Krumby Samba Member
Posted: Wed Dec 04, 2019 1:27 am Post subject: Which direction does the pilot bearing go in ? |
Aloha
I was just looking at the new pilot bearing which way does it go in wide lip out or to the back ? Didn’t realize that it was different on each side.
Mahalo
Steve M. Samba Member
Joined: July 30, 2013 Posts: 6833 Location: Fort Lauderdale, Fl.
Posted: Wed Dec 04, 2019 3:13 am Post subject: Re: Which direction does the pilot bearing go in ? |
You' ve got the transaxle out , see which side fits over the input shaft. _________________ This free advice is worth exactly what you paid for it.
clift_d Samba Member
Joined: December 02, 2012 Posts: 265 Location: Hackney innit, UK
Posted: Wed Dec 04, 2019 3:30 am Post subject: Re: Which direction does the pilot bearing go in ? |
Bentley says any text / markings on the bearing cage should face out, and to lubricate with Molybdenum disulfide grease when installing. _________________ 1988 LHD T25 1.6TD Westfalia Club Joker syncro |
tencentlife Samba Member
Posted: Wed Dec 04, 2019 8:24 am Post subject: Re: Which direction does the pilot bearing go in ? |
Will work either way, I would put them in flat side out because it's more surface to drive against. _________________ Shop for unique Vanagon accessories at the Vanistan shop:
gears Samba Member
Joined: October 28, 2002 Posts: 4391 Location: Tamarack, Bend, Kailua
Posted: Wed Dec 04, 2019 9:34 am Post subject: Re: Which direction does the pilot bearing go in ? |
The lip on the numbered side is slightly thicker, to resist deformation during installation. _________________ aka Pablo, Geary
'90 Syncro Westy SVX
'87 Syncro GL 2.5
https://guardtransaxle.com |
Krumby Samba Member
Posted: Wed Dec 04, 2019 11:46 am Post subject: Re: Which direction does the pilot bearing go in ? |
Mahalo guys !
You guys are always a great help
David |
ebennett Samba Member
Joined: December 18, 2003 Posts: 280 Location: West Chester PA
Posted: Fri Mar 19, 2021 8:32 am Post subject: Re: Which direction does the pilot bearing go in ? |
Where in the Bentley are the details for installing the pilot bearing? I can't seem to find them.
With the text/marking facing out, just whack it in until it bottoms out? Using a socket equal to the outer diameter of the bearing? _________________ GDTRFB |
T3 Pilot Samba Member
Joined: January 10, 2011 Posts: 1507 Location: Deep South of the Great White North
Posted: Fri Mar 19, 2021 9:22 am Post subject: Re: Which direction does the pilot bearing go in ? |
Bentley 13.56 specifies orientation of the bearing.
Consider the upgraded pilot bearing 056 105 313 C
Note: flywheel modification required for this bearing. The O ring end faces out. _________________ 1988 Vanagon
The most important part in every vehicle is the nut behind the wheel...... |
ALIKA T3 Samba Member
Joined: July 30, 2009 Posts: 6361 Location: Honolulu,Hawaii and France
Posted: Fri Mar 19, 2021 11:42 am Post subject: Re: Which direction does the pilot bearing go in ? |
T3 Pilot wrote: |
Note: flywheel modification required for this bearing. The O ring end faces out. |
So for years I thought this bearing was an upgrade, repeating what I read about it. It is actually for a diesel Vanagon or any 4 inline engines of that era and IT DOESNT FIT in a WBX crank, you`ll have to redrill the crank to install this bearing. It is also a bit longer. _________________ Silicone Steering Boots and 930 Cv boots for sale in the classifieds.
Posted: Fri Mar 19, 2021 1:13 pm Post subject: Re: Which direction does the pilot bearing go in ? |
Salut mon vieux!
I’m installing another one of these this weekend, they do in fact work. It is the same diameter bearing, but is a few mm longer to accommodate the integral o ring seal. The O ring seal replaces the factory felt seal and associated metal spacer which presses into the flywheel. So yeah it is true that you have to clearance the recess in the flywheel to accommodate the longer diesel bearing, but the fit into the end of the crank is the same. Deleting the spacer and felt ring seal=upgrade in my book.
I attached a couple of pictures below to illustrate the difference. The Diesel pilot bearing is on the left, the MV bearing plus seal and spacer on the right...
Here the height of the O ring bearing on the left vs. Bearing plus felt on right.
Posted: Fri Mar 19, 2021 4:52 pm Post subject: Re: Which direction does the pilot bearing go in ? |
Countersinking the engine side of the flywheel to allow the use of the longer "diesel" bearing takes almost no time when using a quality stepped drill bit. I started doing this on both my Bays and Vanagons about a dozen years ago with great success. |
?Waldo? Samba Member
Posted: Fri Mar 19, 2021 6:37 pm Post subject: Re: Which direction does the pilot bearing go in ? |
I have also used a stepped drill bit to clearance the WBX flywheel and installed the diesel bearing into a WBX. Total time modifying the flywheel is ~1 minute if you take a break in the middle of the job. No mods to the crank. |
Posted: Fri Mar 19, 2021 10:49 pm Post subject: Re: Which direction does the pilot bearing go in ? |
Diesel pilot bearing installed in crank.
jberger Samba Member
Posted: Sun Mar 21, 2021 7:45 pm Post subject: Re: Which direction does the pilot bearing go in ? |
First.. Numbers out on the bearing.. no matter which you choose. That said.. things are not going to self destruct no matter how it gets pressed in.
Having decades of various installs.. on paper I agree that the diesel bearing is better. Practical knowledge says there is nothing to improve upon. Even sans OG felt and retaining ring this is just a minimally stressed bearing that does its job without complaint. How many modern cars use bronze bushings?
Of course you can drill your cast iron flywheel like butter but why?
J |
Posted: Sun Mar 21, 2021 8:32 pm Post subject: Re: Which direction does the pilot bearing go in ? |
jberger wrote: |
J |
I would say that about 75% of the classic VW transmissions I have seen have had a scored up input shaft from having had a pilot bearing failure over the years. |
Posted: Sun Mar 21, 2021 8:45 pm Post subject: Re: Which direction does the pilot bearing go in ? |
Wildthings wrote: |
jberger wrote: |
J |
I have also seen failed pilot bearings (not simply scored input shafts). Just not in those numbers. Like "just a couple" truly failed where you can not shift. Versus the hundreds of thousands of miles completed with a pinky fingers worth of grease in a non felted\shimmed or sealed pilot bearing. The numbers don't add up. I agree with all the suggested measures but also know that despite our missteps.. the show will go on.. and on.. and... well... on.
J |
