Why don’t these turn signals work? |
It’s the grounds at one or more of the corner indicator lights. |
0% |
[ 0 ] |
It’s the ground at the ground tree above the fuse block. |
25% |
[ 1 ] |
It’s the turn signal stalk switch. |
0% |
[ 0 ] |
Something else |
75% |
[ 3 ] |
Total Votes : 4 |
jimf909 Samba Member
Posted: Thu Dec 05, 2019 10:49 pm Post subject: Turn signal fail: poll |
The turn signal function on my 1990 Vanagon has failed:
Symptoms
- move the turn signal stalk to either right or left and the idiot light flashes as expected and the turn signal relay clicks as normal
- unfortunately, all four corners light as if the four-way flasher switch has been turned on (the four-way flasher works just as expected)
- furthermore, if I step on the brake pedal while the turn signal is turned on (right or left) all four indicators stop flashing and remain lit
- i.e. with the turn signal stalk switched to right or left, all for indicators flash; step on the brakes and all four corners stop flashing and remain lit.
I’ve swapped the relay with the same results.
What’s wrong: grounds? Turn signal switch worn in some way? Something else? _________________ - Jim
Abscate wrote: |
E1 Samba Member
Joined: January 21, 2013 Posts: 6572 Location: Westfalia, Earth
Posted: Fri Dec 06, 2019 4:32 am Post subject: Re: Turn signal fail: poll |
My vote is incorrect voltage. _________________ ‘84 Westy, 2.1L with Digijet, 5.43 R+P, GT Gears
— Colin Chapman |
djkeev Samba Moderator
Joined: September 30, 2007 Posts: 32632 Location: Reading Pennsylvania
kamzcab86 Samba Moderator
Posted: Fri Dec 06, 2019 9:13 am Post subject: Re: Turn signal fail: poll |
jimf909 wrote: |
Turn signal switch worn in some way? Something else? |
Keep in mind that the turn signal wiring is routed through the flasher/hazard switch, which can cause problems if the switch goes bad. _________________ ~Kamz
2016 Golf GTI S
