386kustoms Samba Member
Posted: Tue Oct 29, 2019 7:24 pm Post subject: My first bus! 66 13w delux |
Ok i lied i actually owned a rotted to the ground bus befor but i just bought it for parts. But this is my first bus im going to fix up. Im a bug guy and have owned a few ovals. Im currently restoring a 54 3 fold frame off. Ive had many nice ovals and always afraid to drive them because how clean they are. So i wanted something ruff and this fit the bill. Its a orig paint 66 13w non walk through. My plans are simple with this. Fix the rust, lower it, and drive the hell out of it. Im learning a lot from these forums so i think im going with a 68 bug trans, flipped spindles and 4 inch beam. Here are some pics of my beauty. Took 3 days to get the shag carpet off everything. And then i played with the forward cargo door. If you look in the first pics you can see a bondo spot and surface rust under the glass. Well i mixed some color and blended it pretty good. I will do the rear quarters next. And i also have to fix the window frames as someone cut the corners to fit those jelousy windows
Dustin B Samba Member
Joined: March 29, 2007 Posts: 1017 Location: hesperia, Ca USA
Posted: Tue Oct 29, 2019 8:41 pm Post subject: Re: My first bus! 66 13w delux |
That's a sweet bus. Looks pretty solid too. _________________ Wanted Victoria motors licence plate frame.
62 og paint L469 type 1
61 og paint L31 DD panel type 2
64 heilite viscount tent trailer
71 sears clamshell trailer
I <3 Brazilian busses
Original paint and patina extravaganza http://www.thesamba.com/vw/forum/viewtopic.php?t=187156 |
zimblewinder Samba Member
Joined: January 22, 2004 Posts: 893 Location: Australia
Posted: Wed Oct 30, 2019 1:53 am Post subject: Re: My first bus! 66 13w delux |
classic headliner _________________ 58Euro 23 343208 The Ultimate Zimblewinder Machine.
59 mango standard
Wanted- splash pan supports, og pressed bumper coach bolts, ivory blaupunkt knobs (early), armrest alloy strips, NOS door mechanism |
LAGrunthaner Samba Member
Joined: March 18, 2007 Posts: 5509 Location: 1st Coast
Posted: Wed Oct 30, 2019 2:20 am Post subject: Re: My first bus! 66 13w delux |
Yes looks very solid. What is that headliner made of is it foam? Looking forward to your updates _________________ American Red Cross Safe And Well:
Maui Roadsters
www.mauiroadsters.com
http://www.oacdp.org
Lind wrote: |
Posted: Wed Oct 30, 2019 3:53 am Post subject: Re: My first bus! 66 13w delux |
LAGrunthaner wrote: |
Yes looks very solid. What is that headliner made of is it foam? Looking forward to your updates |
no thats shag carpet, shag shag shag lol they glued the hell out of it too. has some rust above cargo doors from it holding water that i have to address |
j.pickens Samba Member
Joined: December 03, 2002 Posts: 9791 Location: Exit 7, New Jersey
Posted: Wed Oct 30, 2019 7:25 pm Post subject: Re: My first bus! 66 13w delux |
386kustoms wrote: |
For nearly twenty years, from 1970 to the late 1980's, the liberal application of shag carpeting was the normal thing to do to the interior of a VW bus.
My older brother had a '67 panel bus which he bought with 4 inches of foam on the floor, and the entire floor and walls covered in yellow/orange/brown shag carpeting.
We would go skiing in Vermont, my brothers up front, and me lying on the shag in the rear with the ski gear. They would be freezing, so they would crank up the Southwind heater, which only vented into the rear, and I'd be roasting! It was more like a kidnapping, as I couldn't see out the front windows, just random headlights and streetlights flickering into the shadowy confines of the cargo compartment.
Good times... _________________ Founder and Chairman Emeritus, ECMSAS
BeaterBarndoor wrote: |
i wish more people would actually drive their vws rather than just talking about what they have in the garage. |
Red Fau Veh wrote: |
If you've seen one sunroof swivel seat kombi, you've seen them all! |
scottvw Samba Member
Joined: November 17, 2004 Posts: 2821 Location: Centennial, CO
Posted: Thu Oct 31, 2019 10:43 am Post subject: Re: My first bus! 66 13w delux |
Removing that carpet must have been a nasty job. Good luck....keep the progress pics coming. Believe it or not, that paint will buff out nicely. Try a small spot to see. My Sea Blue came back nicely. |
zuggbug Samba Member
Joined: June 17, 2008 Posts: 3479 Location: Anderson SC
Posted: Thu Oct 31, 2019 2:14 pm Post subject: Re: My first bus! 66 13w delux |
j.pickens wrote: |
386kustoms wrote: |
Good times... |
what you learn about someone on the Samba _________________ SOUTHERN INTEGRITY AIRCOOLERS
58 15 window
56 westy |
Posted: Thu Oct 31, 2019 3:21 pm Post subject: Re: My first bus! 66 13w delux |
Agreed the most enjoyable read of the day
zuggbug wrote: |
j.pickens wrote: |
386kustoms wrote: |
Good times... |
what you learn about someone on the Samba |
Maui Roadsters
Lind wrote: |
