ClareSutton Samba Member
Joined: December 05, 2004 Posts: 465 Location: Sarnia Ontario
Posted: Wed Nov 06, 2019 6:29 pm Post subject: Bleeding clutch with brakes |
I have been reading through the forum on "brake bleeding" and many times it is mentioned to bleed the clutch along with the 4 wheels on a standard. If my clutch is working fine, do I really have to bleed it with the 4 wheels when trying to remove air from the brake lines (soft brakes)? It doesn't say to do this in the Bentley. |
MarkWard Samba Member
Joined: February 09, 2005 Posts: 17122 Location: Retired South Florida
Posted: Wed Nov 06, 2019 6:38 pm Post subject: Re: Bleeding clutch with brakes |
No you don’t need to bleed the clutch. It is a good time to since both masters share the same fluid reservoir. _________________ ☮️ |
Posted: Wed Nov 06, 2019 6:50 pm Post subject: Re: Bleeding clutch with brakes |
Thanks, Mark. That's what I thought. Just wanted to hear it from someone else. |
bkleysteuber Samba Member
Posted: Sat Dec 03, 2022 11:10 am Post subject: Re: Bleeding clutch with brakes |
I have a Bentley repair manual, thru year 1987, an on page 30.2/3, Clutch Controls, it addresses the requirement to replace the brake fluid every two yrs. This is the same period of time that is recommended for the brakes and for the same reason, brake fluid absorbs moisture from air. This moisture will rust the internal components of the brake/clutch system.
Additionally, the manual, pg 30.2, under Bleeder screw, states to “pressure bleed” the system. Here is my experience with bleeding the clutch system. On a ‘91 Passat I thought I could gravity feed and then pump the clutch to purge the clutch system following a major rebuild of the engine.. I burnt up two clutches in the process because there was still air in the system, clutch plate would pulsate. On my ‘86 westy, my clutch slave cylinder rusted out causing clutch failure even though I bleed the system at the same time as my brakes (every two years, of course) using the gravity and pump method for brakes and clutch. When I PRESSURE bleed the clutch system, after my normal way of bleeding, I was surprised at how rusty and dirty the fluid in the slave cylinder was.
Although Bentley, pg 47.8, same manual, thru ‘87, does not specify to use a pressure bleeder for the brakes, I use the pressure bleeding procedures for the clutch and brakes. I then use the old pump up the brakes and release the pressure thru fluid release at each wheel cylinder, method. By the way, the order to bleed the brakes is shown on the same page, 47.8, i.e., start with the wheel that is the farthest from the brake master cylinder and work towards the closest wheel, left front. I hope this helps. I’m new to the forum and don’t know how to use pictures yet. |
Ahwahnee Samba Member
Joined: June 05, 2010 Posts: 9800 Location: Mt Lemmon, AZ
Posted: Sun Dec 04, 2022 12:54 pm Post subject: Re: Bleeding clutch with brakes |
bkleysteuber wrote: |
...Additionally, the manual, pg 30.2, under Bleeder screw, states to “pressure bleed” the system... |
A simple yet effective pressure bleeder can be fashioned using a bucycle tire inner tube:
pathao Samba Member
Joined: November 01, 2012 Posts: 291 Location: Montreal, Canada
Posted: Tue Dec 06, 2022 10:57 am Post subject: Re: Bleeding clutch with brakes |
Ahwahnee wrote: |
Great MacGyver stuff
I think it does belong to be mentioned in this thread https://www.thesamba.com/vw/forum/viewtopic.php?t=774889
(I hope you didn't mind that I added a link into it myself) _________________ 1982 AC P27 - 2.0 FI FED - 091 - BA6
English is a second language to me
valvecovergasket Samba Member
Posted: Tue Dec 06, 2022 11:16 am Post subject: Re: Bleeding clutch with brakes |
MarkWard wrote: |
No you don’t need to bleed the clutch. It is a good time to since both masters share the same fluid reservoir. |
x2
and you already have all your bleeding tools out, may as well _________________ MegaSquirt resource - SpitfireEFI.com
gone, but not forgotten: '83 tdi westy - swap thread |
LobWedge Samba Member
Posted: Sun Feb 19, 2023 12:46 pm Post subject: Re: Bleeding clutch with brakes |
Ahwahnee wrote: |
Impressive! Please describe the process for this. Thanks. _________________ '91 Westy |
