sunroof Samba Member
Joined: October 06, 2006 Posts: 1774 Location: Winnipeg
Posted: Mon Feb 15, 2021 6:29 am Post subject: Re: Field find 1954 Canadian custom |
I got the last of the repair bits welded in last night. I warped this one a little because the old metal kept evaporating when I pulled the trigger. I was as careful as I could be but I just kept having to fill holes. A little discouraging but it is done. If I had longer arms I could do some hammer and dolly to straighten it out bit it will have to do.
I am also taking off the grey primer and replacing it with the copper only because I like the look of the copper better.
Finally I am going to tackle this mess. Lots to say about the A pillar and Virtanen's repair piece.
Don _________________ Better and better mistakes! |
grailoc Samba Member
Joined: March 25, 2004 Posts: 1441 Location: FRANCE and now QUEBEC city
Posted: Sun Feb 21, 2021 6:56 pm Post subject: Re: Field find 1954 Canadian custom |
Spent a couple more hours tonight cutting away the cancer. I can see the finish line from here.
I am only using a little of this very expensive piece so I will be selling whatever is left.
I think this would be an auspicious moment to weld this in:
And then while I'm doing that I need to fill in these 2 little bits.
There is still this problem to deal with, the repair piece overhangs the heater channel by a bit. It is fairly obvious it is a problem with the shape of the heater channel, this did not happen on the other side and the firewall piece went in very nicely.
Busstom Samba Member
Joined: November 23, 2014 Posts: 3851 Location: San Jose, CA
Posted: Sun Feb 21, 2021 11:29 pm Post subject: Re: Field find 1954 Canadian custom |
If I'm not mistaken, you have a $1,300 Wolf quarter panel, of which you only need that lower-rear quadrant. I've been pondering the same purchase, and I too only need partial, but I need the entire fender-mounting arc, and it looks like you'll be using the rear-most section with two or three fender-attach nuts, correct? |
Posted: Wed Feb 24, 2021 10:15 pm Post subject: Re: Field find 1954 Canadian custom |
What do you call 100 lawyers floating in the bay? A good start.
This is my own good start.
Trimming, trimming, trimming
VW_Jimbo Samba Member
Joined: May 22, 2016 Posts: 9966 Location: Huntington Beach, CA
Posted: Wed Feb 24, 2021 11:40 pm Post subject: Re: Field find 1954 Canadian custom |
A GREAT start! Good is an understatement!
Panel fitting is such tedious, time consuming work. Keep at it, you are almost there! _________________ Jimbo
TDCTDI wrote: |
67rustavenger wrote: |
GFY's Xevin and VW_Jimbo! |
Posted: Wed Feb 24, 2021 11:44 pm Post subject: Re: Field find 1954 Canadian custom |
Is it an illusion or does that 52-60 wheel well have a narrower fender-flange mounting surface than the later panel it's mating to? |
Posted: Sun Feb 28, 2021 6:36 am Post subject: Re: Field find 1954 Canadian custom |
It is an illusion, the '52 - '60 panel is fitting up to a '54 so everything is right as rain.
Speaking of which:
It is coming together nicely I must say.
I have to figure out what to do about this little bit:
This is what I love about Wolfparts, the fit is amazing every time, I mean look at the way that lines up, could not be better if it was NOS.
Posted: Sun Feb 28, 2021 10:25 am Post subject: Re: Field find 1954 Canadian custom |
Yep, that's a beauty.
Perhaps you can lift open a 1/2 inch or so of the original pillar fold and slip the Wolf flange upwards and under, close 'er up, then weld and grind accordingly to conceal the intersection |
Posted: Sun Feb 28, 2021 10:31 am Post subject: Re: Field find 1954 Canadian custom |
I dunno, I still have to cut the inner lip somehow.
Posted: Sun Feb 28, 2021 5:23 pm Post subject: Re: Field find 1954 Canadian custom |
Don, Jeremy in the late forum went through this. He made a tool for opening up the folded seam. Page 25, half way down.
https://www.thesamba.com/vw/forum/viewtopic.php?t=...;start=480 _________________ Jimbo
TDCTDI wrote: |
Posted: Sun Feb 28, 2021 9:06 pm Post subject: Re: Field find 1954 Canadian custom |
Spent a couple of minutes in the garage tonight and figured out what to do about the pinch seam. Thank you to Busstom for the idea.
I opened up the pinch seam a couple of inches and got my Dremel tool in there and managed to just cut the inner flange and some of the old panel away. This really clears the way for the Big Cut.
Before I do that I'm going to have to make a trip to Pricess Auto and buy another clamp like this one. It has many shortcomings but really shines in this application.
BTW Along with the many hours I am going to have to spend reshaping the Virtanen part to make it fit I will also have to trim the pinch flange. As you may be able to see from the picture it is about 1/3 too wide and will not fold properly.
Posted: Sun Feb 28, 2021 10:06 pm Post subject: Re: Field find 1954 Canadian custom |
Excellent. Dremels are great for getting down to surgical work. I'm sure it will all be invisible when you're all done. |
Posted: Sat Mar 06, 2021 6:31 am Post subject: Re: Field find 1954 Canadian custom |
A couple more hours trimming and adjusting.
There will need to be a little persuasion at this flange to get things tight.
tomsbuggered Samba Member
Joined: October 16, 2014 Posts: 417 Location: Calgary, AB Canada
Posted: Sat Mar 06, 2021 9:38 am Post subject: Re: Field find 1954 Canadian custom |
That is looking really close Don. I think your skill level has improved with every repair. You are exercising good patience; sometimes the best thing to do is back away and evaluate things.
You have had a good run this winter. I hope to get back on bodywork this Spring. _________________ June 1956 VW Oval Beetle |
Posted: Sat Mar 06, 2021 11:11 am Post subject: Re: Field find 1954 Canadian custom |
Nice! That looks like a great fit. Does the speedo hole still align?
Very cool! _________________ Jimbo
TDCTDI wrote: |
Posted: Sat Mar 06, 2021 6:11 pm Post subject: Re: Field find 1954 Canadian custom |
So that is it for fitting up. Probably 7 to 8 hours to get this panel fitted. And that with out any rework to get it to fit the car, just trimming.
VW_Jimbo asked if the speedo hole aligns. Very close and I think it will be closer once the panel is welded in place.
Not to get boring on the subject but...
This is how Wolfparts fit:
Next and final is the Virtanen piece. This will be many many hours to make it fit a Volkswagen beetle.
Posted: Sun Mar 07, 2021 9:17 pm Post subject: Re: Field find 1954 Canadian custom |
Holes punched, primer on:
Posted: Tue Mar 09, 2021 11:07 pm Post subject: Re: Field find 1954 Canadian custom |
OK, that went well.
A little bit of stretching needed here and there, no biggie.
Posted: Wed Mar 10, 2021 12:43 am Post subject: Re: Field find 1954 Canadian custom |
That looks great! Nice job! _________________ Jimbo
TDCTDI wrote: |
