94mm cut to length vs. std. 94mm
Onceler
Onceler is offline
PostPosted: Wed Nov 13, 2019 8:55 pm    Post subject: 94mm cut to length vs. std. 94mm Reply with quote
Any ideas why the head registers would be different between the 2?
I needed another set of pistons, so I went ahead and ordered a set of std. length p&cís.
The cut to length versions measure 101.25mm diameter and std. length measure 100.85mm dia.
You can see the difference in this photo (cut to length on right):
1972 Karmann Ghia
bugguy1967
bugguy1967 is offline
PostPosted: Wed Nov 13, 2019 10:53 pm    Post subject: Re: 94mm cut to length vs. std. 94mm Reply with quote
You mean the head diameter? They're usually used for apps where people are running more cylinder pressure, so AA gave us some extra wall thickess. Make sure your head fits.
"A petrol engine can start readily, run smoothly and give every appearance of being in good order, without necessarily being in good tune." - Colin Campbell, "The Sportscar Engine"
Onceler
Onceler is offline
PostPosted: Thu Nov 14, 2019 2:05 pm    Post subject: Re: 94mm cut to length vs. std. 94mm Reply with quote
Well that seams like a good idea, but slightly annoying that itís not mentioned in any of the spec.ís Iím aware of
1972 Karmann Ghia
mark tucker
mark tucker is offline
PostPosted: Thu Nov 14, 2019 2:51 pm    Post subject: Re: 94mm cut to length vs. std. 94mm Reply with quote
I wood prefur the thicker ones....
Onceler
Onceler is offline
PostPosted: Thu Nov 14, 2019 6:33 pm    Post subject: Re: 94mm cut to length vs. std. 94mm Reply with quote
Any issues with boring these heads out further? They are already broken through to the fin area.
1972 Karmann Ghia
bugguy1967
PostPosted: Fri Nov 15, 2019 2:01 pm    Post subject: Re: 94mm cut to length vs. std. 94mm Reply with quote
You gotta do what you gotta do. It won't hurt anything.
Onceler
Onceler is offline
PostPosted: Fri Nov 15, 2019 5:41 pm    Post subject: Re: 94mm cut to length vs. std. 94mm Reply with quote
I figured so, but thought I better ask the experts. Thanks
1972 Karmann Ghia
