jbhurley92 Samba Member
Posted: Sun Oct 20, 2019 10:00 am Post subject: 85 Vanagon running on 3 cylinders |
Last night the vanagon just died on me lost all power wouldn't stay cranked like it was starving for fuel if you gave it gas it just died.
Towed it home swapped all plugs, rotor cap, distributor cap, spark plugs and it's running better with a definite dead cylinder. What could be the cause time for a new head? |
djkeev Samba Moderator
Joined: September 30, 2007 Posts: 32632 Location: Reading Pennsylvania
Phaedrus Samba Member
Joined: January 06, 2014 Posts: 500 Location: Washington
Posted: Sun Oct 20, 2019 11:27 am Post subject: Re: 85 vanagon running on 3 cylinders |
"Cranking" is when the starter is turning the engine over before the engine fires up. "Wouldn't stay running" would indicate you've got a running issue. "Wouldn't crank" would indicate you have an ignition or starting issue.
Verify you have solid spark at the cyl that's not firing. You can do this by using a spare known good plug and plugging it into the wire that goes to whichever cyl. Ground it against the case while you crank the motor.
If spark is good, like dj said, check your compression, then if comp is good, test injector.
You don't need a new head until you need a new head. One step at a time. _________________ 1986 WBX (Tin Top Camper) |
Ahwahnee Samba Member
Joined: June 05, 2010 Posts: 9810 Location: Mt Lemmon, AZ
Posted: Sun Oct 20, 2019 1:22 pm Post subject: Re: 85 vanagon running on 3 cylinders |
jbhurley92 wrote: |
... it's running better with a definite dead cylinder... |
How did you determine that one cylinder is 'dead'? |
Posted: Sun Oct 20, 2019 1:48 pm Post subject: Re: 85 vanagon running on 3 cylinders |
Spark is good to all, verified one is dead by pulling wires one at a time and after one was pulled nothing changed, swapped wires for it and still that cylinder is dead and not firing. |
Howesight Samba Member
Joined: July 02, 2008 Posts: 3274 Location: Vancouver, B.C.
Posted: Sun Oct 20, 2019 2:01 pm Post subject: Re: 85 vanagon running on 3 cylinders |
I hate to be a stickler, but if people are asking for free assistance from our helpful forum posters (which many people here on the Samba, myself included, are am happy to provide), then those asked to help should not have to de-code the question first before giving their assistance.
Here is what the OP wrote:
"Last night the vanagon just died on me lost all power wouldn't stay cranked like it was starving for fuel if you gave it gas it just died.
Towed it home swapped all plugs, rotor cap, distributor cap, spark plugs"
Here is what I think the OP meant:
"Last night my vanagon just stopped running. The engine lost all power. When re-starting, it wouldn't stay running. When I tried to re-start it, it ran briefly like it was starving for fuel. When idling, and then pressing on the accelerator, it just died.
I got it towed it home and replaced rotor, distributor cap, spark plugs. This did not help. What is wrong with my Vanagon?"
Frankly, I don't know what to do about a Vanagon that "wouldn't stay cranked". For a Meth addict that "wouldn't stay cranked", I would say, it's time for rehab, but for a Vanagon, I don't know.
Sign me, "Happy to help, but not a code-breaker". _________________ '86 Syncro Westy SVX |
Posted: Sun Oct 20, 2019 2:05 pm Post subject: Re: 85 vanagon running on 3 cylinders |
Howesight wrote: |
Sign me, "Happy to help, but not a code-breaker". |
Indeed you are correct thank you for your time decoding, I won't let it happen again lol. Was a tad drunk when I typed this out on the phone. |
Posted: Sun Oct 20, 2019 3:34 pm Post subject: Re: 85 vanagon running on 3 cylinders |
djkeev wrote: |
You've confirmed a healthy spark at all four cylinders?
If yes, pull the spark plugs and do a simple compression test, see what that says.........
If spark is good and compression is good, move on to the injectors........
Dave |
Sadly I don't have a compressor I think my girlfriend's neighbor is bringing one, at least ol beluga made it on a 6 day road trip before leaving us stranded after a date last night!
I'm leaning towards injectors but my neighbor said could be the valves. |
0to60in6min Samba Member
Joined: November 27, 2006 Posts: 3417 Location: OR & CA (Oregon/California)
Posted: Sun Oct 20, 2019 3:51 pm Post subject: Re: 85 vanagon running on 3 cylinders |
Quote: |
Sadly I don't have a compressor |
are you sure that you need a compressor to do a compression test? |
Posted: Sun Oct 20, 2019 4:59 pm Post subject: Re: 85 vanagon running on 3 cylinders |
0to60in6min wrote: |
Mistakes were made indeed, but he's bringing the stuff tomorrow hopefully. |
Abscate Samba Member
Posted: Sun Oct 20, 2019 6:11 pm Post subject: Re: 85 vanagon running on 3 cylinders |
This is like watching kale smolder and wondering what the funny smell is. _________________ .ssS! |
Posted: Sun Oct 20, 2019 6:24 pm Post subject: Re: 85 vanagon running on 3 cylinders |
Abscate wrote: |
This is like watching kale smolder and wondering what the funny smell is. |
Lol I know I messed up and combined two things into one I was going to use the compressor for checking for other things my fault. |
Posted: Mon Oct 21, 2019 4:35 am Post subject: Re: 85 vanagon running on 3 cylinders |
jbhurley92 wrote: |
Abscate wrote: |
Sorry about my snark. Hope it is something minor in that cylinder ,but if not, we are here for you on the first engine drop! _________________ .ssS! |
MarkWard Samba Member
Joined: February 09, 2005 Posts: 17155 Location: Retired South Florida
Posted: Mon Oct 21, 2019 6:14 am Post subject: Re: 85 vanagon running on 3 cylinders |
Another easy test is to swap the injector harness plugs. See if the miss moves. _________________ ☮️ |
Posted: Mon Oct 21, 2019 4:05 pm Post subject: Re: 85 vanagon running on 3 cylinders |
djkeev wrote: |
No worries, you were probably thinking of a cylinder leak down test which does use compressed air.
Dave |
Did a compression test and the cylinder showed no compression and the others showed 110. |
Posted: Mon Oct 21, 2019 4:39 pm Post subject: Re: 85 vanagon running on 3 cylinders |
jbhurley92 wrote: |
djkeev wrote: |
Dave |
Pull the rocker cover and see what there is to see. You can also pull the rocker arms and see if the valve stem heights are all the same. |
Posted: Mon Oct 21, 2019 4:46 pm Post subject: Re: 85 vanagon running on 3 cylinders |
jbhurley92 wrote: |
djkeev wrote: |
Dave |
Well, the good news is that you know why you have a miss, now..... why do you have zero compression?
I don't know what your abilities are to go farther?
An easy test is to get that cylinder (which one is it?) at firing TDC (top dead center) and pressurize the cylinder with compressed air.
You then listen/feel for air in any of three places......
Out of the oil fill cap = rings = upper end rebuild
Out of the exhaust = exhaust valve burnt or hanging open = simple valve job
Out of the intake (remove Air Flow Meter) = bad / hung up intake valve = simple valve job.
You pressurize the cylinder using a hose screwed into the spark plug hole, this hose might be the obe you probably used to check the compression.
Instead of connecting the gauge, you plug in compressed air.
This is a simplified explanation but hopefully you get the idea.......
Ghia
Vanagon
Beetle
Posted: Mon Oct 21, 2019 4:50 pm Post subject: Re: 85 Vanagon running on 3 cylinders |
Yeah, that's why I was trying to find a compressor since I know my luck lol. At least she made it through the trip before she died on us, I'm already tempted to snatch this motor out and rebuild it completely at this point, let's hope for a valve job probably just going to go ahead and yank the heads off and see if it's a valve. |
