sunroof Samba Member
Joined: October 06, 2006 Posts: 1772 Location: Winnipeg
Posted: Sat Jun 18, 2022 2:50 pm Post subject: Re: Field find 1954 Canadian custom |
Maiden voyage:
https://www.youtube.com/watch?v=K3h1SHtQylE
https://www.youtube.com/watch?v=PgGZQ0TYg6Q
There are a few problems to deal with. The biggest is that it won't idle at all. I will swap out the carb for a known good one and see if that solves the problem. Also the steering is very stiff. I will back off the adjuster on the steering box and see if that helps. Other than that it goes down the road very nicely, straight and true and the brakes work as well as they can. All the electrical work EXCEPT! the light on the speedo for the semaphores doesn't come on. I will have to talk to Matt about that. Other than these few things it is beautifully solid and looks fantastic.
Don _________________ Better and better mistakes! |
Posted: Sat Jun 18, 2022 3:02 pm Post subject: Re: Field find 1954 Canadian custom |
grailoc Samba Member
Joined: March 25, 2004 Posts: 1441 Location: FRANCE and now QUEBEC city
Posted: Sat Jun 18, 2022 5:40 pm Post subject: Re: Field find 1954 Canadian custom |
I am having carb issues. One won't idle and now the second one is pouring gas out the throttle. Darn.
67rustavenger Samba Member
Joined: February 24, 2015 Posts: 9756 Location: Oregon
Posted: Sat Jun 18, 2022 6:31 pm Post subject: Re: Field find 1954 Canadian custom |
It's just a carb issue Don. You'll get it sorted soon and be cruising down the hiway.
The car looks great on the road.
In the second video. I thought I heard a tire rub or something like that. It was when you turned left into the gravel driveway.
Give it a listen. Maybe my old ears are fooling me! _________________ I have learned over the years.
Buy Once, Cry Once!
GFY's Xevin and VW_Jimbo! |
Posted: Sat Jun 18, 2022 7:39 pm Post subject: Re: Field find 1954 Canadian custom |
No, you heard it. I have to pull the right rear brake drum, there is something rubbing in there.
Rome Samba Member
Joined: June 02, 2004 Posts: 9641 Location: Pearl River, NY
Posted: Sat Jun 18, 2022 7:47 pm Post subject: Re: Field find 1954 Canadian custom |
Give it a listen. |
I hear it also; like brake shoes making incomplete contact with the drum or an unevenly machined drum. sunroof- did you notice any mild pulsations in the brake pedal during slowdown?
Excellent work on the '54's revival! |
Posted: Sat Jun 18, 2022 10:42 pm Post subject: Re: Field find 1954 Canadian custom |
Well OK the carb issue is fixed but now it turns out the hi/lo bean switch is flakey. When I step on the clutch the headlights go out. This will be important to fix.
Posted: Sun Jun 19, 2022 12:13 pm Post subject: Re: Field find 1954 Canadian custom |
Two things: It took 3 tries to get a hi/lo beam switch that works. I'm sure glad I saved that stuff.
Secondly:
The drums are new, the shoes are new, the hardware is new, the wheel cylinder is new so at this point I have to pull the drum and hope the noise is something simple.
On another note; last night it started leaking prodigious amount of oil. I can't see where it is coming from but I think this will be the last of the sorting out. Fingers crossed.
Posted: Sun Jun 19, 2022 6:42 pm Post subject: Re: Field find 1954 Canadian custom |
What a difference a couple of months can make.
February:
June:
Anyways I took the right rear drum off where the sound was coming from und alle ist korrect.
Posted: Tue Jun 21, 2022 4:13 pm Post subject: Re: Field find 1954 Canadian custom |
If you look at the right side of the backing plate you can see the lip is slightly bent. It was rubbing making the noise. two seconds with the pry tool and it is quiet.
VW_Jimbo Samba Member
Joined: May 22, 2016 Posts: 9955 Location: Huntington Beach, CA
Posted: Tue Jun 21, 2022 4:31 pm Post subject: Re: Field find 1954 Canadian custom |
sunroof wrote: |
Don |
Exactly what I was going to write. But your next response covered it!
Glad you got it sorted! _________________ Jimbo
TDCTDI wrote: |
67rustavenger wrote: |
Posted: Thu Jun 23, 2022 9:33 am Post subject: Re: Field find 1954 Canadian custom |
From the 1 step forward three steps backward department.
I am going to have to pull the engine and start over from scratch. It is pouring oil out the 3-4 push rod tubes despite my best efforts to seal them.
Also it is making a noise I have never heard a 36er make in 43 years of building them.
https://www.youtube.com/watch?v=3oerHXIdy74
If anyone has a clue what could be making that whirring noise let me know, because I have never heard anything like it before.
Busstom Samba Member
Joined: November 23, 2014 Posts: 3841 Location: San Jose, CA
Posted: Thu Jun 23, 2022 1:19 pm Post subject: Re: Field find 1954 Canadian custom |
Are you referring to the sound that sounds like a 2-stroke leaf blower running in sync with your engine revs?
You might wait for the engine to be cool, then run it without the fan belt for a minute and see if the sound is still there. At least you could rule out those rotating parts. |
Posted: Thu Jun 23, 2022 1:25 pm Post subject: Re: Field find 1954 Canadian custom |
OK so I pulled the engine, which makes twice now. I hope it goes back in as easily as it did last time.
Finding the cause of the vibration was super easy.
Some insulation that somehow got left behind even though I really searched and poked around thinking of this very scenario.
Now to tear it apart and find out why the push rods are leaking so badly or well, so much? That makes more sense. Why they are leaking so much.
Posted: Thu Jun 23, 2022 1:29 pm Post subject: Re: Field find 1954 Canadian custom |
This car certainly is throwing some curve balls, like it don't want to be on the road at all. Perhaps I should have checked its carma before I bought it.
lardawge Samba Member
Joined: October 05, 2020 Posts: 355 Location: California
Posted: Thu Jun 23, 2022 3:59 pm Post subject: Re: Field find 1954 Canadian custom |
sunroof wrote: |
Don |
I sometimes feel that way about my car. If it isn’t one thing it’s another. The latest, on a freshly rebuilt motor, it is leaking oil on long drives from behind the crank pulley. It never ends. Then I remind myself how old these cars are. It takes time to get all the gremlins out when you have had a car apart this far. You will get there! _________________ 11/2/54 L227 Strato Silver Ragtop - Soon to be L41 Black - Build Thread
1/7/55 L275 Light Beige |
Posted: Thu Jun 23, 2022 5:12 pm Post subject: Re: Field find 1954 Canadian custom |
sunroof wrote: |
Don |
Karma, yes. It can be a fickle thing in old vw's.
The car is telling you, "I'm the boss here!" _________________ I have learned over the years.
Buy Once, Cry Once!
tehillah1 Samba Member
Joined: August 23, 2009 Posts: 276 Location: Colorado
Posted: Fri Jun 24, 2022 6:39 am Post subject: Re: Field find 1954 Canadian custom |
BLZ Bug |
Posted: Fri Jun 24, 2022 1:34 pm Post subject: Re: Field find 1954 Canadian custom |
Oh man am I glad I took the engine apart. There was insulator cotton all through it. One side of the oil cooler was blocked as well as the space between cylinders 1 & 2 and #4 spark plug well. What a disaster, but I caught it in time.
Also the oil is coming from #3 exhaust pushrod tube. The seal is pushed out of place and pouring oil.
So, I think I am making progress.
