mtsipe Samba Member
Joined: June 22, 2016 Posts: 86 Location: Wilmington, Delaware
Posted: Fri Nov 08, 2019 1:29 pm Post subject: 2000 GTI - Check Engine Light - code P0442 - small evap leak |
I have a 2000 GTI VR6. My check engine light came on and code P0442 small evap leak came up. I pulled the purge valve off near Power steering fluid reservoir and as per my mechanic’s advice that with the engine off, I should not be able to blow through it. I could not blow through, so I know my purge valve is closed and works. I smoked it at that point and couldn’t see any leaks.
Next, with the rear right fender wheelwell off with access to the charcoal canister, I smoked it at the fuel tank. With it completely sealed at the fuel cap opening, no smoke was escaping. I tightened the gas cap and light was still on after days of driving.
Next I replaced the gas tank cap. If the cap is the problem, How long should I have to drive for the light to go off?
Any advice would be greatly appreciated. Thanks
pondoras box Samba Member
Joined: March 22, 2004 Posts: 1220 Location: Eerie PA
Posted: Fri Nov 08, 2019 2:02 pm Post subject: Re: 2000 GTI - Check Engine Light - code P0442 - small evap leak |
I had the same problem with a Honda so take into advisement, but your car has to go through three testing cycles without the code being present to turn the light off.
This took about a week of around town driving, to and from work about 15 miles each way. _________________ Looking for anything from Hal Casey Motors out of Hamburg New York, from license plate surrounds to matchbooks.
1961 23 Window (Bobo)
1965 11 Window (Zelda)
1965 13 Window (Lucas)
1957 Oval ragtop
1988 Cabriolet VR6 conversion
Plus a lot of other rusty junk |
Joined: August 31, 2013 Posts: 12850 Location: North Carolina
Posted: Fri Nov 08, 2019 2:46 pm Post subject: Re: 2000 GTI - Check Engine Light - code P0442 - small evap leak |
The light will not go off on it's own, it has to be reset. _________________ Everybody born before 1975 has a story, good, bad, or indifferent, about a VW.
kublerwagen Samba Member
Joined: February 28, 2012 Posts: 104 Location: Portland, OR
Posted: Mon Dec 09, 2019 7:50 am Post subject: Re: 2000 GTI - Check Engine Light - code P0442 - small evap leak |
Had this with my Cabrio. The seal at the fuel pump was leaking. |
