volkswouter Samba Member
Joined: March 25, 2003 Posts: 450 Location: The Netherlands
Posted: Tue Nov 19, 2019 11:20 am Post subject: Need help dating an engine case? |
The number mentioned on the case makes me doubt when this was produced.
What i want to know if this case in the aluminium one.
Anyone tips how to recognise one?
VW stopped using Aluminium on 19-01-1951.
gatorwyatt Samba Member
Joined: April 24, 2002 Posts: 1867 Location: Clearwater Fl.
Posted: Tue Nov 19, 2019 12:51 pm Post subject: Re: Need help dating an engine case? |
I believe the aluminum cases have a thinner case half flange than a 36hp magnesium case. Pull the pulley and compare it. _________________ www.blastserv.com
wanted:
RHD Barndoor floor mat..reproduction is fine |
djfordmanjack Samba Member
Joined: June 15, 2009 Posts: 2179 Location: Graz, Austria, Europe
sgmalt46 Samba Member
Joined: April 20, 2005 Posts: 1296 Location: south san francisco
Posted: Fri Nov 22, 2019 6:34 pm Post subject: Re: Need help dating an engine case? |
early bus 50-55 is 20- 2- should be type 82e?
beetle on kubel chassis? perhaps. 1944? 45?
my guess _________________ 55 deluxe 23 window bus
64 crew cab
55 rag top beetle
66 beetle
71 square back (sold) ! good luck with it Henry!
46 beetle 552nd royal army service corps CCG |
Posted: Fri Nov 22, 2019 11:31 pm Post subject: Re: Need help dating an engine case? |
I learned yesterday that
1- = KDF
2- = Kubel
5- = Type82e
7- = Typ7 Schwimmwagen
This is a restamped crankcase with a Kubel number. |
Posted: Sat Nov 23, 2019 9:28 pm Post subject: Re: Need help dating an engine case? |
might want to ask in the split forum.
1- does not mean kdf. it is 40-55 beetle. so part right.
2- and 5- are kubel and type82e I get those mixed up.
schwimmwagen is 6- as far as I know. never seen 7-
any way I think it is re-stamped because it would
have 6 point stars on both ends of the #'s
does it have the cogwheel stamps under the
pushrod tube area ? and check under the
crank pulley for casting dates. like someone else
said. by the oil pump. it does have 25hp heads .
does not have the nub on the case to bolt on the
oil filler .so the case is pre 56 .strange _________________ 55 deluxe 23 window bus
64 crew cab
55 rag top beetle
66 beetle
Posted: Sat Nov 23, 2019 11:24 pm Post subject: Re: Need help dating an engine case? |
Thanks for your answer!
Can you verify this?
Someone told me on Facebook that if the case has a square in the casting opposite to the oil cooler it is an aluminium crankcase.
The long oil dipstick shaft indicates the crankcase to be older than 1950.
So certainly not a later style crankcase up to 1956. |
Posted: Sun Nov 24, 2019 8:22 am Post subject: Re: Need help dating an engine case? |
well it is 25hp for sure. the casting date behind the
pulley is the only way to verify the year. did you find
the cogwheel stamp? they used that till 49 on the
case and a lot of parts. that will narrow it down.
aluminum ended in 51 sometime .so jury is still out.
I will take pics of my 46 case for comparo.
my casting date is on the generator stand.
on the other side. not where the are like
later ones. like your pic. strange the circles
are there and no dates? the oil fill area looks
strange as well may be the angle. more pics!
Steve
64 crew cab
55 rag top beetle
66 beetle
Posted: Sun Nov 24, 2019 12:55 pm Post subject: Re: Need help dating an engine case? |
as common back then one side was cast in feb. the other side cast in may.
both haves are stamped the same # on the top .that was added after they machined it together. case # dates it to may. _________________ 55 deluxe 23 window bus
64 crew cab
55 rag top beetle
66 beetle
