
Its something other than just changing transaxle...
ekacpuc Samba Member
Joined: December 08, 2010 Posts: 1414 Location: ketchikan alaska
Posted: Sun Oct 13, 2019 10:33 pm Post subject: Re: First the good news; clutch problem. |
What makes you think the clutch is good?
Did you use a early throw out bearing on a late trans? You should see a collar poking out past the throw out bearing. |
dirtkeeper Samba Member
Joined: February 19, 2008 Posts: 3200 Location: Left of everywhere
Posted: Mon Oct 14, 2019 6:56 am Post subject: Re: First the good news; clutch problem. |
Are you saying the car has been sitting for 7years 11 months?
Clutch could just be rusted together |
calvinater Samba Member
Posted: Mon Oct 14, 2019 10:09 am Post subject: Re: First the good news; clutch problem. |
If you need a hand we are in montgomery. _________________ "Albatross"! |
plotch Samba Member
Posted: Mon Oct 14, 2019 3:55 pm Post subject: Re: First the good news; clutch problem. |
Thanks dudes.
Dirtkeeper; Car has been rebuilt. Not rusted.
Ekacpuc; Sorry but that's not it.
Dale M; There's a maybe to one of your points.
Calvinator; Thanks, i'll let you know.
Next rainy day problem solving. |
plotch Samba Member
Posted: Mon Oct 28, 2019 4:40 pm Post subject: Re: First the good news; clutch problem. |
Trying to exchange an AT transmission with an AH. All the peripherals are the same and the i checked the clutch. I really don't know what the issue is.
Moire to come in the next couple of days. |
Posted: Thu Oct 31, 2019 3:51 am Post subject: Re: First the good news; clutch problem. |
Make any headway? _________________ "Albatross"! |
dustymojave Samba Member
Posted: Sat Nov 02, 2019 6:33 pm Post subject: Re: First the good news; clutch problem. |
Where do we place our bets?
I'm sure it's an issue of early trans, throwout arm and bearing / late clutch pressure plate. _________________ Richard
SoCalBajas Member
plotch Samba Member
Posted: Sat Nov 02, 2019 6:34 pm Post subject: Re: First the good news; clutch problem. |
Wrong clutch lever parts came. While i'm there might as well replace the bushings. Manana i'll post a pic of the AT trans. Wrong parts on the left, old parts on the right,
