Digger89L Samba Member
Joined: May 16, 2013 Posts: 1130 Location: Western Canada (SK)
Posted: Wed Oct 16, 2019 2:04 pm Post subject: Details please about Neiman 77 steering wheel ignition / lock |
Picked up this Neiman 77 steering column ignition / lock in a box of spare parts a while ago. Its missing a few bits (mounting bolts, rubber bushings, etc) but I'd like to take a shot at installing it in my 66 Bug project. Can someone point me to some installation instructions for this model? Also, I don't have the key, so I'd like to get one made ...but there's no obvious way to get the lock cylinder out of the casing. Any hints??
_________________ "If you can't fix it with pop rivets, crazy glue and duct tape, or hold it together with zip ties, velcro or magnets, it REALLY is broken." |
sgmalt46 Samba Member
Joined: April 20, 2005 Posts: 1296 Location: south san francisco
Posted: Wed Oct 16, 2019 3:05 pm Post subject: Re: Details please about Neiman 77 steering wheel ignition / lock |
my 66 has that factory. some one lost the key at some
point and put a regular switch. I found out a bus lock
cylinder worked. part # 113 905 583 68-70 bug-bus
I believe if you take the electrical part out it comes
out easy. I forget how exactly . it's been years.
wolfburg west shows the lock cylinder but out
of stock.
Steve _________________ 55 deluxe 23 window bus
64 crew cab
55 rag top beetle
66 beetle
71 square back (sold) ! good luck with it Henry!
46 beetle 552nd royal army service corps CCG |
KTPhil Samba Member
Joined: April 06, 2006 Posts: 34018 Location: Conejo Valley, CA
Posted: Wed Oct 16, 2019 4:19 pm Post subject: Re: Details please about Neiman 77 steering wheel ignition / lock |
Special breakoff bolts are available.. search this forum and you will find them. |
Emeraldlion Samba Member
Joined: April 13, 2005 Posts: 743 Location: Texarkana, TX
Posted: Thu Oct 17, 2019 6:04 pm Post subject: Re: Details please about Neiman 77 steering wheel ignition / lock |
Do not lose the electrical part. I think this is the smaller of the 2 versions and is no longer available as replacement. Worth returning if you have it. |
Posted: Thu Oct 17, 2019 6:29 pm Post subject: Re: Details please about Neiman 77 steering wheel ignition / lock |
Emeraldlion wrote: |
Yeah ...the electrical (switch) part is still there, but the connector 'blades' are missing (I wonder if they are still available?) My challenge right now is how to get the lock barrel out: after removing the switch, I tried (lightly) pounding on the back end of the lock barrel ...no movement at all. Its made of 'pot metal' so have to be careful not to damage it. Other questions: does it require a special steering shaft, with a notch in it, for the 'bolt' from the lock to grab onto the steering shaft? Is it worth trying to retro-fit this unit onto a car that didn't have one originally ...or should I just try to sell it? (they seem to command quite a decent price here in the classifieds). Answers / comments welcome! _________________ "If you can't fix it with pop rivets, crazy glue and duct tape, or hold it together with zip ties, velcro or magnets, it REALLY is broken." |
Posted: Thu Oct 17, 2019 6:39 pm Post subject: Re: Details please about Neiman 77 steering wheel ignition / lock |
Sell. To retro fit it functionally you will also need the corresponding steering column. Otherwise you would have to grind the locking sprawl which essentially just makes it a unique ignition switch. |
