67 Sunroof Samba Member
Joined: February 22, 2014 Posts: 1836 Location: Salisbury, MD
Posted: Fri Nov 15, 2019 7:32 am Post subject: Endplay on newly rebuilt 71 case |
.004 or .005?
Setting it today and googled and got all kinds of answers.
1776 dual port. New crank, flywheel, bearings, etc. rods not installed. Distributor drive gear not installed. Pulley not installed.
Case tightened down to spec with internals
Check out my procedure:
Using a Dial gauge on the flywheel.
Torque flywheel to 200ft lbs
Measure endplay
Find a 3 shim stack (unoiled) that measures the endplay minus .005
Reinstall
Remeasure endplay
Sound about right?
Here is what I am at now. Between .004 and .005.
Is this fine? First try on the shim stack I selected!! Good luck? Maybe I should play the lottery?
jsturtlebuggy Samba Member
Posted: Fri Nov 15, 2019 8:22 am Post subject: Re: Endplay on newly rebuilt 71 case |
Factory spec for endplay is .0027-.0051" on a stock engine, with a wear limit of .006"
With a high performance engine setting to the high side of clearance more common to allow for higher temp some experience.
Torque spec for gland nut minimum of 217 ft lbs. I torque stock gland nuts to 250 ft lbs and chromoly ones to more. _________________ Joseph
Elrod Motorsports
Motion Tire Motorsports
Into Volkswagens since 1960 |
Posted: Fri Nov 15, 2019 8:52 am Post subject: Re: Endplay on newly rebuilt 71 case |
I torqued the berg nut to 230ft/lbs according to my torque meister tool. That thing is a fantastic little tool!!!
(Set torque wrench to 25ft/lbs) |
Joined: August 15, 2002 Posts: 4394 Location: Brew City
Posted: Fri Nov 15, 2019 9:08 am Post subject: Re: Endplay on newly rebuilt 71 case |
67 Sunroof wrote: |
.004 or .005?
Measure endplay
Reinstall
Remeasure endplay
Sound about right?
PLEASE torque the flywheel to 250ft/lbs.
It makes no difference between .004" and .005" _________________ Please "LIKE" us on facebook to see what we are working on.
https://www.facebook.com/mofoco?ref=ts&fref=ts
www.mofoco.com
Cylinder Head Reference Sheet |
Posted: Fri Nov 15, 2019 9:26 am Post subject: Re: Endplay on newly rebuilt 71 case |
230 is plenty for setting endplay right???? Its going to be more like 400 once I finalize assembly. |
Posted: Fri Nov 15, 2019 10:14 am Post subject: Re: Endplay on newly rebuilt 71 case |
67 Sunroof wrote: |
Absolutely not. When you set the end play, you MUST torque the flywheel to the same ft/lbs as you are going to when you assemble the motor.
As for 400ft'lbs......that is WAY overkill for your engine. IF you are building a 200HP dragrace engine, then absolutely torque it to 400ft/lbs. I have been building 60hp to 175hp street performance engines for 30 years with over 2000 builds and I have never torqued a flywheel past 250ft/lbs, never used loctite and never had one come loose. _________________ Please "LIKE" us on facebook to see what we are working on.
www.mofoco.com
chrisflstf Samba Member
Joined: February 10, 2004 Posts: 3446 Location: San Diego
Posted: Fri Nov 15, 2019 12:29 pm Post subject: Re: Endplay on newly rebuilt 71 case |
Has anyone actually measured any difference in end play with the nut torqued to 50, 100, or 250 ft lb? |
Posted: Fri Nov 15, 2019 12:56 pm Post subject: Re: Endplay on newly rebuilt 71 case |
Not to question your ability Roy as I very much respect your comments and very much APPRECIATE the help and time you give to help us here on the forum...
But it dont feel the endplay will change between 230ft/lbs and 250ft/lbs as the flywheel is already seated on the crank and dowel pins right?
Anything over that point you are just stretching the threads on your gland nut or crankshaft or both right?
What changes between 250ft/lbs and 400ft/lbs should be the real question!!?? |
ach60 Samba Member
Joined: May 14, 2001 Posts: 4139 Location: Santa Maria
Posted: Fri Nov 15, 2019 7:39 pm Post subject: Re: Endplay on newly rebuilt 71 case |
67 Sunroof wrote: |
Because "You Test Like You Fly" _________________ Good Luck
Al |
Posted: Fri Nov 15, 2019 8:48 pm Post subject: Re: Endplay on newly rebuilt 71 case |
Annnnnnd that means what? |
RWK Samba Member
Posted: Sat Nov 16, 2019 9:01 am Post subject: Re: Endplay on newly rebuilt 71 case |
Torque applied to assembly shouldn't matter in theory, the gap between the crank and flywheel is fixed when it is assembled properly, period! if it changes during tightening, something is wrong, factory did it the measurement way and shimmed accordingly based on the gap less main bearing thickness, and I believe that the crank,bearing ,shims and flywheel were assembled before, and dropped into split case. The reason we do it on rebuilds is nothing is perfect on a used engine and the torque helps seat bearing and hopefully make it more consistent, squish bearing, allow for bent dowels,dirt,crank to flywheel seat not parallel, ect. IMHO 100-125 flbs or so should be enough to check, I would check it a couple times (R&R) to ensure you get the same readings, mounting in the same position of course. _________________ 73 Type 181
63 Type 113
63 Type 261- 428 071
62 Type 241-378 025 178 530 |
