richierich Samba Member
Posted: Wed Nov 20, 2019 9:01 am Post subject: Replacing idler bearing on MST serpentine |
Anyone done this? I have one of these system on a motor - not my choice, and the bearing is grumbling. Are they easy to change? _________________ Blah..... |
grandpa red Samba Member
Joined: November 23, 2018 Posts: 520 Location: Hollister,Ca.
Posted: Wed Nov 20, 2019 9:56 am Post subject: Re: Replacing idler bearing on MST serpentine |
Just order one from mst? _________________ '72 Beetle |
Posted: Wed Nov 20, 2019 10:01 am Post subject: Re: Replacing idler bearing on MST serpentine |
The bearing assy. just bolts on. _________________ '72 Beetle |
Ebel Samba Member
Posted: Wed Nov 20, 2019 5:51 pm Post subject: Re: Replacing idler bearing on MST serpentine |
If you can just take it apart and read the number on the bearings and order new ones. I’ve never touched one of those pulleys myself. But that’s how I’ve done pretty much everything that ever used a standard bearing. |
Posted: Thu Nov 21, 2019 5:18 pm Post subject: Re: Replacing idler bearing on MST serpentine |
Done it now. Thanks for the replies. _________________ Blah..... |
Cusser Samba Member
Joined: October 02, 2006 Posts: 31361 Location: Hot Arizona
Posted: Thu Nov 21, 2019 6:01 pm Post subject: Re: Replacing idler bearing on MST serpentine |
richierich wrote: |
Done it now. Thanks for the replies. |
Ya' gonna tell us what you did, so we can learn from it ??? _________________ 1970 VW (owned since 1972) and 1971 VW Convertible (owned since 1976), second owner of each. The '71 now has the 1835 engine, swapped from the '70. Second owner of each. 1988 Mazda B2200 truck, 1998 Frontier, 2014 Yukon, 2004 Frontier King Cab. All manual transmission except for the Yukon. http://www.thesamba.com/vw/forum/album_page.php?pic_id=335294 http://www.thesamba.com/vw/forum/album_page.php?pic_id=335297 |
Posted: Thu Nov 21, 2019 7:02 pm Post subject: Re: Replacing idler bearing on MST serpentine |
Well, when I had a look at it, the idler wheel is literally the bearing. The belt simply rides on the bearing edge. I sourced a 3303-ZZ Double Row Bearing (17mm x 47mm x 22.5mm) off of Ebay - £10.00 rather than £30.00 for a 'genuine' MST one. The old one unbolts quite easily with a 15mm spanner and new one fitted. Voila. _________________ Blah..... |
Ebel Samba Member
Posted: Fri Nov 22, 2019 5:24 pm Post subject: Re: Replacing idler bearing on MST serpentine |
Told you. Easy right? |
ach60 Samba Member
Joined: May 14, 2001 Posts: 4139 Location: Santa Maria
Posted: Fri Nov 22, 2019 6:36 pm Post subject: Re: Replacing idler bearing on MST serpentine |
eBay
The best China can supply _________________ Good Luck
Al |
Posted: Sat Nov 23, 2019 1:49 am Post subject: Re: Replacing idler bearing on MST serpentine |
The bearing I ended up buying is made in Britain actually. The 'ones MST supply for 3 times the cost are Chinese. _________________ Blah..... |
