khughes Samba Member
Joined: July 13, 2013 Posts: 747 Location: Phoenix AZ
Posted: Sat Nov 28, 2020 1:38 pm Post subject: Re: 2.0 ABA Block rebuild thread thinking in turbo=) |
Butcher wrote: |
You guys are nuts! Carbs had their day and you are nuts to think throwing a turbo with carbs will make it run better.
The only time CIS or EFI has let me down was because of a worn out fuel pump or an occasional fuel pump relay. |
Where did you get the idea we're talking about carbs and turbos? I think you missed a few posts, we already discussed carbs being ill-suited for turbos. The OP has a carb system now, so that's the quickest, cheapest way to get him back on the road with a replacement setup.
But with tens, if not hundreds of millions of miles driven on carbs, kinda silly to pretend they can't work well. No, you can't play around with long duration cams, or high overlap cams and expect enough idle suction to idle worth a damn, but if the carb is sized properly to the engine and jetted to the altitude, they can and do run well. FI is better for driveability yeah, and emissions, and likely fuel economy. _________________ '86 Westy FAS GenV Turbo (Marvin) |
rogertj Samba Member
Joined: October 07, 2008 Posts: 505 Location: Tijuana, Baja California. Mexico
Posted: Mon Dec 07, 2020 9:15 am Post subject: Re: 2.0 ABA Block rebuild thread thinking in turbo=) |
I was eager to know what really happened with this engine since the last time it ran in the middle of summer.
As you already know it has taken forever to put new engine since it starting to smell like barbecue and the exhaust was like a smoker (Are we having steak? )
When I put the new engine I wouldn't want to have any problems with it that's why I checked it, just wanted to be really sure.
It turned out it had a bad distributor, I was able to find the problem testing the solenoid with the multimeter and then I confirmed it when placed my finger in the solenoid when touching the ground so you can imagine how that feels
I found that when touching the ignition module (where the rotor is seated inside the distributor) it had a clicking noise in the solenoid when the key was on, so that's how I got to know what happened (maybe, and I say maybe because in the electronics world it could be anything)
I already had that problem years ago with the ignition module so it's time for a new distributor.
I'm thinking of summit racing (does obd1 and obd2 has to be taken in to consideration?). What do you guys think? Throw some heavy lip on me!
Thanks in advance! _________________ Roger
Had a Carbureted ABA after engoing the heck out of it now going for ABA 2.0 Jetta EFI ill put a garrett in to the tin can later or maybe go electric?
https://www.thesamba.com/vw/forum/viewtopic.php?t=...mp;start=0 |
Posted: Wed Dec 23, 2020 3:12 pm Post subject: Re: 2.0 ABA Block rebuild thread thinking in turbo=) |
Can some one please send me a grass weed eater?
Fun day before Christmas Eve! _________________ Roger
Posted: Sun Jan 03, 2021 2:44 pm Post subject: Re: 2.0 ABA Block rebuild thread thinking in turbo=) |
Guys good afternoon! And happy new year!
Do you have a clue of what could cause this residue in the valves and spark plugs in the head of my tin top?
It's a 1985 jetta 1.8 head in a 2.0 block the van had possibly bad rings because it was a smoker so the cylinder had just charcoal residue but when I saw this on the head I was like 😒 wtf what is that?
Is any one have a clue of past experience?
Here are the photos
Posted: Wed Mar 10, 2021 6:41 pm Post subject: Re: 2.0 ABA Block rebuild thread thinking in turbo=) |
Well I'm back at it again, after selling the Beetle and receiving some funds for the tools that I needed the engine is out
Today we had heavy rain so everything is wet outside so have to the weather to get sunny so that I can concentrate on the engine. Today I did a little bit of more work on the harness and made my first mistake cut the wrong wire good thing I noticed it because I had a second-hand look at the photo to learn who he is (is the reason for my constant struggle and work in life)
Posted: Sun Apr 18, 2021 11:31 am Post subject: Re: 2.0 ABA Block rebuild thread thinking in turbo=) |
We are back from a 3-week vacation to Lago Chapala México specifically Ajijic wonderful place to live it's full of Americans and Canadians.
Started to put the engine in the stand and sprayed some degreaser hope to move slowly because more funding is coming our way after may.
Very inspired in uberaudis build on a lot of confusions I had to solve clearance issues. Also with exhaust resolutions.
Thanks to Vanagonut for his "manual", specially Dkoesyncro for sending me that mk3 jetta book. Thanks man I owe you one. And thanks to everyone else that has placed an answer on my thread. I appreciate it. heres some picks of the donor engine. ready to be degreased!
danfromsyr Samba Member
Joined: March 01, 2004 Posts: 15143 Location: Syracuse, NY
Posted: Sun Apr 18, 2021 2:57 pm Post subject: Re: 2.0 ABA Block rebuild thread thinking in turbo=) |
no offense to the OP
but you have enough trouble getting 'normal' engine operations to run properly for you
I would not suggest a hybrid/DIY turbo till your mechanic gets more skilled
KISS
Keep
It
Simple
Silly _________________
Abscate wrote: |
Posted: Sun Apr 18, 2021 3:36 pm Post subject: Re: 2.0 ABA Block rebuild thread thinking in turbo=) |
danfromsyr wrote: |
KISS
Keep
It
Simple
Silly |
When you say no offense to the OP we all know what does that mean. Fortunately, I do not depend on what people think, its the other way around, I put more attention on what I think about people and I do whatever is in front of me to be done. I grab the positive side of people ONLY!
In my vocabulary the Term
KISS
Means:
Keep
it
Simple
Stupid!
So now you know what to think about keeping things simple in your yard and not in mine.
By the way no offense to Dan. As I imagine that he is a gentleman and non-offense will be taken.
If you have something to add to my build youre welcome to come back and leave a positive comment
Like something about turbos lol!
Or normal operation on a 2.0 ABA
Back to the thread I'm about to measure cylinder dimension and bearing wear wish me luck because I saw some crusty oil debris inside of the head and engine oil but it was a junkyard engine placed in the donor car with 100k miles (battery did connect to dash) so hoping for the best, if not I have plenty of time to invest in this engine but the sooner the better =) _________________ Roger
Posted: Sun Apr 18, 2021 7:56 pm Post subject: Re: 2.0 ABA Block rebuild thread thinking in turbo=) |
Hey folks after a quick nap I measured the ID of cylinders and to to my surprise they are beefy
Tomorrow I'll measure the main bearings and the rods bearings just to be really sure that we have solid internals _________________ Roger
Butcher Samba Member
Joined: December 05, 2015 Posts: 1285 Location: Right Here
Posted: Mon Apr 19, 2021 7:51 am Post subject: Re: 2.0 ABA Block rebuild thread thinking in turbo=) |
That's really not the right tool to measure a bore. It's ok to give you a ball park guess, but not that accurate. That applies to the engine bearings and journals too. |
Posted: Mon Apr 19, 2021 8:17 am Post subject: Re: 2.0 ABA Block rebuild thread thinking in turbo=) |
ups my bad, forgot to throw some samba forum porn !
I used this satellite measuring tools
Ill use some Sealed Power Plastigage made in the USA for the bearings and then clean it very well _________________ Roger
Posted: Wed Apr 21, 2021 3:30 pm Post subject: Re: 2.0 ABA Block rebuild thread thinking in turbo=) |
Made some progress today after having a ball park at the cylinders, making sure that everything is thighteng in the internals, I painted a part of the engine and placed the diesel oil pan just to motivate my self
Looking good! (I think I overkilled the silicone on the front crankshaft seal I would appreciate comments here my friends)
Posted: Sat May 01, 2021 3:44 pm Post subject: Re: 2.0 ABA Block rebuild thread thinking in turbo=) |
Progress! Not perfection
As for my boy... He is having a nap to much thinking with the harness lol! _________________ Roger
Posted: Sat May 15, 2021 9:39 am Post subject: Re: 2.0 ABA Block rebuild thread thinking in turbo=) |
Head is here! Things are getting interesting!
Vanagon Nut Samba Member
Joined: February 08, 2008 Posts: 10367 Location: Sunshine Coast B.C.
Posted: Sat May 15, 2021 10:11 am Post subject: Re: 2.0 ABA Block rebuild thread thinking in turbo=) |
Hey Roger.
Is that a new head?
Nice to see the progress.
1988 West DIY 50º ABA
VE7TBN |
Posted: Sat May 15, 2021 10:37 am Post subject: Re: 2.0 ABA Block rebuild thread thinking in turbo=) |
Vanagon Nut wrote: |
Hey Roger.
Is that a new head?
Neil. |
Doesn't it look new? Haha it was the donor cars head it was a good job by the machine shop the last job they did in mine lasted 8 years in my engine full reboard (is that the word)
Thanks for your visit come by more often _________________ Roger
dkoesyncro Samba Member
Posted: Sun May 16, 2021 6:36 am Post subject: Re: 2.0 ABA Block rebuild thread thinking in turbo=) |
Good to see you're making progress, keep that ball rolling!
Are you using obd1 wiring harness? If so, A2resource has an excellent color copy schematic...super simple to follow, clear down to wiring up the relays. |
Posted: Sun May 16, 2021 6:58 am Post subject: Re: 2.0 ABA Block rebuild thread thinking in turbo=) |
dkoesyncro wrote: |
Yes OBD1, Thanks Dillon yeah that schematic is great I have it on 11.5 x 16 lol!!! and with plastic!
I'm getting there on the relay connections I'm right now as we speak soldering all wires because the harness was excessive too long I cut it down to 55" +/- but I left all connectors long and also relays very long I'm deciding were should I put the relays, I'm more towards the bench seat as they will remain without humidity _________________ Roger
MarkWard Samba Member
Joined: February 09, 2005 Posts: 17109 Location: Retired South Florida
Posted: Sun May 16, 2021 7:00 am Post subject: Re: 2.0 ABA Block rebuild thread thinking in turbo=) |
Are you fabricating a custom intake? Still planning to turbo charge? _________________ ☮️ |
Posted: Sun May 16, 2021 7:17 am Post subject: Re: 2.0 ABA Block rebuild thread thinking in turbo=) |
MarkWard wrote: |
Are you fabricating a custom intake? Still planning to turbo charge? |
The Peny has forced me to first go Stock EFI and about the Intake I was thinking on Europen intake from an Audi A4 (B5) 1.6
Part 050133223D
Engine capacity
1,595 cc
Engine code
AHL
Saloon, 4-dr, Petrol, 1.595cc, 74kW (101pk), FWD, ADP; AHL; ANA; ARM, 1994-11 / 2000-10, 8D2
The one that Dkoesyncro (Dillon) used but still dont know if I will have to adapt new fuel injectors (stock) and fuel rail or if the EDIT: Throtle body - will fit I think it does... I guess this is a question for Dkoesyncro _________________ Roger
