VW_Jimbo Samba Member
Joined: May 22, 2016 Posts: 9966 Location: Huntington Beach, CA
Posted: Mon Mar 16, 2020 9:29 am Post subject: Re: Field find 1954 Canadian custom |
Good stuff! Looking good. Really jealous of that door fit. That’s what I get to deal with, AFTER repining that door hinge. Heads up! I really thought I had done a good job lining up the door. But I was off about 3/64 at the gap in the door hinge. Worked out to be almost a full 1/16 at the top of the door. Damn it!
All that to say...I would get the hinge pinned before going much further. Just my 2 cents, based on Saturday’s adventure! _________________ Jimbo
TDCTDI wrote: |
67rustavenger wrote: |
GFY's Xevin and VW_Jimbo! |
sunroof Samba Member
Joined: October 06, 2006 Posts: 1774 Location: Winnipeg
Posted: Mon Mar 16, 2020 1:13 pm Post subject: Re: Field find 1954 Canadian custom |
When I first fit up the door it wouldn't even close, the lower hinge was too low! Dammit. I spent many hours fitting and adjusting to get it right but I got it finally. That was discouraging to say the least. Keep at it, it will be worth it.
Don _________________ Better and better mistakes! |
tomsbuggered Samba Member
Joined: October 16, 2014 Posts: 417 Location: Calgary, AB Canada
Posted: Tue Mar 17, 2020 9:28 am Post subject: Re: Field find 1954 Canadian custom |
sunroof wrote: |
Don |
I have tacked the passenger side A pillar in place and am now trying to get the gap better. The upper hinge is still partly seized, so I'm hoping that is part of the reason the door seems to bind a bit.
Going to go out to the shop later and stare at it for a while and take some measurements.
Tom _________________ June 1956 VW Oval Beetle |
Posted: Tue Mar 17, 2020 8:34 pm Post subject: Re: Field find 1954 Canadian custom |
After weeks of grinding, cutting, shaping, welding, fitting, grinding, cutting, shaping, welding I am finally satisfied with the fit of this panel and started welding tonight.
Posted: Wed Mar 18, 2020 8:36 am Post subject: Re: Field find 1954 Canadian custom |
Wow major progress Don!
I am still aligning A pillars, a slow task.
Posted: Thu Mar 19, 2020 6:15 am Post subject: Re: Field find 1954 Canadian custom |
Things can go fast if you go slow enough to get it right the first time!
Aligning the A pillar was a long frustrating task. I hope the other side goes quicker!
Posted: Thu Mar 19, 2020 7:49 pm Post subject: Re: Field find 1954 Canadian custom |
In spite of how much shaping of the repair panel was required, it really came together in the end. I was hitting it with the hammer right up to the final weld.
The arch over the tortion bar end was way out of whack but a weld and a few blows and another weld and a few more blows etc brought it slowly in line finally.
Posted: Thu Mar 19, 2020 11:38 pm Post subject: Re: Field find 1954 Canadian custom |
Looks really nice! _________________ Jimbo
TDCTDI wrote: |
Posted: Fri Mar 20, 2020 6:12 am Post subject: Re: Field find 1954 Canadian custom |
The long weld is a little ripply, that is to say it has some ripples in it not that it is somehow like Ripley, but Hammer and Dolly took care of that! To finish the job now the body has to come off the chassis. Previously on '54 Field Find several friends would come over and help lift the car around. Having a Corona has taken on a new meaning I must say!
Posted: Fri Mar 20, 2020 8:32 am Post subject: Re: Field find 1954 Canadian custom |
They cannot all be perfect. But they must be sound. So long as you have strength, I would not worry about it. That spot is not a focal point, to the public. I am certain you will always zoom in on it! Well, at least that is what I would do.
I was scrolling through your pictures and noticed only half of the rear heater channel was welded. Is there something missing?
And here is one of my photos which shows the whole channel in contact with the rear cross member.
TDCTDI wrote: |
Posted: Fri Mar 20, 2020 9:22 am Post subject: Re: Field find 1954 Canadian custom |
I'm pretty sure I got it right but good catch:
When I cut apart the other side we will see for sure.
Posted: Fri Mar 20, 2020 9:23 am Post subject: Re: Field find 1954 Canadian custom |
sunroof wrote: |
Don |
It is a difficult enough task as is ,trying to move the body by yourself without having the current challenges imposed on us. Wish I were closer to be able to help, Hopefully someday I will get to see your project Don. _________________ June 1956 VW Oval Beetle |
Chickensoup Samba Member
Joined: January 06, 2018 Posts: 5368 Location: Good Hope, GA
Posted: Fri Mar 20, 2020 10:07 am Post subject: Re: Field find 1954 Canadian custom |
tomsbuggered wrote: |
sunroof wrote: |
Don |
It is a difficult enough task as is ,trying to move the body by yourself without having the current challenges imposed on us. Wish I were closer to be able to help, Hopefully someday I will get to see your project Don. |
I know how that feels... its really not that bad, just dont drop the body. It is best to work your way from front to rear repeatedly and wiggle her off. Be ready to have some tires or one thing to place the body on.
EDIT- oh, and you will have to remove the shifter and heater cable knobs as they will not clear the heater channel. It will also be easier if you remove the wheels. |
Posted: Fri Mar 20, 2020 10:55 am Post subject: Re: Field find 1954 Canadian custom |
Quote: |
I was scrolling through your pictures and noticed only half of the rear heater channel was welded. Is there something missing? |
I see it now, you're doing a '56 and I'm doing a '54. Sometime in late '55 they changed the shape of that whole part of the body. Numerous small changes were made that meant it all fits together very differently. I'm getting confused between you and VW_Jimbo who is also doing a '54.
virtanen Samba Member
Joined: January 08, 2006 Posts: 1462 Location: Finland
Posted: Fri Mar 20, 2020 11:26 am Post subject: Re: Field find 1954 Canadian custom |
It looks like there is a little extension on the rear end of the heater channel to fit into the little trapezoid. I must have missed that when I took it apart. I should be able to add it easily enough. Thanks guys for the heads up on this.
None of the Klassicfab heater channels show this detail:
Looks like Virtanen was all over this already!
Here we see how it all goes together.
Thanks again tomsbuggered and Virtanen, I would have totally missed this.
Now I'm starting to wonder if a lot of my problems are because I'm mixing Klassicfab with Virtanen and Autocraft. On the left side I will try to stick to Virtanen for all my repair panels and see how things fit.
Virtanen! I'm going to need this for the drivers side:
Posted: Fri Mar 20, 2020 10:08 pm Post subject: Re: Field find 1954 Canadian custom |
That fits acceptably well I think>
Filling this big ugly hole will be my next project
And then finally this hole.
Posted: Sat Mar 21, 2020 6:11 am Post subject: Re: Field find 1954 Canadian custom |
Excellent, I will do that.
Posted: Sat Mar 21, 2020 12:47 pm Post subject: Re: Field find 1954 Canadian custom |
Regarding that rear heater channel opening. Maybe weld an L shaped piece up against the rear wall of the hole. Then cut the mounting flange of the channel still left on the drivers side. Drill a couple holes through it for plug welds. Then hammer it down on top of that L piece, previously welded into place, and weld it together! _________________ Jimbo
TDCTDI wrote: |
