Marcdeb Samba Member
Posted: Tue May 19, 2020 1:10 pm Post subject: Re: Looking for help in the Denver Colorado area.... |
I've only been on TheSamba about 6 months and I just now found this thread. I don't mean to resurrect it but I had a similar, much more costly experience, so here's my 2 cents worth in case it helps anybody.
I feel for you! You really did everything possible to evaluate the car. You did everything right. It's unfortunate that some people can be so dishonest. I was intentionally misled about the condition of the car I bought. I did some homework, but I should have done way more. I knew better, but the seller had credentials that seemed safe - my bad judgement. Not easy to swallow at first.
I've moved on. I have and will continue to do anything I can to warn others about the seller in my case. But life is too short. We have to enjoy each day. Know that you are a better person than the low life who felt he had to ruin your day in order to make his better. _________________ Marc
71 Karmann Ghia Cabrio
Previously Owned:
2011 VW EOS Hard Top Conv
2008 Saab 9-3 2.0T Conv
2003 Saab 9-3 SE Conv
2001 Saab 9-3 Conv
1998 BMW 3 Series Conv
1997 Saab 900 Conv
1997 Mazda Miata
71 Ghia Vert Restoration: https://www.thesamba.com/vw/forum/viewtopic.php?t=726710&postorder=asc |
HMVWNAB Samba Member
Joined: September 23, 2006 Posts: 1089 Location: Sunshine State
Posted: Tue Dec 03, 2019 1:41 pm Post subject: Re: Looking for help in the Denver Colorado area.... |
Of course you can always out the offending party on the good ol’ net to make any other prospective victims aware of the sellers shady practices, much like the feedback feature here.
Wouldn’t be the first time someone was shredded. _________________ What are the last 2 words of the National Anthem?
PLAY BALL! |
Mickey bitsko Samba Member
Joined: June 13, 2019 Posts: 511 Location: New Mexifornia
Posted: Tue Dec 03, 2019 5:32 am Post subject: Re: Looking for help in the Denver Colorado area.... |
Move on, small claims tough to collect even if you win.
Just throwing good money after bad. |
ach60 Samba Member
Joined: May 14, 2001 Posts: 4139 Location: Santa Maria
Posted: Tue Dec 03, 2019 3:14 am Post subject: Re: Looking for help in the Denver Colorado area.... |
mauibarber wrote: |
New Motor, $3500
Attorney Fees after you win, $7000 |
True, cut your losses, and move on with life.
Yes it sucks, but that's life. _________________ Good Luck
Al |
wheel607 Samba Member
Posted: Fri Nov 22, 2019 1:07 pm Post subject: Re: Looking for help in the Denver Colorado area.... |
You had a PPI done and it doesn't matter subsequent to that. Last document in standard. In your mind (only) you were wronged. This is just real world advice. As someone stated earlier, it will cost you $7000 to win a $3500 civil case. Or go to small claims court where you will loose because of time. Hard pill to swallow, but without costly representation, it is what it is. |
EverettB Administrator
Joined: April 11, 2000 Posts: 69824 Location: Phoenix Metro
mauibarber Samba Member
Joined: January 30, 2009 Posts: 72 Location: Fort Collins, Colorado
Posted: Fri Nov 22, 2019 8:59 am Post subject: Re: Looking for help in the Denver Colorado area.... |
New Motor, $3500
Attorney Fees after you win, $7000 _________________ -Alex |
moogie32 Samba Member
Joined: April 06, 2005 Posts: 663 Location: Connecticut
Posted: Fri Nov 15, 2019 11:07 am Post subject: Re: Looking for help in the Denver Colorado area.... |
I'd agree with you except the documentation I was given at the time of inspection said the engine had been rebuilt . It was the incorrect invoice for the work done. If the seller had given me the invoice that actually was for the car I would have seen the mechanic noted cam wear and pitting and that no action had been taken by the owner at that time to fix it. So, even though I flew to Denver to inspect and drive the car and had a PPI done by someone conversant in the field without the correct invoice we had no way of knowing that the total rebuild the seller described in the ad for the car had not really happened at all. If I had seen "cam wear" on the invoice I was given I would have factored a rebuild into the offer for the car. After it was delivered I put 60 miles on the car when it started having unrelated hesitation problems. When my mechanic was tuning it he heard noises at #3 cylinder when he pulled the wire from it and that's what made him tear down the engine....
The only reason I have the correct invoice at all is that the seller threw the mechanic under the bus for all of this and gave me his contact info. That's when the invoice issue came to light. But buyer beware - absolutely - I did everything right and now am stuck dealing with this mess. _________________ RIP HBB (1984-2009)
Du liefst so gut
Du warst so schön
Doch leider musst du von uns gehn |
djkeev Samba Moderator
Joined: September 30, 2007 Posts: 32625 Location: Reading Pennsylvania
Posted: Thu Nov 14, 2019 7:03 pm Post subject: Re: Looking for help in the Denver Colorado area.... |
specifically it involves misrepresentation of a motor vehicle's condition - in this case a supposedly restored engine that now needs a total rebuild - documentation that was offered up (eg invoice for the work done) at the time of inspection was in fact for a different car. If the correct invoice had been made available I would have known the short block showed cam wear and the owner had elected to do nothing about it. _________________ RIP HBB (1984-2009)
Du liefst so gut
Du warst so schön
jspbtown Samba Member
Posted: Thu Nov 14, 2019 1:24 pm Post subject: Re: Looking for help in the Denver Colorado area.... |
You might need to be a little more clear. "Vintage car cases" is not really an specific area of focus. |
Posted: Thu Nov 14, 2019 12:27 pm Post subject: Looking for help in the Denver Colorado area.... |
..to help me find an attorney, preferably one who is a known quantity and has experience dealing with vintage car related cases.
Really appreciate any leads - thanks!
Diane _________________ RIP HBB (1984-2009)
Du liefst so gut
Du warst so schön
