jimf909 Samba Member
Posted: Sat Oct 26, 2019 6:15 pm Post subject: Mopeka Bluetooth Propane Tank Gauge |
Last week I was looking for something to spend GW bucks on during their 15% off sale and came across a Bluetooth propane tank gauge. It arrived this week and I tried it out today.
Sand the rust off of the tank..
Epoxy toothpicks to the sensor so it sits squarely on the bottom of the tank...
Spray paint the tank, attach the sensor to the tank (the sensor has magnets that stick to the tank)...
Download the app to a phone and set it for a tank depth of 4.25” which is about the depth of the liquid propane in a full Westy 3.3 gallon tank (up to the overflow bleed valve which is about 2.6 gallons).
I’m looking forward to seeing how it tracks the propane level. GW recommends taking the sensor off of the tank in between measurements. I was going to try some more secure attachment system but decided to keep the sensor inside the van when not measuring the propane.
https://www.gowesty.com/product/lp-tank/25189/-bluetooth-propane-tank-level-sensor
It’s also available on amazon for a few bucks less. _________________ - Jim
Abscate wrote: |
kamzcab86 Samba Moderator
Posted: Sat Oct 26, 2019 6:50 pm Post subject: Re: Bluetooth Propane Tank Gauge |
My parents picked a package of these up at their local RV dealer months ago (before GW began selling them) and gave me the second sensor (the first is in their van along with the non-app digital display). Works well. 👍
Digging out that image reminds me that I need to get my tank filled before the upcoming trip!
Edit: Since this post, I've changed the tank parameter to a horizontal diameter measurement of 6" (calculated via tank circumference) . The above image showing 30% was an incorrect reading and resulted in my tank being overfilled because I went and had the tank filled thinking it was low.🤦♀️
Edit 2: The instructions state to mount the sensor perpendicular to the tank (and centered on the bottom), not parallel, to get an accurate reading. _________________ ~Kamz
2016 Golf GTI S
WestleyTheWesty Samba Member
Joined: October 07, 2015 Posts: 128 Location: Portland, OR
Posted: Fri Jan 03, 2020 11:52 pm Post subject: Re: Mopeka Bluetooth Propane Tank Gauge |
Just grabbed one of these from Amazon, nice to see a few tips for using it! Yeah, really no reason to leave it installed 24/7, and the little bag is smart to keep it protected.
Will hopefully test it out this week! _________________ 1990 Westy, started stock, not anymore! |
Posted: Sat Jan 04, 2020 6:33 am Post subject: Re: Bluetooth Propane Tank Gauge |
kamzcab86 wrote: |
Edit 2: The instructions state to mount the sensor perpendicular to the tank (and centered on the bottom), not parallel, to get an accurate reading. |
Kamz is correct (again ). I subsequently learned the same and the toothpicks I epoxied on are unneccesssry.
Now I leave the sender inside the van and put it on the tank only when I want to take a measurement. _________________ - Jim
Abscate wrote: |
maco70 Samba Member
Joined: March 16, 2011 Posts: 456 Location: Montréal, Québec
Posted: Sat Jan 04, 2020 8:18 am Post subject: Re: Mopeka Bluetooth Propane Tank Gauge |
Here are the instructions photos, about where to put the sensor :
_________________ Martin from Montréal
1986 Vanagon GL full camper westfalia
(brown/tan interior) |
cmayna Samba Member
Joined: August 18, 2014 Posts: 1148 Location: SF Bay area, CA
Posted: Sat Jan 04, 2020 10:39 am Post subject: Re: Mopeka Bluetooth Propane Tank Gauge |
Something I've been wanting to determine how much propane the westy has but also how much propane I have left in my BBQ and smoker propane tanks.
My local ACE hardware has them in stock for $37.....and with a $5 off Ace rewards card that the wife got in the mail recently. _________________ '90 Westy / automatic.
If I'm not working on the camper or my '50 Chebbie truck, I'm either fishing with the wife or smoking Salmon.
Craig |
cmayna Samba Member
Posted: Sat Jan 04, 2020 1:59 pm Post subject: Re: Mopeka Bluetooth Propane Tank Gauge |
JimF909 and Kamz,
Is 6" the best horizontal tank height dimension to use? With 6" it says my tank is about half full which seems pretty accurate to me, but until I get it topped off, it's all a guess.
I then connected the transmitter to the bottom of one of my smoker 20 lb tanks which says 98% which if my memory is correct would be pretty close to accurate.
Just a bunch of more testing, etc will deem how accurate this setup is. _________________ '90 Westy / automatic.
Craig |
Ahwahnee Samba Member
Joined: June 05, 2010 Posts: 9810 Location: Mt Lemmon, AZ
Posted: Sat Jan 04, 2020 2:03 pm Post subject: Re: Mopeka Bluetooth Propane Tank Gauge |
Yeah - I got one too on the strength of the above comments. 34 bucks & free shipping from Amazon made it a reasonable bit of kit.
My tank is full so on Monday I will have it and see what it says using 6". |
Posted: Sat Jan 04, 2020 3:03 pm Post subject: Re: Mopeka Bluetooth Propane Tank Gauge |
cmayna wrote: |
JimF909 and Kamz,
I then connected the transmitter to the bottom of one of my smoker 20 lb tanks which says 98% which if my memory is correct would be pretty close to accurate. |
You'll want to measure your tank to be certain. My tank's circumference is 19-1/8", which yields a 6.1" height (diameter; divide circumference by pi). My dad used calipers to measure his tank and it came close to 7". You can't use decimals in the app, so you have to round the height off. I initially used 7" based on my parents' van, which caused too low of a level reading. It's currently reading 93%.
I just put the sensor on my BBQ tank. It reads 87%, which about matches the "hook, lift, and look" gauge.
My tank is having fill issues, so I'll be running it until empty, then having a pro look at it.
[Edit: Wrong! Decimals can be entered in the app!] _________________ ~Kamz
2016 Golf GTI S
cmayna Samba Member
Posted: Sat Jan 04, 2020 4:15 pm Post subject: Re: Mopeka Bluetooth Propane Tank Gauge |
Just measured the OD and am also getting just a tad over 6". Not knowing if we should be talking OD vs ID, think I'll also stay at 6" for now. Pretty neat device. Think I'll be getting another one dedicated to my two 20# BBQ tanks.
Nice toy. Thank you jimf909 for doing this post. _________________ '90 Westy / automatic.
Craig |
Posted: Sat Jan 04, 2020 4:31 pm Post subject: Re: Mopeka Bluetooth Propane Tank Gauge |
Caution: make sure you download the CORRECT APP.
I was confused when Kamz said she couldn’t enter decimals for the tank height (I could do that on the app I was using). I was further confused when Kamz’s screenshot showed a horizontal tank (I couldn’t select a horizontal tank on my app).
It turns out we had very similar apps (see screenshots above) but kamz’s app had a gear where mine had a pencil. I went back to the App Store and downloaded Mopeka TankCheck not “MY Tracker BBQ” that I had downloaded. They both looked and worked alike but the first app seems to work better with horizontal tanks (at least it displays a horizontal tank). _________________ - Jim
Abscate wrote: |
Posted: Sat Jan 04, 2020 4:50 pm Post subject: Re: Mopeka Bluetooth Propane Tank Gauge |
jimf909 wrote: |
I went back to the App Store and downloaded Mopeka TankCheck not “MT Tracker BBQ” that I had downloaded. They both looked and worked alike but the first app seems to work better with horizontal tanks (at least it displays a horizontal tank). |
MT Tracker BBQ doesn't even appear in the Play Store for me. If I bring it up via a link, it displays This item isn't available in your country. So, yes, you need the app that corresponds with the device, in this case Mopeka Tank Check.👍
MT Tracker BBQ and its (exact same) sensor are also made by Mopeka, but not sold in North America. _________________ ~Kamz
2016 Golf GTI S
Posted: Sat Jan 04, 2020 5:11 pm Post subject: Re: Mopeka Bluetooth Propane Tank Gauge |
^^^ This is interesting. The Help link in the MT Tracker BBQ app goes to an Australian website (below). Either GW has a stash of Australian product and I followed the directions in the package correctly or I somehow managed to track down the Australian version of the app.
Edit: it looks like I just downloaded the Australian app. The product from GW shows the .com url. I'm glad it worked as well as it did !
https://www.boc.com.au/shop/en/au/mt-tracker-bbq
Thanks for setting me straight. _________________ - Jim
Abscate wrote: |
izzydog Samba Member
Posted: Sat Jan 04, 2020 6:42 pm Post subject: Re: Mopeka Bluetooth Propane Tank Gauge |
OK, I'll bite... what's the science behind this magic device? |
Posted: Sat Jan 04, 2020 7:44 pm Post subject: Re: Mopeka Bluetooth Propane Tank Gauge |
izzydog wrote: |
The video says it’s ultrasonic science...
Abscate wrote: |
SyncroHead Samba Member
Joined: May 23, 2005 Posts: 1145 Location: Northern Nevada
Posted: Sat Jan 04, 2020 8:35 pm Post subject: Re: Mopeka Bluetooth Propane Tank Gauge |
My Westy's propane tank was filled by the previous owner and I don't have any idea if it's 90% full or almost empty. This device looks great!
I just ordered one of these too. I'll report back...
Jim _________________ "A Vanagon? It's not a car or a van. It's a hobby!"
Check out:
www.VANAVATION.com
www.SyncroSafari.org and
www.Vanagons.org
sphet wrote: |
I have *no* idea what the previous owner carried in his Westy... angry donkeys? |
cmayna Samba Member
Posted: Sun Jan 05, 2020 9:04 am Post subject: Re: Mopeka Bluetooth Propane Tank Gauge |
Mopeka's FAQs states that the battery in the sensor will typically last a year. Battery strength will be stronger in warm climate. Not sure what I'm going to do yet but might consider removing the battery when not using the sensor which I foresee myself using it 2-3 times a year or add an extra 2032 battery to my stash of batteries in the westy kitchen drawer? _________________ '90 Westy / automatic.
Craig |
Posted: Sun Jan 05, 2020 9:30 am Post subject: Re: Mopeka Bluetooth Propane Tank Gauge |
cmayna wrote: |
Mopeka's FAQs states that the battery in the sensor will typically last a year. Battery strength will be stronger in warm climate. Not sure what I'm going to do yet but might consider removing the battery when not using the sensor which I foresee myself using it 2-3 times a year or add an extra 2032 battery to my stash of batteries in the westy kitchen drawer? |
The battery that came in my sensor lasted about 6 months (parents' original battery is still going). But: 1) I don't count the wimpy battery supplied by the manufacturer. We'll see if the Energizer replacement lasts until December. 2) The signal frequency can be adjusted. I didn't realize this until Christmas when looking at my mom's phone. Mine was set to 3.5 seconds, while my parents' was set to 10.5 seconds. The instructions say to press and hold the sync button for 5 seconds to toggle the setting... not so; press and hold for 10 seconds. Hopefully, this yields a longer battery life.🤞 _________________ ~Kamz
2016 Golf GTI S
Posted: Sun Jan 05, 2020 10:18 am Post subject: Re: Mopeka Bluetooth Propane Tank Gauge |
cmayna wrote: |
...Not sure what I'm going to do yet but might consider removing the battery when not using the sensor which I foresee myself using it 2-3 times a year... |
I expect that is what I will do (same as I do with the batteries for the in-fridge thermometer).
Thanks to all for the detailed instructions - those will save a lot of fiddling and frustration as I set it up. |
Posted: Sun Jan 05, 2020 11:08 am Post subject: Re: Mopeka Bluetooth Propane Tank Gauge |
SyncroHead wrote: |
Jim |
There's always the method of pouring warm water on the tank to check the propane level (the tank will be cool or there will be condensation on the tank up to the level of the propane in the tank). I've found this to be a bit of a PITA on a rusty tank. Plus I'd usually pour water on myself. But it does work. _________________ - Jim
Abscate wrote: |
