txasylum Samba Member
Joined: December 15, 2004 Posts: 389 Location: Boyers, PA
Posted: Sun Nov 24, 2019 3:56 pm Post subject: Fuel sending unit / fuel gauge question |
Car is 74 super beetle
Should there be continuity between the two wires that connect to the fuel sending unit? I've been chasing my fuel gauge problem (not reading full when full, but read less than 1/2 tank). I've taken the fuel sending unit out and checked the full/empty ohm reading. That is good. I connect the wires when fuel sending unit is out of the tank. I can get it to read full or empty depending where I place the lever.
I've been bending the wires trying to get it to read. I got it to read empty when empty, but when I put 5 gallons in the tank, it read just above 1/4. So I played with bending the wires so that it reads closer to 1/2 tank, but then when I emptied the fuel tank the gauge reads about 1/4.
I checked continuity between the two wires and I get continuity (buzzes on my meter). If one is a ground and the other is 12v, why am I getting continuity? |
busdaddy Samba Member
Joined: February 12, 2004 Posts: 51156 Location: Surrey B.C. Canada, but thinking of Ukraine
Posted: Sun Nov 24, 2019 5:08 pm Post subject: Re: Fuel sending unit / fuel gauge question |
The continuity between the terminals changes as the fuel level rises or falls, one is a ground (on the side), the other is the variable ground to the gauge (near the middle with plastic surrounding it). You should get 0 ohms between the brown wire and the car's body, and ~70-90 ohms between the 2 terminals on the sender (wires disconnected) at empty, close to 0 ohms at full.
How sure are you the float actually floats well in gasoline?, many replacement units don't after soaking for a year or so. _________________ Rust NEVER sleeps and stock never goes out of style.
Слава Україні! |
Posted: Sun Nov 24, 2019 5:13 pm Post subject: Re: Fuel sending unit / fuel gauge question |
I took it out of the gas tank and connected it to the wires. By hand, if the one lever is in the down position, the fuel gauge shows empty. If the lever is in the upper most position, fuel gauge shows full. I just can't get it to do that when it is in the fuel tank.
I've considered buying a new one, but it seems all the tests I do this sending unit is good, but who knows. It just is not working properly in the fuel tank.
From what I read online, one position is 11 ohms and the other is 73 ohms, which is what this gauge reads.
busdaddy wrote: |
How sure are you the float actually floats well in gasoline?, many replacement units don't after soaking for a year or so. |
Posted: Sun Nov 24, 2019 5:23 pm Post subject: Re: Fuel sending unit / fuel gauge question |
Sounds like the float isn't floating, or the arms are hanging up on a baffle inside the tank. _________________ Rust NEVER sleeps and stock never goes out of style.
Слава Україні! |
Posted: Sun Nov 24, 2019 7:13 pm Post subject: Re: Fuel sending unit / fuel gauge question |
I've got the tank out of the car and have been messing with this sending unit. I got it to register on empty, but it seems that the long arm with the float hits the top of the tank, therefore it is not raising the smaller float up high enough to register full. If I bend the arms so that it pushes the smaller float up to register full, then it is too high up when it should be registering the tank empty, therefore it shows 1/4 or so full when in fact it is empty.
I thought about ordering a new one, but it seems I'll have the same problem. IDK
busdaddy wrote: |
Sounds like the float isn't floating, or the arms are hanging up on a baffle inside the tank. |
beetlenut Samba Member
Posted: Sun Nov 24, 2019 8:04 pm Post subject: Re: Fuel sending unit / fuel gauge question |
[quote="txasylum"]I thought about ordering a new one, but it seems I'll have the same problem. IDK
FWIW, I put a new one in my 74 Super this last year and it doesn't work that much better! I assume you also tried switching the wires around going to the sender. I also assume you put the sender into the tank clocked the correct way. _________________ scrapyards are for quitters
Wetstuff wrote: |
... I spend more time shaking it than directing it?! I get a pretty decent blast for 8sec. then have to shake it again. |
- Words to live by right there!
My 74 Super rebuild thread: http://www.thesamba.com/vw/forum/viewtopic.php?p=6507104#6507104 |
Posted: Sun Nov 24, 2019 8:27 pm Post subject: Re: Fuel sending unit / fuel gauge question |
txasylum wrote: |
busdaddy wrote: |
Ummm....., the smaller float comes free of the long arm and continues rising for the top 1/2 of the tank, the longer one only deals with 1/2 tank or less. _________________ Rust NEVER sleeps and stock never goes out of style.
Слава Україні! |
Dan the workingstiff Samba Member
Joined: July 03, 2006 Posts: 824 Location: Downriver, MI
Posted: Mon Nov 25, 2019 12:53 am Post subject: Re: Fuel sending unit / fuel gauge question |
[quote="beetlenut"]
txasylum wrote: |
FWIW, I put a new one in my 74 Super this last year and it doesn't work that much better! I assume you also tried switching the wires around going to the sender. I also assume you put the sender into the tank clocked the correct way. |
I'm jumping in with NO EXPERIENCE on this issue. But, if it needs to be referenced front to back or back to front due to the amount of fuel and where it's sitting. |
Posted: Mon Nov 25, 2019 5:18 am Post subject: Re: Fuel sending unit / fuel gauge question |
Yes, all is in correct and plugged in correctly. I verified ground to ground, etc.
Well, I just ordered a new one. Let's see what happens Monday when it comes in.
[quote="beetlenut"]
txasylum wrote: |
AlmostHeavenWV_VW Samba Member
Posted: Mon Nov 25, 2019 8:44 am Post subject: Re: Fuel sending unit / fuel gauge question |
Not my work, but I would advise reading up on this member's (blue69baja)work and watch his videos on the fuel sender function, available aftermarket sender brands, and ways to adjust for better performance:
https://www.thesamba.com/vw/forum/viewtopic.php?t=725590&highlight=fuel+gauge _________________ 1973 Standard Beetle
1600DP AK case
Solex 34PICT3 Carb
Bosch DVDA 205AJ Distributor |
VW_Jimbo Samba Member
Joined: May 22, 2016 Posts: 9969 Location: Huntington Beach, CA
Posted: Mon Nov 25, 2019 8:45 am Post subject: Re: Fuel sending unit / fuel gauge question |
The new fuel level sending units suck!
Here is a great article on the subject!
https://www.thesamba.com/vw/forum/viewtopic.php?t=711130 _________________ Jimbo
TDCTDI wrote: |
67rustavenger wrote: |
GFY's Xevin and VW_Jimbo! |
Blue69Baja Samba Member
Joined: September 04, 2008 Posts: 1065 Location: Fair Oaks
Posted: Tue Nov 26, 2019 7:53 am Post subject: Re: Fuel sending unit / fuel gauge question |
69-79 fuel gauge system, Super and Std videos by me. Should provide a full understanding of the system and the problems introduced by non OEM parts.
Pretty sad but workable.
The videos are not professional but hopefully will answer your questions.
https://www.youtube.com/channel/UC_2W_OgL6dEgsA5VVBrKObA/videos?view_as=subscriber
Jim _________________ 69 Baja with a 1914...
72 Super 100% orig...W/ factory air... 56,000mi
Even the spare is original.. |
