John cilia Samba Member
Joined: May 03, 2016 Posts: 140 Location: Toronto, Canada
Posted: Wed Dec 04, 2019 12:06 pm Post subject: 25 hp motor question |
Does anyone know what goes in the small bottom hole of block?
Iam peiceing this motor together and wondering what parts go into it.
Thanks
_________________ Currently restoring a 1953 11g in metallic blue.
The most important thing on a Tombstone is the Dash between the 2 dates. |
finster Samba Member
Joined: May 26, 2012 Posts: 7935 Location: north o' the border
Posted: Wed Dec 04, 2019 12:42 pm Post subject: Re: 25 hp motor question |
do you mean the hole at bottom right? crankcase plug and has a slotted face
_________________ "we're here on Earth to fart around" kurt vonnegut
nothing lasts, nothing is finished, and nothing is perfect... |
Posted: Wed Dec 04, 2019 12:49 pm Post subject: Re: 25 hp motor question |
So there are no springs or other parts behind it ? _________________ Currently restoring a 1953 11g in metallic blue.
Posted: Wed Dec 04, 2019 1:22 pm Post subject: Re: 25 hp motor question |
I've never removed one but pretty sure it's just a plug
sgmalt46 Samba Member
Joined: April 20, 2005 Posts: 1296 Location: south san francisco
Posted: Wed Dec 04, 2019 4:18 pm Post subject: Re: 25 hp motor question |
John cilia wrote: |
So there are no springs or other parts behind it ? |
nope nothing behind it. _________________ 55 deluxe 23 window bus
64 crew cab
55 rag top beetle
66 beetle
71 square back (sold) ! good luck with it Henry!
46 beetle 552nd royal army service corps CCG |
Posted: Wed Dec 04, 2019 4:22 pm Post subject: Re: 25 hp motor question |
Thanks for the good info.
John _________________ Currently restoring a 1953 11g in metallic blue.
mikeandkirsti Samba Member
Posted: Thu Dec 05, 2019 1:34 am Post subject: Re: 25 hp motor question |
The plug is tapered and you can use the original VW plug with a provision for a large screwdriver or buy a modern tapered plug in the same size (available from Würth in Europe) with a provision for a hex key wrench. |
blood Samba Member
Joined: October 01, 2015 Posts: 50 Location: nashville tn
Posted: Sun Dec 29, 2019 5:51 pm Post subject: Re: 25 hp motor question |
I think this opening is a drilling for the oil pickup tube to spigot into. Also on the 25 hp engine there is no internal opening to allow the oil in this timing gear area to drain back to the main sump. I believe that by the time 36 hp engines were built, a drain back passage had been cut into one of the case halves. I would also guess that would be a OK modification to perform on those early 25 hp engines. That would allow all oil to be removed during oil changes. Please chime in if some has had experience in this. |
Zwitterkafer Samba Member
Joined: November 17, 2007 Posts: 878 Location: Lanark County, Ontario, Canada
Posted: Sun Dec 29, 2019 7:19 pm Post subject: Re: 25 hp motor question |
The oil drain-back passage question was recently answered in another thread:
PR entry reads: Jan 1950, from chassis 1-0138765, unit # 170086:
Crankcase: "Now: Oil can be completely drained off (passage through timing gear chamber)" _________________ "Criticism comes easier than Craftsmanship"
- Zeuxius, 400 BC |
