Kizbo Samba Member
Posted: Fri Oct 18, 2019 9:20 am Post subject: Swing Axle Differential Flex Question |
Just a quick question related to the strength, or lack thereof of the stock diff vs superdiff. I'm aware that having the extra spider gears in the superdiff is sort of the advantage one gets from that product, but I often read in vendor/manf. descriptions about them being made from better metal castings and help eliminate the "flex" of the stock differential.
Could someone help explain where this "flexing" is taking place? Is it flex in the diff housing or flex in the ring gear flange? Thanks. |
Scott SD Samba Member
Joined: June 22, 2010 Posts: 153 Location: San Diego, CA
Posted: Fri Oct 18, 2019 1:19 pm Post subject: Re: Swing Axle Differential Flex Question |
The diff carrier flexes at the ring gear flange. There is flex when there is a large load from the pinion. Mendeolas have a brass plug on the backside just for this reason. All of the swing super diffs that I have seen are not very good, except for the old Crown diffs. German metallurgy was really good. If you install a swing super diff be sure to use the 10 tooth spiders and side gears.
I used a swing super diff for years in my ‘67. It ran 11.70s at 122 mph and had 100s of passes on slicks. |
Kizbo Samba Member
Posted: Mon Oct 21, 2019 6:25 am Post subject: Re: Swing Axle Differential Flex Question |
Scott SD wrote: |
Thanks for clarifying that! I would've thought the housing was more prone to give than the flange & ring gear combo. That's good to know. Thanks again. |
