70vwbug Samba Member
Posted: Thu Oct 17, 2019 7:03 am Post subject: Water accumulation on Driver door |
Hi
I have water accumulating in the driver side door of my 70 Std Bug. How does the water drain? There are supposed to be holes at the bottom, but I donīt see any. Should I drill some holes? Where would the water drain?
Thanks |
andk5591 Samba Member
Joined: August 29, 2005 Posts: 16757 Location: State College, PA
Posted: Thu Oct 17, 2019 7:20 am Post subject: Re: Water accumulation on Driver door |
Clean the bottom real well...There should be 2 holes there. Partially covered by sheet metal. If no holes, then yeah drill a couple....at least 3/8" and make sure you have plastic on the inner door panel side _________________ D-Dubya Manx clone - 63 Short pan,1914.
KTPhil Samba Member
Joined: April 06, 2006 Posts: 33991 Location: Conejo Valley, CA
Posted: Thu Oct 17, 2019 8:58 am Post subject: Re: Water accumulation on Driver door |
The holes (sometimes more like slits than holes) are probably plugged with dirt, so a thorough cleaning is needed! |
Tim Donahoe Samba Member
Joined: December 08, 2012 Posts: 11740 Location: Redding, CA
Posted: Thu Oct 17, 2019 10:07 am Post subject: Re: Water accumulation on Driver door |
I had two holes at the bottom of the passenger door, and one had a chunk of glass in it (where the window had been shattered at some point, I assume); the other hole was partially blocked by a fold of original metal from the factory. I drilled out the second hole to make it as large as the first, and vacuumed the glass chunks that blocked the first hole.
Tim _________________ Let's do the Time Warp again!
Richard O'Brien |
unclewede Samba Member
Posted: Thu Oct 17, 2019 11:04 am Post subject: Re: Water accumulation on Driver door |
This is NOT unique to the ACVW world. My dad's new wife was driving around and had sloshing every time she changed speeds. Took a pipe cleaner to the 2 drain holes on her Ford, and the gunk that came poring out once I cleared the mud was rancid. For some reason she thought I was amiracle worker |
