Eurovan Dometic RC 1140 replacement?
Forum Index -> Eurovan Share: Facebook Twitter
volkybus
volkybus is offline
PostPosted: Sat Nov 16, 2019 6:20 pm    Post subject: Re: Eurovan Dometic RC 1140 replacement? Reply with quote
i have a used one 4a 93 4 $500..I have a 5 speed in mine so no need for it. the van has 143k miles good luck...
1961tbird
1961tbird is offline
PostPosted: Sat Nov 16, 2019 6:08 pm    Post subject: Re: Eurovan Dometic RC 1140 replacement? Reply with quote
I believe I saw a direct factory replacement in Germany. Wasn't cheap though. Unfortunately, I misplaced the link.
prairieox
prairieox is offline
PostPosted: Thu Nov 14, 2019 8:55 pm    Post subject: Re: Eurovan Dometic RC 1140 replacement? Reply with quote
Or should I leave it as-is and just buy a portable 12V fridge like a Dometic CFX?
prairieox
PostPosted: Thu Nov 14, 2019 9:45 am    Post subject: Eurovan Dometic RC 1140 replacement? Reply with quote
hi there, my 1995 Eurovan, the Westfalia one with the top load Dometic RC 1140 fridge, has stopped working. The controller seems fine, no flashing or anything, and the fuses check out.
It seems to just not be running. The repair shop says they need to take it out but it might cost me as much as $400 to fix.
Any experience with this? Other option is to look at replacement but is there a fridge that will fit in the same spot?
My concern is paying quite a bit and then it fails again and I wonder if replacement is the better route to go?
Thanks!
Reply to topic    Forum Index -> Eurovan All times are Mountain Standard Time/Pacific Daylight Savings Time
