txasylum Samba Member
Joined: December 15, 2004 Posts: 389 Location: Boyers, PA
Posted: Thu Oct 17, 2019 4:46 pm Post subject: Engine Rebuild / Piston Question |
I'm rebuilding my motor and am in the process of putting it back together. I have a question.
1. The manual says the pistons can go on any of the rods, but the arrow must point toward the flywheel. My pistons do not have an arrow, but the are stamped "STD" and the other side has a cut in it. See the picture. All four are in the same position. Does it matter how they are installed in reference to the flywheel?
I bought a new set of standard 1600 jugs/pistons. They have been sitting awhile, so the oil in the pistons were a bit sticky. I had to clean them all with a solvent. In doing so, I broke a #2 compression ring on one piston. Now I have to order a new set of rings for these new pistons. Dang it.
THanks
Bob
bomberbob Samba Member
Posted: Fri Oct 18, 2019 4:19 am Post subject: Re: Engine Rebuild / Piston Question |
Your straight on photo doesn't show the dimple in relation to the wrist pin. Use the dimple as a substitute for the arrow. Sorry about the broken ring, it happens to the best of us. _________________ 1968 Beetle (storage)
1990 Jetta GLI megasquirted, burning E85 (currently in heavy maintenance)
2004 Jetta turbo GLI
Marion, Iowa |
viiking Samba Member
Joined: May 10, 2013 Posts: 2667 Location: Sydney Australia
Posted: Fri Oct 18, 2019 9:46 pm Post subject: Re: Engine Rebuild / Piston Question |
Ask on here. I’m sure there’s plenty of folk who have a spare from the set they broke. I’d send you one but I’m ten thousand km away. I’m sure there’d be someone on samba close to you that has one for a few bucks or a six pack. _________________ 1968 1500 RHD Lotus White Beetle since birth. In the hospital for major surgery
Discharged: 1983 Vanagon, 1974 1800 Microbus,1968 Low Light,1968 Type 3 |
Posted: Fri Oct 18, 2019 9:48 pm Post subject: Re: Engine Rebuild / Piston Question |
I also remember seeing but not where someone selling just piston rings for one piston. _________________ 1968 1500 RHD Lotus White Beetle since birth. In the hospital for major surgery
Posted: Sat Oct 19, 2019 5:57 am Post subject: Re: Engine Rebuild / Piston Question |
I ordered a whole set so I will be one of those guys that will have extra in case anyone needs one. Lol
viiking wrote: |
I also remember seeing but not where someone selling just piston rings for one piston. |
