MountainKeep Samba Member
Joined: March 07, 2018 Posts: 124 Location: North Carolina
Posted: Thu Nov 21, 2019 12:58 pm Post subject: Heinous Sin Against Nature... There's a 72 Type 4 in my 71 Bus! |
Here's my bus:
Here's the horrible secret lurking in the back:
_________________ White 71 Campmobile known lovingly as "the Sulphur-Crested Cockatoo." |
Posted: Thu Nov 21, 2019 12:59 pm Post subject: Re: Heinous Sin Against Nature... There's a 72 Type 4 in my 71 Bus! |
Here's what I intend to do about it:
Joined: January 01, 2007 Posts: 16885 Location: sticksville, ct.
Posted: Thu Nov 21, 2019 1:06 pm Post subject: Re: Heinous Sin Against Nature... There's a 72 Type 4 in my 71 Bus! |
MountainKeep wrote: |
pfft. watch this
if that's a horrible secret I have no idea what to call mine _________________
gprudenciop wrote: |
Jake Raby wrote: |
Brian wrote: |
Angus II Samba Member
Joined: June 01, 2016 Posts: 708 Location: Mammoth Lakes Ca. 93546
Posted: Thu Nov 21, 2019 1:20 pm Post subject: Re: Heinous Sin Against Nature... There's a 72 Type 4 in my 71 Bus! |
Hello,
Damn, Skills. That is clean....
At times, it's good to be sinful...
Oh, and Mountainkeep.
Very nice bus you have there.
Yet, your avitar is a little too much info... at least for me. No offense implied.
I'm glad to see your a happy girl though...
Clatter Samba Member
Joined: September 24, 2003 Posts: 7551 Location: Santa Cruz
Posted: Thu Nov 21, 2019 1:24 pm Post subject: Re: Heinous Sin Against Nature... There's a 72 Type 4 in my 71 Bus! |
While that conversion is obviously a hack,
i'll bet you'll miss it when it comes time to drive the thing with that 'new' motor.
If that were mine,
I'd be re-doing the conversion with a proper mount bar and upright fan.. _________________ Bus Motor Build
What’s That Noise?!? |
kangaboy Samba Member
Joined: August 28, 2010 Posts: 1063 Location: St. Louis, Mo
Posted: Thu Nov 21, 2019 1:33 pm Post subject: Re: Heinous Sin Against Nature... There's a 72 Type 4 in my 71 Bus! |
Clatter wrote: |
If that were mine,
I'd be re-doing the conversion with a proper mount bar and upright fan.. |
Truth _________________ -74 Standard - "CaliBug" 2084T, MS3X w/FI and Crank Fire
-76 Westy - "Gandalf"
-18 GTI SE
skills@eurocarsplus wrote: |
that fucking thing looks like it drove through a J.C. Whitney catalogue and hit everything on the way out |
Hack job! That's original German angle iron in my bus!
Nothing wrong with type 4's.. I just that I want to make my 71 a 71 again... with that new-fangled "engine tin" stuff that everybody keeps talking about and all! _________________ White 71 Campmobile known lovingly as "the Sulphur-Crested Cockatoo." |
Posted: Thu Nov 21, 2019 1:57 pm Post subject: Re: Heinous Sin Against Nature... There's a 72 Type 4 in my 71 Bus! |
Hope this avatar is more to your liking Angus II... Me in my blacksmith shop. _________________ White 71 Campmobile known lovingly as "the Sulphur-Crested Cockatoo." |
Xevin Samba Member
Posted: Thu Nov 21, 2019 2:02 pm Post subject: Re: Heinous Sin Against Nature... There's a 72 Type 4 in my 71 Bus! |
So you have a type 4 conversion and want to put a 73 type 1 bug engine into your 71 type2 bus. Can you give specifics on what parts you are planing to use? Maybe some pictures. Firewall tin, transmission, brackets, and etc Maybe these guys can answer in detail what you will need to do and get. _________________ Keep on Busin'
67rustavenger wrote: |
GFY's Xevin and VW_Jimbo! |
Clatter wrote: |
Damn that Xevin... |
SGKent wrote: |
Posted: Thu Nov 21, 2019 2:28 pm Post subject: Re: Heinous Sin Against Nature... There's a 72 Type 4 in my 71 Bus! |
Thanks for your post Xevin. I would love to put my bus back to stock as I can afford to get it. I know it will be slower, but that is fine with me. I wish I could afford a freshly rebuilt 71 motor, but this is the best I can find locally and in my price range. This new motor is a '73 1600 dp out of a Super Beetle supposedly (AH317186).
I believe I still have the original 3 rib transmission in the bus currently. I have a 71 rear apron to replace the one they took a torch to. I have a "71 only" firewall tin on the way.... along with the oil cooler tin that goes through it. I have the original mustache bar, but I will unfortunately have to use the hotly debated adapter, as there is no metal to drill and tap on this motor. I think this motor has been used in a bus before because there are extra long studs on the oil pump cover already... At least motor mount brackets on the frame were spared the torch... so that's good. I will be looking for some replacement sheet metal for the sides of the motor bay that they cut out. I may have to blacksmith up something and weld it in to close up the holes on either side. I will also be looking for the original breather set up. _________________ White 71 Campmobile known lovingly as "the Sulphur-Crested Cockatoo." |
Posted: Thu Nov 21, 2019 2:37 pm Post subject: Re: Heinous Sin Against Nature... There's a 72 Type 4 in my 71 Bus! |
Oh, and I will be getting the rear tin/breast plate for this new motor soon as well. And I will have to do a little more research to see if I will need another 30 amp voltage regulator for the generator. They left the old one in the bus... I just don't know if it works. _________________ White 71 Campmobile known lovingly as "the Sulphur-Crested Cockatoo." |
71whitewesty Samba Member
Joined: February 25, 2010 Posts: 1544 Location: oregon
Posted: Thu Nov 21, 2019 2:39 pm Post subject: Re: Heinous Sin Against Nature... There's a 72 Type 4 in my 71 Bus! |
and I'd just suggest a new muffler too... single exhaust to the side. _________________ 71 Westy 1600 DP, all stock Bus 1
1970's Snow Trac 1600 SP (sold 12/2016)
1968 Tucker sno cat, sold 2021
1969 Tucker Sno cat 542
2017 VW Alltrac
71 tin top stock 1600 DP (project but runs)
Twin 71 White Westy, Bus 2, that I pulled from a 15 year slumber in a dry eastern WA field in 2015.
1966 Sundial Camper "Boomer" |
Xevin Samba Member
Posted: Thu Nov 21, 2019 2:44 pm Post subject: Re: Heinous Sin Against Nature... There's a 72 Type 4 in my 71 Bus! |
And check those manifold heat risers are clean.
No expert on trans and engine compatibility. Is it a 3rib that originally came with a type 4 engine? _________________ Keep on Busin'
Clatter wrote: |
SGKent wrote: |
Posted: Thu Nov 21, 2019 2:48 pm Post subject: Re: Heinous Sin Against Nature... There's a 72 Type 4 in my 71 Bus! |
Hello,
If they left the original voltage regulator in place, it would be an 38 amp. regulator; not 30 amp.
The 71 bus came with an 38 amp generator, dished mounting plate/tin and wider fan. To go with the dog house tin and cooler.
Do you use coal or propane for your forge? |
Posted: Thu Nov 21, 2019 3:04 pm Post subject: Re: Heinous Sin Against Nature... There's a 72 Type 4 in my 71 Bus! |
I will check the heat risers, thanks. And I believe the three rib transmission was used in '71 with a 1600... So I'm thinking/hoping it will work with this '73 1600.
And yes I hope to get the right exhaust set up as well.
And someone here on the samba said I would need a 30 amp for a bug motor.. I really don't know what I need in that regard.
And Angus, I use coal... I prefer metallurgical grade bituminous. _________________ White 71 Campmobile known lovingly as "the Sulphur-Crested Cockatoo." |
TomWesty Samba Member
Joined: November 23, 2007 Posts: 3482 Location: Wyoming,USA
Posted: Thu Nov 21, 2019 8:41 pm Post subject: Re: Heinous Sin Against Nature... There's a 72 Type 4 in my 71 Bus! |
Don’t forget to find or fab a brake booster compatible intake manifold! _________________ If you haven't bled on them, you haven't worked on them.
Visit: www.tomcoryell.com and check out my music! |
Manfred58sc Samba Member
Posted: Thu Nov 21, 2019 8:49 pm Post subject: Re: Heinous Sin Against Nature... There's a 72 Type 4 in my 71 Bus! |
Nice Bus, I have the correct intake with the proper port for brake booster, PM for details _________________ Fat chick owner/operator |
Posted: Fri Nov 22, 2019 4:10 am Post subject: Re: Heinous Sin Against Nature... There's a 72 Type 4 in my 71 Bus! |
Thanks y'all. That's a useful bit of information. I hadn't known there was no port for a brake booster on this new motor. I will have to look into that. Yay! More time and money! But some people think having functioning brakes is important... _________________ White 71 Campmobile known lovingly as "the Sulphur-Crested Cockatoo." |
airschooled Air-Schooled
Posted: Fri Nov 22, 2019 4:27 am Post subject: Re: Heinous Sin Against Nature... There's a 72 Type 4 in my 71 Bus! |
Thanks y'all. That's a useful bit of information. I hadn't known there was no port for a brake booster on this new motor. I will have to look into that. Yay! More time and money! But some people think having functioning brakes is important... |
I mean, your brakes will still FUNCTION, but they'll need a few hundred pounds of pressure to lock the wheels…
The manifold can't be swapped with the engine in, so solve this issue before proceeding. The manifold off a '71+ Auto-Stick Type 1 will also work, as it has the same vacuum take-off port.
Here is a factory "moustache bar" aka the rear engine carrier bar.
It supports the engine from three threaded mounts in a factory bus engine case.
If you don't have those holes on your bug engine case, you'll need to pick up an adapter, which is occasionally frowned upon, but often used successfully on cars that don't see marathon drives and rough off-roading.
I've never been to North Carolina, but if it's ever above 25% humidity or below 75°f, you'll want working preheated air for your carburetor. This here is a "stove pipe" and it installs before the rear breast tin. It connects to the stock air filter to take in warm air from around the heads and encourage proper fuel atomization.
I'm sure the good folks here will have more to say as you post more pictures.
See you on the road,
www.airschooled.com
alman72 Samba Member
Joined: October 09, 2014 Posts: 2573 Location: MICHIGAN
Posted: Fri Nov 22, 2019 4:30 am Post subject: Re: Heinous Sin Against Nature... There's a 72 Type 4 in my 71 Bus! |
you can make some of that money back by selling your running type4 that you have now. Best to take the buyer for a ride and let them hear/see it run before you pull it. (dibbs!) |
