My new 70 single cab...uh oh
ivwshane
ivwshane is offline
PostPosted: Thu Oct 24, 2019 2:56 pm    Post subject: My new 70 single cab...uh oh Reply with quote
So I went and bought a 1970 single cab and while I knew it would need some work, Iím hoping I didnít bite off more than I can chew.
First up are the pics:
77 westy 2.0 FI
69 ghia coup 1600dp
70 single cab
ivwshane
ivwshane is offline
PostPosted: Thu Oct 24, 2019 3:09 pm    Post subject: Re: My new 70 single cab...uh oh Reply with quote
I planned on replacing all the floors and I think that is a job I can handle. The doors are worse than I anticipated and I probably will just buy used ones (are the early and late bays the same?).
The gates may be salvageable for someone with more skill but Iíll either get some klassic fab replacements or fab my own basic ones.
There are two areas that are a major concern for me, the front lower inner metal (is that considered part of the frame or a separate structure?), and there is a small section of body and rockers that needs to be replaced. I was not anticipating that:(
The other major body work is the rear quarter panels which I think I can do but it will definitely push my skills.
There are some mechanical issues that Iíll need to address. The bus was converted to a type IV engine which I would like to keep but it may be more feasible to simply put back in a type I. The engine currently has dual carbs (I donít know much else about it), but I prefer fuel injection and more specifically a setup like my 77 westy just to simplify things and stick with what I know.
The front was also converted to disc brakes but after my initial test drive it seems like they arenít doing anything. Hopefully that will be an easy fix as itís the main thing I need to tackle before I drive it more.
Other than that there area ton of little things that need to be fixed. Right now I want to get all the holes plugged that might let water in. Specifically there are holes behind the cab, I posted a picture of them, does anyone know what supposed to go there?
77 westy 2.0 FI
69 ghia coup 1600dp
70 single cab
Clatter
Clatter is offline
PostPosted: Thu Oct 24, 2019 3:39 pm    Post subject: Re: My new 70 single cab...uh oh Reply with quote
Sweet ride.
Singles are often beaten up, but that one looks far better than most.
it'll need full dogleg surgery.
Luckily for you,
Gerson has most all of this stuff now.
I'd be saving for that big order.
Gates make or break a truck IMHO.
Oh,
And,
Early and late doors are different...
Bus Motor Build
Fastback Build
What's That Noise??
ivwshane
ivwshane is offline
PostPosted: Thu Oct 24, 2019 4:05 pm    Post subject: Re: My new 70 single cab...uh oh Reply with quote
Clatter wrote:
Sweet ride.
Luckily for you,
Oh,
And,
Thanks. So 68-71 are the same then? No difference between various models (sc, dc, bus)?
77 westy 2.0 FI
69 ghia coup 1600dp
70 single cab
Liveonjg
Liveonjg is offline
PostPosted: Thu Oct 24, 2019 4:33 pm    Post subject: Re: My new 70 single cab...uh oh Reply with quote
ivwshane wrote:
my 77 weary
I know exactly how you feel.
Keep it acoustic.
77 FI 2L Westfalia - Ripple
77 FI 2L Westfalia - Althea
62 Dual Carb Single Cab - Lou
ivwshane
ivwshane is offline
PostPosted: Thu Oct 24, 2019 4:34 pm    Post subject: Re: My new 70 single cab...uh oh Reply with quote
Liveonjg wrote:
ivwshane wrote:
my 77 weary
Doh!
77 westy 2.0 FI
69 ghia coup 1600dp
70 single cab
orwell84
orwell84 is offline
PostPosted: Thu Oct 24, 2019 5:42 pm    Post subject: Re: My new 70 single cab...uh oh Reply with quote
I like it. Definitely salvageable. Actually, it looks pretty solid.
Of course you bit off more than you can chew. But you will learn to just keep chewing. Smile
ivwshane
ivwshane is offline
PostPosted: Thu Oct 24, 2019 6:43 pm    Post subject: Re: My new 70 single cab...uh oh Reply with quote
Anyone have any good threads on how to tackle the lower front area?
77 westy 2.0 FI
69 ghia coup 1600dp
70 single cab
orwell84
orwell84 is offline
PostPosted: Thu Oct 24, 2019 7:01 pm    Post subject: Re: My new 70 single cab...uh oh Reply with quote
FWIW, here is a link to the work I did on that area. I know itís a late bay, but there are a few similarities. I found the hardest area to be the washer bottle panel. Wolfsburg West makes one. I think Gerson makes the rest. The Haynes restoration manual is a good guide to help you figure out all those rust sandwiches.
https://www.thesamba.com/vw/forum/viewtopic.php?t=...p;start=40
heimlich Premium Member
VWNOS.com
heimlich is online now
PostPosted: Thu Oct 24, 2019 7:06 pm    Post subject: Re: My new 70 single cab...uh oh Reply with quote
That's a nice ride.
www.vwnos.com
New NOS OEM Parts. Classic Brands. Classic Quality
Aluminum and Cast Iron Restored Distributors Available (<--Click here)
ivwshane
ivwshane is offline
PostPosted: Thu Oct 24, 2019 7:40 pm    Post subject: Re: My new 70 single cab...uh oh Reply with quote
Damn!! I might have to farm this bit out!
77 westy 2.0 FI
69 ghia coup 1600dp
70 single cab
Whaanga
Whaanga is offline
PostPosted: Thu Oct 24, 2019 9:04 pm    Post subject: Re: My new 70 single cab...uh oh Reply with quote
I donít much about single cabs but was surprised to see a type 4 engine in this 1970 SC. Is this how they came?
Late 1973 Bay w/a transplanted 914 Engine
ivwshane
ivwshane is offline
PostPosted: Thu Oct 24, 2019 9:17 pm    Post subject: Re: My new 70 single cab...uh oh Reply with quote
No. It was converted. It may have to go though. Weíll see. Ideally Iíd like to keep it and make it work but I want it to be just like the type IV in my westy.
77 westy 2.0 FI
69 ghia coup 1600dp
70 single cab
TomWesty
TomWesty is offline
PostPosted: Thu Oct 24, 2019 9:20 pm    Post subject: Re: My new 70 single cab...uh oh Reply with quote
Iím gonna say no....
ivwshane
ivwshane is offline
PostPosted: Wed Oct 30, 2019 2:01 pm    Post subject: Re: My new 70 single cab...uh oh Reply with quote
So I have a type IV engine with dual Weber carbs but thatís about as much information as I can get about it. I donít see an engine code on either the fan housing or on the case by the breather box. Where eids would they be?
Itís got the inspection plug on the top of the Fan housing but that doesnít necessarily mean anything.
Does the exhaust offer any clues?
77 westy 2.0 FI
69 ghia coup 1600dp
70 single cab
Angus II
Angus II is offline
PostPosted: Wed Oct 30, 2019 2:44 pm    Post subject: Re: My new 70 single cab...uh oh Reply with quote
Hello,
It may be a 914 engine, check the top of the case near the front?, for engine numbers.
And for the front brakes, it looks as if there is no vacuum powered brake servo... just disc and calipers... of course they don't work.... They must have changed out the rear brake system and axles also. You can't fit 71 and later rims on a 70-68 rear hub, take a closer look of your pound puppy.
The holes behind the seat may be for canopy post? IDK just a guess.
It does look like a fun project, if you like rust repair...
secretsubmariner
Champagne Wrangler
secretsubmariner is offline
PostPosted: Wed Oct 30, 2019 3:00 pm    Post subject: Re: My new 70 single cab...uh oh Reply with quote
Definitely a hack job but it looks alright. there is a tin conversion kit to make a type IV fit in an early bay but I think it's usually pretty pricey.
I have a VW of Canada Re-manufactured engine in my bus - also a type IV. The case itself only says "GE" and it has a little VW recycling stamp on it. You also have to look like, DIRECTLY down to see the number, the angle of the pic where the number would be may not be at a good angle.
I also couldn't see the engine number on my shroud until I really scrubbed the crap out of it. Maybe you just have enough oil and dirt and gunk to fill in the numbers and letters??
Good luck, sick bus
-Tony
1978 Champagne Edition II (Mar)
1978 Champagne Edition II (Feb - sold)
1978 Champagne Edition II (Jan - sold)
jtauxe
jtauxe is offline
PostPosted: Wed Oct 30, 2019 3:37 pm    Post subject: Re: My new 70 single cab...uh oh Reply with quote
Thoughts:
Cramming that Type IV engine in there must have involved some hackery, as it would not ordinarily fit. If you do go that route, you'll need to figure out how to seal off the engine compartment (so that you cannot see the street from the inside).
The row of holes behind the cab is not original. The original hoops are held to the floor and bulkhead by captive nuts that are likely gone.
My '78 double cab also has no brake booster, although it has '78 disc brakes. Stops quite well, surprisingly.
A new set of gates from KlassicFab will run you about $2000.
The engine number stamped on the shroud might be misleading. The real engine number is stamped on the top of the case near the breather box.
Good luck! Trucks are great fun and useful, too!
John
"The bus came by and I got on. That's when it all began..." - Garcia/Weir/Kreutzman
http://vw.tauxe.net
1979 Champagne Sunroof, 1974 Westfalia Automatic, 1979 Transporter, 1972 Sportsmobile, 1973 Transporter Wild Westerner, 1974 Westfalia parts bus
, 1975 Mexican single cab, 1978 Irish 4-door double cab RHD
