Onceler Samba Member
Posted: Fri Nov 29, 2019 10:34 pm Post subject: Fitting tins |
I’ve been working on fitting tins for my 2387 for the street. Other than it generally looking like hell atm, any advice on anything I’ve missed?
_________________ 1972 Karmann Ghia |
66brm Samba Member
Joined: January 25, 2010 Posts: 3676 Location: Perth Western Australia
Posted: Fri Nov 29, 2019 11:16 pm Post subject: Re: Fitting tins |
Only one bit, make sure to trial fit the actual manifolds you will use, not all are the same _________________ Aust. RHD 66 Type 1
Aust. RHD 57 Type 1 Oval
modok wrote: |
I am an expert at fitting things in holes, been doing it a long time |
ALB Samba Member
Joined: August 05, 2008 Posts: 3480 Location: beautiful suburban Wet Coast of Canada
Posted: Sat Nov 30, 2019 4:06 am Post subject: Re: Fitting tins |
Looks like you've got it covered. 66brm's point is a good 1- depending on the thickness of the manifolds around the bottom, you could have some work yet. Is there a reason you went with the type 3 bottom pieces? _________________ On a lifelong mission to prove (much to my wife's dismay) that Immaturity is Forever!! |
oprn Samba Member
Joined: November 13, 2016 Posts: 12632 Location: Western Canada
Posted: Sat Nov 30, 2019 4:53 am Post subject: Re: Fitting tins |
Wrong bottom tins for an upright fan. Also do you have the flaps and thermostat to install still? And what are you doing for the oil cooler, dog house mod? Can't see that in the picture.
The rest looks good! |
gt1953 Samba Member
Joined: May 08, 2002 Posts: 13842 Location: White Mountains Arizona
Posted: Sat Nov 30, 2019 7:20 am Post subject: Re: Fitting tins |
Wondering about the main fan shroud? Does it have the directional vanes like the factory stock shroud? Get rid of the type three tins as the engine will run hotter. _________________ Volkswagen: We tune what we drive.
72 type 1
72 Squareback
Floating VW Samba Member
Joined: April 28, 2015 Posts: 1596 Location: The South Zone
Posted: Sat Nov 30, 2019 8:48 am Post subject: Re: Fitting tins |
Don't forget these little buggers:
You might already have them in, but I couldn't see in your pics.
The rest is looking good, except for maybe the Type 3 tins, as noted above. _________________ "It's time you started treating people as individuals, rather than mathematically predictable members of an aggregate set, regardless of how well that works." |
volksworld Samba Member
Joined: November 26, 2011 Posts: 2525 Location: formerly NY currently NC
Posted: Sat Nov 30, 2019 10:08 am Post subject: Re: Fitting tins |
without entering into a debate about the effectiveness of the 311 style lower tins , the aftermarket ones usually dont clip on very well and you should weld on some tabs so you can bolt them to the cylinder covers so they dont wind up sitting on your pushrod tubes |
Glenn Mr. 010
Joined: December 25, 2001 Posts: 76760 Location: Sneaking up behind you
Posted: Sat Nov 30, 2019 10:45 am Post subject: Re: Fitting tins |
volksworld wrote: |
I usually just safety wire then around the cylinders so they don't tattle. _________________ Glenn
Member #1009
#BlueSquare |
Posted: Sat Nov 30, 2019 1:19 pm Post subject: Re: Fitting tins |
Good points. It’s a doghouse cooler, I still need to fit all that.
Looks like I still need to secure bottom tins, install the small cylinder deflectors, fit my manifolds. Other than the stuff we could debate on, any other tips/tricks? _________________ 1972 Karmann Ghia |
slalombuggy Samba Member
Posted: Sat Nov 30, 2019 2:53 pm Post subject: Re: Fitting tins |
I weld in vanes to mimic the flaps to direct air over the cylinders. I also fill in the space between the cooler and the "ramp" on the shroud that directs air into the cooler.
Posted: Sat Nov 30, 2019 3:11 pm Post subject: Re: Fitting tins |
slalombuggy wrote: |
I weld in va rs to mimic the flaps to direct air over the cylinders. I also fill in the space between the cooler and the "ramp" on the shroud that directs air into the cooler.
Great ideas! I’m gonna do that. Thanks for sharing _________________ 1972 Karmann Ghia |
