pupjoint Samba Member
Posted: Sat Nov 23, 2019 8:28 am Post subject: ATL fuel cell |
anyone has used the ATL fuel cell on their Bug before?
there are too many types available. looking for the biggest to replace the stock gas tank on a 66 bug. |
buguy Samba Member
Joined: November 17, 2003 Posts: 4915 Location: Port Orange, FL
Posted: Sun Nov 24, 2019 7:38 am Post subject: Re: ATL fuel cell |
I've never used one of those, but I have seen 12 gallon replacement tanks if that does any good. |
Posted: Sun Nov 24, 2019 7:42 am Post subject: Re: ATL fuel cell |
buguy wrote: |
replacement tanks mean plug and play into the stock Bug location? |
TomSimon Samba Member
Posted: Sun Nov 24, 2019 8:23 am Post subject: Re: ATL fuel cell |
I've never seen a plug-n-play replacement fuel cell for an acvw, only custom fitments. Typically if a guy is adding a racing upgrade like a fuel cell, he's got a hotrod engine, that requires more fuel delivery than the mechanical fuel pump and even the stock in-tunnel fuel line can support.
Mike Lawless' adapted a fuel cell to the fuel tank stock opening on his 'show car build turned race car' blue Ghia. He built a flat aluminum plate, maybe 3/16" thick, holding it in place using the stock fuel tank clip brackets, in place of the stock tank. Then adapted an aftermarket aluminum fuel cell to the 3/16" thick aluminum plate, similar to this one:
https://www.jegs.com/i/JEGS/555/15315/10002/-1?gcl...KIQAvD_BwE
I hope that helps _________________ 2-time NASA Pro Racing Champion, Bonneville 130 Club and 150 Club Memeber, BRS Pro Gas racer |
gprudenciop Samba Member
Joined: July 06, 2008 Posts: 606 Location: portland or
Posted: Sun Nov 24, 2019 1:57 pm Post subject: Re: ATL fuel cell |
Not an atl but I installed this from summit racing..I can measure it if you like.
_________________ Never look down at anybody unless you are helping them up..
Loaning someone your strength instead of reminding them of their weakness = kindness.. |
slalombuggy Samba Member
Posted: Sun Nov 24, 2019 5:36 pm Post subject: Re: ATL fuel cell |
CIP1.COM lists a 12.5 gallon stock style tank that drops in. I bought on for my Ghia project.
brad |
jpaull Samba Member
Joined: February 22, 2005 Posts: 3466 Location: Paradise, Ca
buguy Samba Member
Posted: Mon Nov 25, 2019 9:18 am Post subject: Re: ATL fuel cell |
gprudenciop wrote: |
if u don't mind, that would be really great if you can help with the measurements.
how many gallons is that?
u made the brackets yourself? mind sharing the link for this tank at summit? |
Posted: Mon Nov 25, 2019 10:51 am Post subject: Re: ATL fuel cell |
This is the tank I used. It is ten gallon but you can see the measurements needed if you buy something bigger. You have room to go down.i used some angle iron from home depot for the mount. The cover is a dairy nut and some flat plate I had.
https://www.summitracing.com/parts/jzp-892-010-01/
Here is the bracket in blue.
