Oil bath air cleaner vs. Empi air filter?
Serpent7
Serpent7 is offline
PostPosted: Mon Oct 14, 2019 5:32 pm    Post subject: Oil bath air cleaner vs. Empi air filter? Reply with quote
I have a 73 Thing that did not run when purchased. I finally got it running the other day but purchased a Empi air filter only. I have only driven it a few feet and noticed oil now in my air filter and a little running down my carb and intake. Should I also purchase a oil bather? Will this solve my issue or are there other devil's at work here?
2019 Audi Q5
2014 Volkswagen Touareg X
1997 Honda Shadow
1979 Kawasaki KZ1000
1979 Volkswagen Transporter
1973 Volkswagen Thing
EDragnDean
EDragnDean is offline
PostPosted: Tue Oct 15, 2019 8:41 am    Post subject: Re: Oil bath air cleaner vs. Empi air filter? Reply with quote
Sounds like a different issue. Can you post pictures of your setup and the leak?
63 Double Cab http://www.thesamba.com/vw/forum/viewtopic.php?t=443823&highlight=deanos
66 Bus Click to view image - SOLD
73 Thing http://www.thesamba.com/vw/forum/viewtopic.php?p=8111202#8111202
70 BusClick to view image
BJT
BJT is offline
PostPosted: Tue Oct 15, 2019 2:21 pm    Post subject: Re: Oil bath air cleaner vs. Empi air filter? Reply with quote
Do you have an crankcase breather road draft tube or the breather tube connected to the air filter, or both setup?
andk5591
andk5591 is offline
PostPosted: Wed Oct 16, 2019 5:57 am    Post subject: Re: Oil bath air cleaner vs. Empi air filter? Reply with quote
If you have your oil breather connected to the air filter, which you probably do, then you may be getting excessive blow by through your breathing system. Its not unusual to see some oil in the bottom of a conventional filter over time, but if you are seeing a bit right away, you have other issues as mentioned.
D-Dubya Manx clone - 63 Short pan,1914.
There's more, but not keeping them...
74 Thing
74 Thing is offline
PostPosted: Wed Oct 16, 2019 6:48 am    Post subject: Re: Oil bath air cleaner vs. Empi air filter? Reply with quote
Post a photo of your engine compartment. Is it a stock engine?
