obus Samba Member
Joined: March 08, 2001 Posts: 11071 Location: just off Garden State Parkway Exit 81
Joe 20 Samba Member
Posted: Tue Nov 05, 2019 8:18 pm Post subject: Re: Glove box light placement |
A: mount it
B: remove it
C: check it regularly
problem solved |
Semper_Dad Samba Member
obus Samba Member
Rev. Scott Samba Member
Joined: June 04, 2006 Posts: 770 Location: Philo, Ca.
Posted: Wed Nov 06, 2019 1:13 pm Post subject: Re: Glove box light placement |
Do any of us actually use that light? There is a relocation bracket available...TTS maybe? It might actually be more functional under the dash...when was the last time time you actually used a map? I say put it in a box and save it for a purist. _________________ "I haven't seen one of those since I was shootin' at 'em!" |
mondshine Samba Member
Joined: October 27, 2006 Posts: 2770 Location: The World's Motor Capital
Posted: Thu Nov 07, 2019 6:30 am Post subject: Re: Glove box light placement |
My glove box light, radio, and garage door opener are all powered by a relay that is triggered by the SU contact on the ignition switch.
Normally, the SU contact is used to power a door buzzer on '70's VW's when the key is in the ignition switch. This feature is not applicable to Things, but it is very useful when re-purposed this way. On Things, terminal SU provides +12V when the key is in the ignition. It is a simple matter to install a .110 disconnect terminal (with locking tab) into the vacant SU cavity of the ignition switch plug.
Passengers would bump the glove box light, switching it on, and in bright daylight, it would go un-noticed. Additionally, I can listen to the radio, or open my garage door with the key in the ignition, but the ignition switched off. Here's a sketch:
obus Samba Member
vwwestyman Samba Member
Joined: April 24, 2004 Posts: 5688 Location: Manhattan, Kansas, USA
Posted: Fri Nov 08, 2019 7:38 am Post subject: Re: Glove box light placement |
mondshine wrote: |
I thought about doing that when I installed my new ignition switch a couple months ago, and wish I had gone ahead and done it!
I suppose it probably isn't all that hard to pop the wiring harness of the bottom of the switch without completely undoing everything.
I also should try to fix up that light. It is currently a rusted mess.
Nice diagram, btw.
How did you set up your garage door opener? I like that idea; I keep an opener in one of my Buses, and never remember to lock it, so really things aren't all that secure should someone decide to look inside the Bus and see the opener... _________________ Dave Cook
1973 Wild Westerner
My Thing |
Posted: Fri Nov 08, 2019 8:53 am Post subject: Re: Glove box light placement |
westyman-
My garage door transmitter used a small (weird) 12V battery, so it was easy to just bypass the switch with a momentary pushbutton (mounted in a discreet location).
Many garage door transmitters require ~3 volts, but a simple $2 DC step down buck would reduce the car's 12V to whatever is required by your transmitter (just check the battery in the transmitter). |
Posted: Fri Nov 08, 2019 9:35 am Post subject: Re: Glove box light placement |
mondshine wrote: |
westyman-
So did you just take the remote and stash it somewhere in the Thing out of the way, and basically wire your own button in the circuit, replacing the garage door opener button? Genius! _________________ Dave Cook
1973 Wild Westerner
My Thing |
Posted: Fri Nov 08, 2019 10:21 am Post subject: Re: Glove box light placement |
westyman-
I took the transmitter apart.
Mine contained a simple circuit board about 1" x 2".
Once wires were soldered to the battery contacts and across the switch (so that the switch is always "on"), I use a momentary pushbutton switch to power the transmitter. The whole thing fits inside a 3" length of 1" heat shrink tube with two wires sticking out of one end. One wire goes to ground, and the other wire goes to the switch. |
