Daverham Samba Member
Posted: Mon Nov 04, 2019 9:03 pm Post subject: Re: Installing a Cheap Chinese Diesel Parking Heater |
Y'all almost had me convinced to put it inside. I suppose I'm not really worried about the heater unit itself burning up at this point. But the noise of the fan is of great concern when sleeping. I have the perfect place to put it.... but there would be essentially no ducting on either side and I'm not into "jet engine" at all. I’m highly annoyed by such things - the sound of my fridge running (in my house) sometimes bugs me from the next room. So I need this to be as silent as possible, within reason.
I'm still a bit tempted to go with the factory(?)-designated Eberspacher engine compartment location, but that would essentially be right under my pillow. So again with the noise. Although that would be on the other side of the rear floor + insulation so maybe it's not quite so bad as unmitigated fan noise. This is my #2 at this point.
And I was also highly tempted to pop it right into the main duct line in place of the entire factory heat system, but my factory heater/defrosters actually work, so I would just hate to scrap that because I wasn’t willing to try a little harder.
So I have one last "other" idea before I commit: I cut the zip-ties that hold up the central heat duct and it was easy to push it over to the side a bit - and then re-attach it with a bit of a bend in it. Side note: my bus currently has a 3.5 inch accordion duct running up the middle between the cross-braces. I don’t know if that’s factory or if it should be a solid pipe. For all I know, I installed that duct myself 10 years ago. I have no idea. Regardless, with that out of the way there are a lot more options under the floor and I think I have a good place staked out a bit forward of center. By re-designing my mounting bracket, I can pull almost 3 inches off the ground clearance issue. It will involve a little more welding and drilling at my work bench, but I think it will be worth it.
I’ll likely be adding another $20 worth of steel to the cost tally tomorrow, for my new mounting bracket. Probably a hole saw too and eventually some ducting and clamps.
Oh, and to answer one question from a page or so back: I have just added an auxiliary battery. Partly for this and partly for house lights and accessory plugs (mostly phone chargers). |
vwwestyman Samba Member
Joined: April 24, 2004 Posts: 5688 Location: Manhattan, Kansas, USA
Posted: Mon Nov 04, 2019 9:33 pm Post subject: Re: Installing a Cheap Chinese Diesel Parking Heater |
That plastic/paper duct is factory on later Bays. My '73 had a metal duct (before I swapped in the BA6); my '78 had a plastic/paper duct. So sometime in between there.
I don't know if I mentioned this idea in this thread or another, but you could get a Y and some kind of flap, and have the heater pipe go into the heater duct.
A much simpler option would be to extend the factory heating tube(s) straight from the rear Y where the heater box lines join together to your paper duct, all the way up to the front "heater tree." Bypass and eliminate the flapper box that directs heat to the rear vents.
Now, duct your parking heater with a Y to go into the rear seat heat outlet and the outlet between the front seats.
Doing all that, you'd eliminate potential flow losses to the front of the Bus/defrost, and be providing a heater for the back that can also be used for camping. That seems like a double good to me!
This would essentially be how I installed my Espar, I just hadn't until now thought about how to do it while still using a factory heating system. (Since I'm watercooled in that Bus.)
Also, you would end up with some bends which should help the noise issue. Indeed the noise is pretty low in my Bus with the heater running. Neither my wife or I find it at all disruptive, nor have buddies who've camped with me. _________________ Dave Cook
1973 Wild Westerner
My Thing |
tristessa Samba Member
Joined: April 07, 2004 Posts: 3992 Location: Portland, OR
Posted: Mon Nov 04, 2019 9:35 pm Post subject: Re: Installing a Cheap Chinese Diesel Parking Heater |
The few times I've run it while sleeping, the noise hasn't been a problem for me .. but I'm one of those weirdos who can sleep soundly on an airplane, even in economy-class seating. Drives my wife nuts; I'll be all refreshed and ready to go after a transatlantic flight, all she wants to do is go to the hotel and sleep for a day or two.
It is on the loud side at full blast, though.
My (early-ish) '75 was metal duct, my buddy's '77 is paper, so the cutoff is somewhere in between. '76 would be logical, but... |
notchboy Samba Member
Joined: April 27, 2002 Posts: 22462 Location: Escondido CA
Posted: Mon Nov 04, 2019 9:44 pm Post subject: Re: Installing a Cheap Chinese Diesel Parking Heater |
You are going to hear it no matter where you put it. Yeah maybe less some places, but it will be there. Any sound resonates through the frame, the wall, the floor.
It will be interesting to see what you come up with to combat this. _________________
t3kg wrote: |
Jason "notchboy" Weigel
1964 1500 S
1964 T34 S Convertible
Okie Adam Samba Member
Joined: November 07, 2003 Posts: 1347 Location: OOOOOOOOOOOOOOOOOklahoma
Posted: Tue Nov 05, 2019 9:02 am Post subject: Re: Installing a Cheap Chinese Diesel Parking Heater |
I've been considering this exact set up for my late westy. The only problem I'm worried about is from my experience with these heaters they need unrestricted air for the fan to blow. It will throw a code and shut down if it doesn't get it. _________________ Oil Capital Air Cooled
55 Wolfsburg Kombi
60 Walkthrough Kombi
62 Single Cab
66 21window
67 so42
76 Westy
64 Karmann Ghia |
danfromsyr Samba Member
Posted: Tue Nov 05, 2019 9:25 am Post subject: Re: Installing a Cheap Chinese Diesel Parking Heater |
they really don't stay on full blast for very long.
they idle down to a maintain low speed and only ramp up if it can't maintain temp at a lower fan velocity.
so unless you do sub zero winter camping with the top popped, it's not going to be on high very much at all. |
Posted: Tue Nov 05, 2019 12:02 pm Post subject: Re: Installing a Cheap Chinese Diesel Parking Heater |
Tristessa, I cannot sleep on a plane AT ALL, no matter how tired I am, even at 3am. But it's the sitting up more than the noise. Regardless, I'll be mounting every point of contact possible via rubber - as thick as possible. And I think the external (under-floor) mount for the whole unit is going to work. After that, I'll just be sure to have an extra glass of whiskey before bed and I'll be fine.
I just got back from the hardware store.
Time to update the cost tally:
• The unit $199
• Two steel bars from the local hardware store for mounting it under the floor $16 (no longer being used)
• New fuel tank $15
• Crooked funnel for filling that fuel tank $8
• New steel plate for mounting bracket $12
• 1.25 inch hole saw in case mine is dull $10
• New 3.5 inch hose clamps (one broke while messing with the big duct) $6
• A gallon of Kerosene for setup, testing & camping $10
>>> TOTAL SO FAR: $277 |
Posted: Tue Nov 05, 2019 1:04 pm Post subject: Re: Installing a Cheap Chinese Diesel Parking Heater |
Daverham wrote: |
• The unit $199
• New fuel tank $15
Like the original plan? Or back more?
t3kg wrote: |
1964 1500 S
Posted: Tue Nov 05, 2019 1:09 pm Post subject: Re: Installing a Cheap Chinese Diesel Parking Heater |
I transferred the hole pattern to my new piece of steel with spray paint, using the old one as a template:
And drilled it up. It fits! Next it needs to be drilled for mounting to the bus and a 90-degree bend put in there. I don't have a brake, but I'll figure something out.
But first I have to go pick up my kid from pre-school... and I suppose I should do some work at some point today to, although this is way more fun. |
Posted: Tue Nov 05, 2019 1:11 pm Post subject: Re: Installing a Cheap Chinese Diesel Parking Heater |
I'm moving it a bit more forward, tucked up higher (closer to the floor) and inboard, in between the two main frame rails. You shall see soon! |
OG Velvet Samba Family Man
Joined: February 24, 2003 Posts: 2168 Location: Portland, OR
Posted: Tue Nov 05, 2019 7:41 pm Post subject: Re: Installing a Cheap Chinese Diesel Parking Heater |
As hot as this thing blows, you're not going to want or need it while sleeping. I plan on running it to take the edge off, then crawling into bed. But I run pretty hot. _________________ '67 13 Window
'77 Westy
'69 Sunroof Beetle
'65 Honda Dream |
obieoberstar Samba Member
Posted: Tue Nov 05, 2019 8:12 pm Post subject: Re: Installing a Cheap Chinese Diesel Parking Heater |
Fired up my heater for the first time in 6 months. No problems. Same fuel too.
My fuel pump has that rubber collar which includes a mounting hole. Well, I mounted the pump below the fuel tank on the bulkhead behind the driver's seat.
The pump's operational duty cycle gets transmitted to the body and is quite loud.
This guy has the solution.
https://www.youtube.com/watch?v=ypuF1TeQ_hc |
71whitewesty Samba Member
Joined: February 25, 2010 Posts: 1544 Location: oregon
Posted: Tue Nov 05, 2019 9:33 pm Post subject: Re: Installing a Cheap Chinese Diesel Parking Heater |
obieoberstar wrote: |
What language was that in? that was a great tip and worth watching. _________________ 71 Westy 1600 DP, all stock Bus 1
1970's Snow Trac 1600 SP (sold 12/2016)
1968 Tucker sno cat, sold 2021
1969 Tucker Sno cat 542
2017 VW Alltrac
71 tin top stock 1600 DP (project but runs)
Twin 71 White Westy, Bus 2, that I pulled from a 15 year slumber in a dry eastern WA field in 2015.
1966 Sundial Camper "Boomer" |
Posted: Fri Nov 08, 2019 1:41 pm Post subject: Re: Installing a Cheap Chinese Diesel Parking Heater |
It has been mentioned a couple times - and it's easily lost among the photos and such - but I'd just like to highlight that the Facebook user groups are VERY active and full of people with tons of experience and technical knowledge. You can get answers to anything right away:
https://www.facebook.com/groups/146837062640024
I finally got my unit installed to my satisfaction (under the floor) and now I'm working on ducting. I'll report back with thoughts, comments, things I've learned and photos... |
thomas. Samba Member
Joined: July 31, 2010 Posts: 1291 Location: South West (Pa.)
Posted: Sat Nov 09, 2019 6:41 am Post subject: Re: Installing a Cheap Chinese Diesel Parking Heater |
I have a 5kw installed under the rear seat / rock & roll bed. It's a '66 Westy but I've never used it for camping. Some day maybe. Anyway I wanted to say I'm sure I've read the chinese heaters are not intended for the outside of the vehicle because the wiring isn't waterproofed so you may want to address that. Also wanted to include I had my bus out this morning 23* fahrenheit. and the heater worked beautifully. Like I said I only run the heater while it's moving and bus has lots of drafts so this 5kw really does the job. I have to unplug the heater while in storage, even overnight since the LED controllers backlight stays on and drains the battery. Otherwise pretty happy with it. When I 1st installed it I was getting an error code#5 (overheating) It turned out I didn't leave enough open space on the cabin intake air side. So I have to leave the closet door open that sits in front of heater.No big deal. Haven't had a code since. I also bought a 2kw one I was going to install in my Bug. You can't beat the price. One last thing (I know long winded) if anyone here is looking for a 2kw( at least that is what is advertised ) here is a link to one with a good price.
Caveat emptor, A lot of merchants are advertising 2kw heaters when they are actually 5kw. The one in the photo below looks as a 2kw.
https://www.ebay.com/itm/12V-Air-Diesel-Heater-PLA...3579490257 |
Posted: Sat Nov 09, 2019 7:19 am Post subject: Re: Installing a Cheap Chinese Diesel Parking Heater |
Here's a few photos of my heater. The last photo I'm opening the window because it's getting too warm ....
Posted: Sat Nov 09, 2019 8:26 am Post subject: Re: Installing a Cheap Chinese Diesel Parking Heater |
^^funny, I pictured you older for some reason. _________________ 71 Westy 1600 DP, all stock Bus 1
2017 VW Alltrac
Posted: Sat Nov 09, 2019 9:50 am Post subject: Re: Installing a Cheap Chinese Diesel Parking Heater |
Cats out of the bag, really my grandson who will probably end up being a "VW for life" as well. |
Posted: Sat Nov 09, 2019 4:18 pm Post subject: Re: Installing a Cheap Chinese Diesel Parking Heater |
thomas., how and where are you ducting the heat to the bus? |
