oprn Samba Member
Joined: November 13, 2016 Posts: 12740 Location: Western Canada
Posted: Fri Dec 06, 2019 5:39 am Post subject: TDI mod experiance? |
I have two '02 TDIs that are down a bit on power. It seems the EGR system is responsible for this at times and needs regular cleaning. I see some people delete this system. Who has experiance with this and what are the pitfalls?
Thanks in advance. |
Joined: August 31, 2013 Posts: 12858 Location: North Carolina
Posted: Fri Dec 06, 2019 6:35 am Post subject: Re: TDI mod experiance? |
"Regular cleaning" is roughly 100,000 miles before there's any noticeable decrease in performance. You can do a EGR delete but by the time you do the block off, re-plumb the coolant lines, & pay for a tune that deletes the EGR function to keep the light off, UNLESS the cooler takes a shit, it seems like wasted money.
You can adjust the parameters so that the EGR effectively never comes on & leave it all in place. _________________ Everybody born before 1975 has a story, good, bad, or indifferent, about a VW.
Butcher Samba Member
Joined: December 05, 2015 Posts: 1285 Location: Right Here
Posted: Fri Dec 06, 2019 7:46 am Post subject: Re: TDI mod experiance? |
TDCTDI wrote: |
You can adjust the parameters so that the EGR effectively never comes on & leave it all in place. |
This, right after a complete cleaning.
https://www.youtube.com/watch?v=xIijYgvxW0g |
oprn Samba Member
Posted: Fri Dec 06, 2019 2:51 pm Post subject: Re: TDI mod experiance? |
Looks a bit harsh. No danger of warping the manifold? |
Posted: Fri Dec 06, 2019 3:32 pm Post subject: Re: TDI mod experiance? |
oprn wrote: |
Nope, I've done a couple hundred that way. _________________ Everybody born before 1975 has a story, good, bad, or indifferent, about a VW.
oprn Samba Member
Posted: Sun Dec 08, 2019 10:00 pm Post subject: Re: TDI mod experiance? |
Ok Thanks!
The Jetta was into a shop just a few months back to have this intake clogging problem looked after. Not a VW dealer but a European car shop that does a lot of VWs and sells air cooled parts too. My daughter has been driving this car to collage for the last 2 years in the city so I have not been driving it or close enough to over see the maintenance.
This weekend we had possession of the car and drove it about 900 miles and I now have a better feel for what it's running like and have doubts about the EGR valve being the problem. Here is what it is doing.
When you got through the gears it pulls hard for about 3 seconds in every gear and then goes flat. If you then leave your foot into it and wait, after 8 to 10 seconds it slowly gains power again until it seems to be pulling about normal. If you are cruising at a steady speed and go to pass it does the same thing, 3 seconds of good power, goes flat and then a slow steady gain back to good power.
I tried it out on a long river hill, rolled the power on as I pulled out into the passing lane and it gave the usual burst, went flat, then slowly started to pull again. It held good power for the rest of the hill passing everything other car there.
I put a new fuel filter in it already so that is not the problem. Ideas? Vacuum leak? Sticky waste gate? Turbo clogged with carbon? |
Posted: Mon Dec 09, 2019 3:40 am Post subject: Re: TDI mod experiance? |
This going into limp mode can be caused by several things. Most likely you have a vacuum leak somewhere. _________________ Everybody born before 1975 has a story, good, bad, or indifferent, about a VW.
oprn Samba Member
Posted: Mon Dec 09, 2019 5:16 am Post subject: Re: TDI mod experiance? |
Thanks again.
No check engine light, should there be? |
Posted: Mon Dec 09, 2019 6:51 am Post subject: Re: TDI mod experiance? |
With no check engine light (although codes may be stored ), it could be a MAF sensor. Just about the only thing that does not trigger a code is the damned MAF sensor.
There again, scan the DTC memory & check for vacuum leaks before throwing parts at it. But you could swap from your other car to check. _________________ Everybody born before 1975 has a story, good, bad, or indifferent, about a VW.
Posted: Mon Dec 09, 2019 8:08 am Post subject: Re: TDI mod experiance? |
Not a bad idea to replace the fuel filter if you do not know when it was replaced last. |
oprn Samba Member
Posted: Mon Dec 09, 2019 8:38 pm Post subject: Re: TDI mod experiance? |
Butcher wrote: |
Last line in post #6. |
oprn Samba Member
Posted: Mon Dec 09, 2019 8:45 pm Post subject: Re: TDI mod experiance? |
TDCTDI wrote: |
There again, scan the DTC memory & check for vacuum leaks before throwing parts at it. But you could swap from your other car to check. |
No the Gulf is 12 hours drive one way away. I do have an '04 TDI in the yard but I understand it is a different fuel system than the '02.
I bought an OBDII code reader a while back but have never used it. Is it of any value here? |
Posted: Tue Dec 10, 2019 8:33 am Post subject: Re: TDI mod experiance? |
oprn wrote: |
Butcher wrote: |
I'm old and can't read.
How about I second the idea about the fuel filter replacement. |
Posted: Tue Dec 10, 2019 9:05 am Post subject: Re: TDI mod experiance? |
oprn wrote: |
TDCTDI wrote: |
It always helps to know what the ECM is thinking. More than likely, you will have fault codes for overboost/underboost (And probably glow plugs too, they love throwing that code.) Depending on the level of your scan tool, you might be able to get real time data, if so, this would be great for diagnosing a faulty MAF. If not, then it's just a guessing game. Once you clear the faults, you could also disconnect the MAF, a car with a faulty one will sometimes run better without it plugged in. _________________ Everybody born before 1975 has a story, good, bad, or indifferent, about a VW.
oprn Samba Member
Posted: Tue Dec 10, 2019 7:54 pm Post subject: Re: TDI mod experiance? |
Ok I will give it a go. I have some busy days coming up so not likely until the weekend.
Thanks again! |
oprn Samba Member
Posted: Wed Dec 25, 2019 9:32 pm Post subject: Re: TDI mod experiance? |
Finally work slowed down enough to get a day off. Did some checking, the vacuum pump gives me -18"Hg right on start up and settles down to -23"Hg very soon after. There are 3 vacuum pots, one on the turbo waste gate, two up on the EGR valve body. All held vacuum and I observed motion on all 3. The hose down to the waste gate pot is frayed and will be replaced but again for now it holds a vacuum.
There are also 3 units that I would call solenoids but most likely have another proper name that I think convert the signal from the brains of this system to a vacuum signal to put these pots in motion. Not sure how to test them yet.
Tomorrow I will attempt to use my code reader and see if I learn anything.
TDCTDI, where is this MAF sensor you speak of? I have the other car in the yard now so I could swap them and see if the problem follows. Thanks! |
oprn Samba Member
Posted: Thu Dec 26, 2019 3:49 pm Post subject: Re: TDI mod experiance? |
Got the code reader working - no codes. Found the MAF sensor, switched it with the one from the other car. Running GREAT now! Problem found! I will clean this faulty one up and see if it works again. Seems to have a bit of black soot on it. |
oprn Samba Member
Posted: Thu Dec 26, 2019 5:00 pm Post subject: Re: TDI mod experiance? |
Cleaned up the sensor and put it back in, all good! |
