BulliBill Samba Member
Joined: July 09, 2004 Posts: 4573 Location: St Charles, MO
Posted: Wed Nov 13, 2019 8:11 am Post subject: Odd mounting bracket for 25- or 30bhp thermostat |
I'm putting together the last items to complete a spare mid 1952 25 hp engine and I've run into an odd mounting bracket for the thermostat on an early engine of some sort. In most respects it is an original 25- or 30bhp thermostat bracket except this bracket has a factory spot welded extra arm (see photos). As you can see, I've tried to mount it on a 36hp crankcase I have here and that added bracket will not fit between the inner two pushrod bosses. I'm guessing this is maybe for a Porsche crankcase? What else could this fit?
The odd bracket is on the left
If I cover up the added-on part of the bracket, you'll see that the remainder is exactly like the normal bracket we all know and adore!
You can just see the four factory spot-welds that attach the add-on bracket piece...
When I tried to fit it to a 1957 VW crankcase, it lines up well with the lower stud hole, and the upper hole in that add-on part lines up with big case stud but the whole bracket will not fit flush to the crankcase...
...nor will the add-on bracket fit between those two push-rod holes without obviously having to modify the factory bracket.
Anyway, I thought I'd put the question and a few photos of it out there and see if one of you engine guru's and puzzle solvers might have seen this oddball factory bracket before and can shed some light on what type and era of engine this odd mounting bracket was made for... I don't really want to cut the add-on arm off just to be able to use it on one of my spare 36hp engines if it fits something else.
So let us know if you know what this bracket properly fits? Thanks!
Perplexed in St. Louis...
Bill _________________ I'm looking for these license plate frames for my fleet:
Mission VW - San Fernando
Thornton VW - Stockton
Thanks for any help! |
66brm Samba Member
Joined: January 25, 2010 Posts: 3676 Location: Perth Western Australia
Posted: Wed Nov 13, 2019 3:15 pm Post subject: Re: Odd mounting bracket for 25- or 30bhp thermostat |
I remember there was a thread on these a while back, I'll see if I can find it _________________ Aust. RHD 66 Type 1
Aust. RHD 57 Type 1 Oval
modok wrote: |
I am an expert at fitting things in holes, been doing it a long time |
Posted: Sat Nov 16, 2019 11:09 am Post subject: Re: Odd mounting bracket for 25- or 30bhp thermostat |
Thanks for the reply. I hope someone can make sense of why the add-on part was added at the factory and for what models or manufacturer (VW or Porsche) it was for...
Posted: Wed Dec 11, 2019 1:00 pm Post subject: Re: Odd mounting bracket for 25- or 30bhp thermostat |
Oh damn! I found another oddball thermostat mounting bracket! WTF is this one made for? looks super beefy, looks factory made and spot-welded (not backyard cobbled-up) and seems to fit on a 36hp crankcase just fine like the later more common looking one.
The beefy one is in the foreground...
and on the right in this shot...
and in the background in this shot...
and finally on the left in this shot...
Can anyone shed any light on the correct applications for this or the initial oddball thermostat mounting brackets? Inquiring minds want to know! Thanks!
Bill Bowman _________________ I'm looking for these license plate frames for my fleet:
virtanen Samba Member
Joined: January 08, 2006 Posts: 1462 Location: Finland
Posted: Sat Dec 14, 2019 11:19 am Post subject: Re: Odd mounting bracket for 25- or 30bhp thermostat |
Mika! Thanks for the clarification on this bracket. That is great news, as I might use it on a '51 crankcase that I have a line on, that I unknowingly might have used a later style (the other bracket in the photos above) thermostat bracket for. So it is a two year bracket, ending around ???
I still don't know what the first odd bracket with the extra arm at the beginning of this "thermostat bracket" thread is for? Anyone? Anyone?
Hopefully someone can identify each version of these thermostat brackets with start and end chassis numbers and it could eventually become a FAQ "sticky" for the benefit of us all...
