Okie Adam Samba Member
Joined: November 07, 2003 Posts: 1347 Location: OOOOOOOOOOOOOOOOOklahoma
Posted: Mon Nov 09, 2020 7:32 am Post subject: Re: Installing a Cheap Chinese Diesel Parking Heater |
Jeremy, I am curious how much room you have between the sheet metal and the inlet? I have read some folks have had a problem when that air flow is restricted. I love your set up! _________________ Oil Capital Air Cooled
55 Wolfsburg Kombi
60 Walkthrough Kombi
62 Single Cab
66 21window
67 so42
76 Westy
64 Karmann Ghia |
wagohn Samba Member
Joined: June 24, 2014 Posts: 740 Location: United States
Posted: Thu Dec 31, 2020 9:04 am Post subject: Re: Installing a Cheap Chinese Diesel Parking Heater |
tjrm63 wrote: |
I chose the portable chinese heater for my application
Installed it behind the jumpseat, I also chose the one with the 4 vents so I could put heat up front in the cab as well as the back. I used 4 traps from a sink as my heater vents that are curved 90 degrees and fit inside the hole perfecly and I can rotate them to add or lessen the heat
I'm very interested in these all-in-one types. Does anyone know why this model-type could not be strapped into the area in the engine bay where an aux battery would usually sit? It seems it would be an easy install and relatively simple to route the exhaust down to under the bus. Heat issues?
We use our bus for dog shows and it gets pretty cold waiting in the parking lot for our runs (covid rules). So we're not too bothered about noise when sleeping etc. Also, how long does a "full tank" run on these things?
Thanks _________________ 1976 VW Transporter, 2.0 FI Engine |
vwwestyman Samba Member
Joined: April 24, 2004 Posts: 5688 Location: Manhattan, Kansas, USA
Posted: Thu Dec 31, 2020 9:51 am Post subject: Re: Installing a Cheap Chinese Diesel Parking Heater |
I missed the original post of that portable heater install before.
But I'd advise looking up what the material on the sink parts is made of, what that material does at high temps, and checking the temps that the heater is putting out.
I say that because I've seen comments that PVC pipe, when heated, will release toxic gasses. _________________ Dave Cook
1973 Wild Westerner
My Thing |
tristessa Samba Member
Joined: April 07, 2004 Posts: 3992 Location: Portland, OR
Posted: Thu Dec 31, 2020 11:01 pm Post subject: Re: Installing a Cheap Chinese Diesel Parking Heater |
vwwestyman wrote: |
I say that because I've seen comments that PVC pipe, when heated, will release toxic gasses. |
OP should see if there's a brass or chrome/brass version that fits the same as what he's using, or an ABS DVW fitting. All the slip-fit plastic sink traps I've seen on the market in the last ten years are PVC or polypropylene, even if they're colored black. Source: I reorder inventory to keep the plumbing section of a smaller hardware store stocked every week.
Joined: January 01, 2007 Posts: 16863 Location: sticksville, ct.
Posted: Fri Jan 01, 2021 12:57 pm Post subject: Re: Installing a Cheap Chinese Diesel Parking Heater |
honestly those fuckers get so hot at the outlet i'd look into aluminum pre heat pipes. _________________
gprudenciop wrote: |
Jake Raby wrote: |
Brian wrote: |
jakokombi Samba Member
Joined: August 15, 2010 Posts: 777 Location: Milwaukee
Posted: Sat Jan 02, 2021 9:25 am Post subject: Re: Installing a Cheap Chinese Diesel Parking Heater |
I put a small unit (2.2kw) under the driver's seat in my '70.
I think that I could fit the larger 5.5 kw in there with a raised thimble to avoid the floor contours.[img]
[/img] _________________ 70 Sunroof Kombi
69 Tin Top
73 Thing
72 Baja |
notchboy Samba Member
Joined: April 27, 2002 Posts: 22449 Location: Escondido CA
Posted: Sat Jan 02, 2021 10:03 am Post subject: Re: Installing a Cheap Chinese Diesel Parking Heater |
Notch, I haven't used it for camping yet, but running it while driving around was just ok at freezing temperatures.
I suspect that the 5.5 might be the better choice, I don't end up camping in real cold temps because Wisconsin roads get salted before the first sight of snow and this should be good enough for now. _________________ 70 Sunroof Kombi
69 Tin Top
73 Thing
72 Baja |
wagohn Samba Member
Posted: Sat Jan 02, 2021 10:07 am Post subject: Re: Installing a Cheap Chinese Diesel Parking Heater |
jakokombi wrote: |
I suspect that the 5.5 might be the better choice, I don't end up camping in real cold temps because Wisconsin roads get salted before the first sight of snow and this should be good enough for now. |
Ours is a "tintop" and our temps rarely are below 40 degrees while at events (when we need the heat). I'm thinking the 2kw is more than enough to get us into the mid 60s.
I like the under the seat idea. Where is the fuel tank? Thanks. _________________ 1976 VW Transporter, 2.0 FI Engine |
Posted: Sat Jan 02, 2021 10:10 am Post subject: Re: Installing a Cheap Chinese Diesel Parking Heater |
skills@eurocarsplus wrote: |
honestly those fuckers get so hot at the outlet i'd look into aluminum pre heat pipes. |
Yeah, come to mention it, I get a whiff of hot plastic from the 2.2 kw.
I suspect from the vent nozzle supplied with it. I'll be on the lookout for something else. _________________ 70 Sunroof Kombi
69 Tin Top
73 Thing
72 Baja |
Posted: Sat Jan 02, 2021 10:20 am Post subject: Re: Installing a Cheap Chinese Diesel Parking Heater |
Wagohn, it sounds like you would be fine with the smaller unit.
I currently have the 16"x16"x4" tank mocked up on the back of the passenger seat bulkhead.
I plan to enclose it with a Westy style spice rack/folding table, assuming I like that location. _________________ 70 Sunroof Kombi
69 Tin Top
73 Thing
72 Baja |
wagohn Samba Member
Posted: Sat Jan 02, 2021 10:37 am Post subject: Re: Installing a Cheap Chinese Diesel Parking Heater |
jakokombi wrote: |
I plan to enclose it with a Westy style spice rack/folding table, assuming I like that location. |
Thanks - I assume the cap is vented, no diesel smells, etc, when driving? _________________ 1976 VW Transporter, 2.0 FI Engine |
Posted: Sat Jan 02, 2021 10:43 am Post subject: Re: Installing a Cheap Chinese Diesel Parking Heater |
Yes, vented and no smells, I do worry about spills during fill ups tho.
I thought about making it to slide out to fill, probably I won't. _________________ 70 Sunroof Kombi
69 Tin Top
73 Thing
72 Baja |
wagohn Samba Member
Posted: Sat Jan 02, 2021 10:44 am Post subject: Re: Installing a Cheap Chinese Diesel Parking Heater |
jakokombi wrote: |
I thought about making it to slide out to fill, probably I won't. |
Thanks so much. _________________ 1976 VW Transporter, 2.0 FI Engine |
jeremyrockjock Samba Towbar Builder
Joined: January 01, 2002 Posts: 5008 Location: Richmond, Verjinya
Posted: Sat Jan 23, 2021 6:31 pm Post subject: Re: Installing a Cheap Chinese Diesel Parking Heater |
John Ghia wrote: |
Jeremy do you think it will fit in the toolbox area? |
I tried that but the problem is the axle beam is directly below it.
Okie Adam wrote: |
Jeremy, I am curious how much room you have between the sheet metal and the inlet? I have read some folks have had a problem when that air flow is restricted. I love your set up! |
I was a little worried too but it works very well. If I had to do it over I would give it more room. Once I cut the holes for the intake and exhaust I was committed. _________________ Why buy what you can build.
Step away from the fiberglass and no one gets hurt!! |
scubasteve321 Samba Member
Posted: Sun Jan 24, 2021 11:25 am Post subject: Re: Installing a Cheap Chinese Diesel Parking Heater |
Regarding fuel tank locations;
I bought a 2 gallon diesel tank and have it bungeed in the aux battery area in my 71 Bay (the mirrored area from the starting battery location)
Download the Webasto manual; the fuel pump can pump quite a distance _________________ 1971 Campmobile Tin-Top
1971 Campmobile Pop-Top
1974 VW Bus |
BUSBOSS Samba Member
Joined: January 21, 2009 Posts: 2161 Location: Northern California
Posted: Fri Jan 29, 2021 11:44 pm Post subject: Re: Installing a Cheap Chinese Diesel Parking Heater |
KrisBalfe wrote: |
Stuck mine in the spare tire well. Keeps the bus toasty and complaints from the wife and kids are gone. |
More pics of this install please. _________________ All the redemption I can offer, girl, is beneath this dirty hood
1976 Westfalia
1970 Karmann Ghia Convertible (sold - but not forgotten) |
RParker Samba Member
Joined: October 04, 2019 Posts: 4 Location: British Columbia
Posted: Tue Feb 02, 2021 12:05 pm Post subject: Re: Installing a Cheap Chinese Diesel Parking Heater |
I bought a Chinese 2kw unit and with a little modification, it fits perfectly beneath the seat on my ‘75 “Vincent”. I have the hot air blowing out of the vent it came with just into the cabin. I’m nervous to send it up to the dash through the bus’s ducting because the air temp is so hot it may melt the plastic tubes. I’m wondering about getting the hot air into the metal mixing box where the ambulance fans could blow it on the windscreen. |
KentABQ Samba Member
Joined: September 11, 2016 Posts: 2406 Location: Albuquerque NM
Posted: Tue Feb 02, 2021 6:32 pm Post subject: Re: Installing a Cheap Chinese Diesel Parking Heater |
RParker wrote: |
I bought a Chinese 2kw unit and with a little modification, it fits perfectly beneath the seat on my ‘75 “Vincent”. |
Which seat were you able to fit it under?
What modifications were needed?
Can you post some pictures of your accomplishment? _________________ -Kent-
1976 Riviera, 1.8l FI chrome yellow VAN - "Chloe"
"I must say, how can you be in a bad mood driving this vehicle full of vibrant color.
Cars of today are so bland in comparison. It's like driving a celebration!" ---WildIdea
Bus ownership via emoticons:
---williamM |
calvinater Samba Member
Joined: September 06, 2014 Posts: 3328 Location: 802 The Pointless Forrest
Posted: Wed Feb 03, 2021 11:34 am Post subject: Re: Installing a Cheap Chinese Diesel Parking Heater |
Anyone found an all in one unit that runs on 110 ac voltage?
Could use for a 20x20 basement shop. _________________ "Albatross"! |
