phlogiston Samba Member
Posted: Sat Nov 30, 2019 3:11 pm Post subject: single piece syncro fuel sender bracket?? |
i figured i'd just replace the fuel sender bracket because the tank is out, but was amazed to find the one that's in there is 1 piece! were some of the OEM ones put inside they tank when it was manufactured? it seems there's no way to get this out of the tank without grinding or cutting, which seems a bit dangerous given all the residual fumes coming from the tank, not to mention the metal particles and crap that will inevitably end up in there.
has anyone devised a better way to cut these out??
dkoesyncro Samba Member
Posted: Sat Nov 30, 2019 4:45 pm Post subject: Re: single piece syncro fuel sender bracket?? |
I used heavy duty wire cutters, line man type. This didn't cut all that well but made it easy to fold like a taco and remove! |
4Gears4Tires Samba Member
Posted: Sat Nov 30, 2019 4:50 pm Post subject: Re: single piece syncro fuel sender bracket?? |
Studs look good though, why replace it? _________________ '87 Syncro
dobryan Samba Member
Joined: March 24, 2006 Posts: 16505 Location: Brookeville, MD
Posted: Sat Dec 03, 2022 4:21 pm Post subject: Re: single piece syncro fuel sender bracket?? |
phlogiston wrote: |
I see that same thing. WTH?
_________________ Dave O
The Western Syncro build
Sodo Samba Member
Joined: July 06, 2007 Posts: 9615 Location: Western WA
Posted: Sat Dec 03, 2022 11:10 pm Post subject: Re: single piece syncro fuel sender bracket?? |
Why take it out ??
Can't you simply put a new seal on it? _________________
....KTMs, GasGas, SPOT mtb |
MarkWard Samba Member
Joined: February 09, 2005 Posts: 17154 Location: Retired South Florida
Posted: Sun Dec 04, 2022 5:29 am Post subject: Re: single piece syncro fuel sender bracket?? |
Sodo wrote: |
Why take it out ??
Can't you simply put a new seal on it? |
Agreed. The factory part is better made and if the studs are useable and it’s not disintegrating from rust, new seal and back in place. _________________ ☮️ |
