67 Sunroof Samba Member
Joined: February 22, 2014 Posts: 1836 Location: Salisbury, MD
Posted: Wed Oct 30, 2019 1:42 pm Post subject: CB “racing gland nut” |
Ok so I’m beginning to assemble the crank and noticed that the gland nut is a different size than the stock one. Stock is 36mm and i think cb is 37-38...
No big deal. But.
My torque master tool tool I bought to tighten down the gland nut is also 36mm. Haha.
Not sure what I am asking here but I guess I’ll just buy another stock gland nut or use the cb and have to find another socket and find a way of torquing down the gland nut without the torque tool I bought. Wasted money I guess.
I guess I’ll just get a new gland nut instead. |
grandpa red Samba Member
Joined: November 23, 2018 Posts: 520 Location: Hollister,Ca.
Posted: Wed Oct 30, 2019 1:50 pm Post subject: Re: CB “racing gland nut” |
I know what your saying...that tool is not cheap but works good. _________________ '72 Beetle |
KROC Samba Member
Joined: February 20, 2006 Posts: 359 Location: Vancouver B.C.
Posted: Wed Oct 30, 2019 1:51 pm Post subject: Re: CB “racing gland nut” |
67 Sunroof wrote: |
No big deal. But.
Manufactured from chromoly steel to provide the strongest gland nut available. The extra large thrust surface helps hold the flywheel firmly against the crankshaft to prevent loose dowel pins and oil loss. The increased diameter has better holding power than stock gland nuts. Complete with inner needle bearing and special grease seal. You can use Racing Gland Nuts with stock or lightweight flywheels with 4 or 8 hole pattern. Each Racing Gland Nut is sold with a hardened steel thrust washer for added strength and holding power. For use on all 40hp, 1300, 1500 and 1600cc based engines.
Requires 1 1/2" socket. |
Glenn Mr. 010
Joined: December 25, 2001 Posts: 76940 Location: Sneaking up behind you
W1K1 Samba Member
Joined: March 04, 2004 Posts: 4921 Location: Southern AB
Posted: Wed Oct 30, 2019 3:09 pm Post subject: Re: CB “racing gland nut” |
Quote: |
My torque master tool tool I bought to tighten down the gland nut is also 36mm. Haha. |
simple fix. I have 3 different gland nut "tools" for the torquemeister. I never seem to buy the same size gland nut.
buy a cheap socket for the size you need, weld an axle nut on the top, trim the length so it fits in the torquemeister when mounted on the engine case. _________________ http://www.thesamba.com/vw/archives/manuals/jim_martin_engine_build.php
1973 super
1965 squareback 1500E
1971 bay window westy- subi swap |
Posted: Wed Oct 30, 2019 3:24 pm Post subject: Re: CB “racing gland nut” |
It’s the little things that always bite you in the ass...not exactly hit me but slowed my progress. I appreciate your suggestions. The torque meister is awesome!!! |
Zundfolge1432 Samba Member
Posted: Wed Oct 30, 2019 5:57 pm Post subject: Re: CB “racing gland nut” |
Back In the old days we used these, but they are limited by size as the socket is welded on. Unbreakable tool steel not cast will last forever.. left side is 41mm and right side 36mm.
Glenn Mr. 010
Posted: Wed Oct 30, 2019 6:03 pm Post subject: Re: CB “racing gland nut” |
Yup....
_________________ Glenn
Member #1009
#BlueSquare |
Mikedrevguy Samba Member
Joined: October 15, 2008 Posts: 2240 Location: Medford, OR
Posted: Wed Oct 30, 2019 6:04 pm Post subject: Re: CB “racing gland nut” |
Weld a axel nut to the 1 1/2” socket, and use the torquemeister as usual. _________________ 74 1303 (RevBug): plan for German Look
76 914 with 2260
79 VW Iltis
69 Bwajaja
"The wise speak because they have something to say; while the foolish speak because they have to say something." Plato
Illigitimi non-Carborundum!! |
modok Samba Member
Posted: Wed Oct 30, 2019 6:11 pm Post subject: Re: CB “racing gland nut” |
i used to weld sockets to stuff, but these days I mostly don't anymore.
A socket is most useful as a socket.
But....I will weld a tube to an extension, this makes a great low cost breaker bar, that has proven SUPER handy. Two can be connected to form a tee handle.
Connect a torque wrench to make a tee handle that gives 2x torque setting for large lug nuts.
Weld another extension at the end of the handle, also makes 2x torque wrench multiplier. (Must be same effective length as torque wrench in both cases)
Depends WHERE you are in the game.
Still tooling up, or, tooling down (re-tired) |
vwracerdave Samba Member
Joined: November 11, 2004 Posts: 15309 Location: Deep in the 405
Posted: Wed Oct 30, 2019 6:25 pm Post subject: Re: CB “racing gland nut” |
I only buy the Gene Berg gland nut and I only have one tool. _________________ 2017 Street Comp Champion - Thunder Valley Raceway Park - Noble, OK
Glenn Mr. 010
Posted: Wed Oct 30, 2019 6:26 pm Post subject: Re: CB “racing gland nut” |
Member #1009
#BlueSquare |
Posted: Wed Oct 30, 2019 7:39 pm Post subject: Re: CB “racing gland nut” |
Think I’m gonna go with the Berg. It the right size so I can use both my 36mm socket, torque wrench, and my torque meister thingy.
I “can” weld but not too confident in my ability. If that bitc! breaks it would suck!! |
Dan Ruddock Samba Member
Joined: October 25, 2012 Posts: 3594 Location: Sarasota, in my adopted state of Florida
Posted: Wed Oct 30, 2019 8:37 pm Post subject: Re: CB “racing gland nut” |
67 Sunroof wrote: |
Yep the Berg is a quality piece. All I will use.
Dan |
Paul Jr Samba Member
Posted: Thu Oct 31, 2019 2:35 pm Post subject: Re: CB “racing gland nut” |
Posted: Thu Oct 31, 2019 2:37 pm Post subject: Re: CB “racing gland nut” |
That’s awesome. How would torque specs apply in that case? How would you torque it down? |
BFB Samba Member
Posted: Thu Oct 31, 2019 3:35 pm Post subject: Re: CB “racing gland nut” |
i read a book and cant remember which one now, couldve been the " how to keep your vw alive" as it has some really cool simple ideas. anyhow it was talking about torquing the gland nut and an easy way to figure your foot lbs. if you have a 200lb man supporting all his weight on a 1 ft bar thats equal to 200 ft lbs , make it a 2 ft bar and thats 400 ft lbs, etc etc...
i tried this on the last engine i built ( im about 220 ) with a 2ft breaker bar. so if this is correct that wouldve been 440 ft lbs. after that i hit the gland nut with my 1/2" impact rated at 400 lbs on 600lbs off and it wouldnt tighten the gland nut anymore than what it was. |
DurocShark Samba Member
Joined: April 05, 2004 Posts: 6624 Location: Crappy town in a crappy state. But the beach is nearby, so I have that going for me.
Posted: Thu Oct 31, 2019 5:34 pm Post subject: Re: CB “racing gland nut” |
richardcraineum wrote: |
Impact ratings are usually BS. Your body weight at a given length works fine. _________________ No boom today. Boom tomorrow. There's always a boom tomorrow. |
Posted: Thu Oct 31, 2019 8:18 pm Post subject: Re: CB “racing gland nut” |
Yep that’s where it was from.
Muir had a backyard bare bones approach that just worked.
He also had a hilarious way to explain it. His book was entertaining as well as educating. |
TomSimon Samba Member
Posted: Fri Nov 01, 2019 6:04 am Post subject: Re: CB “racing gland nut” |
W1K1 wrote: |
buy a cheap socket for the size you need, weld an axle nut on the top of that cheap socket, trim the length so it fits in the torquemeister when mounted on the engine case. |
Yes! ^^^^^^^^ This!
works fantastic
I just flip the torquemeister's pinion gear around tot he brake drum removal side, which accommodates my socket/axle nut weldment _________________ 2-time NASA Pro Racing Champion, Bonneville 130 Club and 150 Club Memeber, BRS Pro Gas racer |
