harrymarlin Samba Member
Joined: June 07, 2018 Posts: 720 Location: Washington, DC
Posted: Thu Oct 31, 2019 5:31 am Post subject: Cadmium plating? |
I'm looking to get my original fender bolts replated - does anyone have a recommendation for a shop that does small batches for cadmium plating? _________________ -Harry
1967 Ruby Red Convertible Beetle ("Becky")
ISO Albuquerque "Imported Motors" dealership paraphernalia |
Evil_Fiz Samba Member
Joined: May 06, 2011 Posts: 1045 Location: Jacksonville, FL
Posted: Sat Nov 02, 2019 8:13 am Post subject: Re: Cadmium plating? |
Do a search on the site. I know there are several references to plating companies in the Ghia forum but I cannot remember the specic thread names.
Emil _________________ “…It's not just about what's interesting. It's also about what's helpful, and it's helpful even if it helps just one other guy working on a Ghia.”
kiwighia68
See my build on TheSamba at:
The K_R_A_K_E_N_N : a 70 Ghia Convertible reinterpreted |
Posted: Mon Nov 04, 2019 1:19 pm Post subject: Re: Cadmium plating? |
Evil_Fiz wrote: |
Do a search on the site. I know there are several references to plating companies in the Ghia forum but I cannot remember the specic thread names. |
I appreciate the suggestion. I did do a search on the site, but was unable to find recommendations for a cadmium plater, other than "do it yourself" kit manufacturers. If you can remember the specific thread which describes a recommended plater (or even the name of the plater), I would appreciate it! _________________ -Harry
Mike Fisher Samba Member
Joined: January 30, 2006 Posts: 17968 Location: Eugene, OR
Posted: Mon Nov 04, 2019 5:27 pm Post subject: Re: Cadmium plating? |
Buy a kit from Eastwood etc & do your own plating at home where they won't get lost! _________________ https://imgur.com/user/FisherSquareback/posts
69 FI/AT square Daily Driver
two 57 oval ragtops sold
'68 Karmann Ghia sold
Posted: Mon Nov 04, 2019 8:42 pm Post subject: Re: Cadmium plating? |
Thanks - it does look like that particular place does only zinc plating, but it may be they do cadmium plating, but just don't list it (like the place I've ended up going to, King of Trim). I understand cadmium is a bit less environmentally friendly, so not as many places do it, but cadmium plating is 2x more corrosion resistant than zinc, so it's great for fender bolts (what I'm doing) or pan bolts, like original.
I only wish the place I'm using did "gun metal gray" color cadmium plating. I'm having to do silver. Oh, well... it will gray out as it oxidizes, until it eventally looks almost black, like parts of my original bolts look now..
The only reason I didn't decide to do the kits is my fear of having a thin or uneven plating. _________________ -Harry
panicman Samba Member
Joined: December 18, 2011 Posts: 2290 Location: Canby, OR
Posted: Tue Nov 05, 2019 9:11 am Post subject: Re: Cadmium plating? |
I considered different finishes for my fender bolts, but ultimately paid about $20 to set up my own zinc plating kit. It works fast, you can re-strike the part many times if you want to build up thickness, and in the end it is actually fun.
Here is a link to the thread I started:
https://www.thesamba.com/vw/forum/viewtopic.php?t=605517&highlight=zinc
When you’re done, you discard a solution of salt, sugar, and basically Moss Out.
Not as environmentally unfriendly as other plating options. _________________ Plate of shrimp |
Posted: Tue Nov 05, 2019 11:05 am Post subject: Re: Cadmium plating? |
panicman wrote: |
I considered different finishes for my fender bolts, but ultimately paid about $20 to set up my own zinc plating kit. It works fast, you can re-strike the part many times if you want to build up thickness, and in the end it is actually fun. |
That sounds cool. I think I'll go order one and play around with it. Thanks! _________________ -Harry
